On my screen it's showing me E1 what does that mean ?
Acer aspire e1-532 battery led off when plug the ac adapter and does not power up
It is beyond what I can diagnose remotely, as it fails to power up even on just the AC adaptor, without the battery.
It needs a professional repair, which means opening it up to find out why it fails to start or even show a screen, which means no software fix can be done.
Feb 05, 2015 | Acer Computers & Internet
My air conditioner want turn on or anthing and it shows e1, whats this mean
The E1 code is an error code that appears on the LED temperature display of some digital air conditioners. The error code could mean anything from dirty air filters to a damaged room thermistor, a safety connected to your thermostat that detects room temperature. Troubleshooting the cause of this error code may improve your air conditioner's performance
Sep 15, 2013 | Haier HWR06XC7 Air Conditioner
What does E1 mean in tadiran 250 R, it works then stops and screen shows E1 when it operates as a heater
h Air Conditioners
Nov 24, 2012 | Heating & Cooling
What does error code #e1 mean on Canon CLBP 460 PS mean?
Meaning of error code E1
The motor sensor or sensors, the DC controller on the main board DC controller.
I can not give solution to your problem, because possibility of damage main board.
I suggest you contact Canon Customer Support (e-mail, telephone, or repair contacts).
Nov 16, 2011 | Canon CLBP 460 PS Laser Printer
Hi Mr. Janome expert, My Janome Memory Craft 4900QC is showing error message E1.Unfortunately I lost the manual to identify the solution to this problem. Could you mind telling what this error means...
E1 means it out of order--something in the electronics is mess up--it needs to be serviced
by a service tech with the tools to check the electronics of the machine
Sep 13, 2011 | Janome Memory Craft 4900QC Mechanical...
The meaning of display Error Code-E1
E-1 Indoor unit room temp sensor faulty. Replace it.
Oct 04, 2010 | Samsung AW0503B Air Conditioner
What is E!
Hi
Thanks for using FixYa. Error E1 means thermistor failure, it flashes when the thermistor circuit is open. The dryer will not operate if the exhaust temperature drops below 18° F. or exceeds 250° F. To resolve this the thermistor should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Whirlpool ET8CHEXSQ Dryer
My tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
May 16, 2010 | Exercise & Fitness
Call for Service error message E1-12
hi E1-12 for image processing unit ,
thanks
May 14, 2010 | Sharp AR-235 Copier
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
