Question about Reebok Exercise & Fitness
Why does my reebok 8400c treadmill stop after a minute or two? The control panel works, but the tread will stop. I can start it manually, but it stops again after 1 or 2 minutes.
  • Reebok Master
  • 6,694 Answers
You have to check the speed sensor potion. Try to align the speed sensor or check is there is any dust accumulate on speed sensor.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Dec 28, 2016
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: I have a Reebok 8400C treadmill. The control panel stopped working .. I get power but no buttons are functioning?
1) replace batteries and clean contacs with c.cleaner, tight the connector very well
2) tight the ribbon cables, clean it, and tight the plug or connector from display board vs lower board, see the b. diagram
3) adjust the REED switch, clean it, and tight the plug well.
God bless you
Posted on Oct 15, 2012
Reebok T3.2 treadmill stop after couple of minutes
7 amps wth no load is kind of high for this.. be looking at the surface that the belt is on.. and the rollers for excess drag..this should completely freewheel when no one is on it..
Jan 19, 2014 | Reebok Exercise & Fitness
The treadmill will start and then stop
(do not delete) utube.png do the same with the rollers bearings too.
God bless you
Jan 24, 2013 | Reebok 8400C Treadmill Motor Control Board
My tread mill stop working i have green light in the electonic board 5 small light not on
You need a new controller board. You can check your manual for how to order replacement parts. It will not be available on the New Balance website. It will actually be from an off-brand treadmill manufacturer that made the treadmill for New Balance.
Oct 22, 2012 | New Balance Balance 1500 Treadmill
God bless you
Oct 14, 2012 | Reebok 8400C Treadmill Motor Control Board
Two lines appear on the console screen and incline starts going up, then when key is removed all lights go on but nothing works.
I assume you are talking about the safety key. It should have a string attached to it and a clip on the other end of the key's string.
The key is a safety feature and the key should be in the control panel and the clip attached to your shorts or shirt when you are using the treadmill. If you fall of the treadmill, the clip pulls the string and the key is pulled from the panel on the treadmill. This should stop the treadmill instantly by cutting main power to the unit. Main power is shut off because the key is a safety device and it MUST work every time. To help avoid design errors or unreliable stops when the key is pulled, a good designer will shut everything off, not just the motor for the tread belt. I would say your unit was designed by a good design team since everthing goes off when the key is pulled.
From my point of view, it is working as designed unless you are talking about a different key.
I know someone who did not wear their safety key and they slipped on the treadmill, the treadmill threw them into the wall behind the unit and they were stuck with their leg against the treadmill. The belt on the treadmill wore their skin down to the bone on their knee in only a few seconds. Lesson one, keep your treadmill at least 3 feet from the wall. Lesson 2, use the safety key and clip.
-Mark
Jul 17, 2011 | Reebok V 680 Treadmill
Reebok RX100 won't work right
Sounds like you could possibly have a bad drive motor or something is wedged into the walk belt somewhere keeping it from turning. Check this out. One more question. How long does the walk belt turn for, seconds, before it stops. Is it like 3 to 5 seconds or less than that.
Jun 29, 2009 | Reebok Rt1000 Treadmill Walking Belt
Reebok Vista Treadmill issue
Have a 2 year old Reebok treadmill. Control panel was replaced right after we bought it. Now, again, the upper half of the panel works but we are not allowed to start anything. Does the whole panel need to be replaced again or is there a fuse or something small that we can do.
Jun 07, 2009 | Reebok Vista Treadmill - RBTL13305
Reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
May 28, 2009 | Reebok Vista Treadmill - RBTL13305
Exercise & Fitness Logo
83 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
