Question about Microwave Ovens
Flavour wave oven does not turn on & it was used 1 day ago & was fine.
    Top Expert:
  • Microwave Ovens Master
  • 39,149 Answers
Could be an open internal fuse or possibly failure of the door interlock. Less likely would be control board failure.
Posted on Dec 27, 2016
How do I set the clock on the kenmore brew wave
To set the clock:
Find the OPTION button, it is the second top button to the left of the green clock display
1 - Press OPTION
2- Press 1 (to set the time)
3- Press the numbers for the current time of day - then press START (ie: 130 for 1:30 )
4- Press 1 for AM / 2 for PM
5- Time is set !
Jul 10, 2014 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
I bought the microwave brand new two years ago. It always had one or two problems. The problem I am currently struggling with is that we you want to microwave or defrost for more than 1 minute, the counter...
-Base on my experience. These days microwaves are cheap. I Prefer to buy new one instead buy replacement parts , end up 30-50 dollars but it still not work properly.
-Good luck
Mai
Dec 22, 2017 | AEG MCD3534EM Stainless Steel 900 Watts...
Oven stopped working except for the "express" button.
hello,
what is indicate i that there is a form of disconnection or loose of wire from the connection on the element i.e the heater it is silver in colour
what you have to do to fix up wave back to function is to (unscrew)open the wave then trace the wire down to the element to fine the loose wire then connecte it back to the element and then make sure there is no form of dirt or liquid form on the panel of the wave couple it back with this the problem is solve .
please when doing this put off all power supply connected to the wave.
than you and thanks for using fixa.
Jun 14, 2010 | GE Advantium SCA1001SS Convection /...
Won't heat
hello,
what you need to no is that the problem can be from three place 1) from the connection 2) from the element 3)and from the power supply
solution to problem one, unscrew your wave and then trace the wire down to the element were is connected to,to see if there is any form of disconnection if there is you can do the fixing by setting up the wire back to it position but if there is no form of disconnection .
then this mean that your wave element is weak it will need a replacement
while the last of it is the power supply box make sure that is in it best position
if all these can be put in there position your wave will work out fine again
please rate this
Good luck and thanks for using fixya.
May 27, 2010 | Magic Chef MCD1311ST Microwave Oven
Micro is turning on ok and working but not heating up,what would cause that? light is on ok and plate is turning, just not heating
How old is your m wave? Sounds like you need to replace it .You can get a new one from Wal mart for under 75.00.and that will get you the big 1 sq.ft one..I once broke the plate in my m/wave and believe it or not they wanted more for the new plate than I paid for the M/wave BEFORE you do that check your power level settings perhaps it was turned down
Jan 28, 2010 | Sanyo EM-G2585W Microwave Oven
My spacemaker GE 1440 do not heat it 2 years old
Hi tony,
The units magnetron(the device that generates the micro waves) is failed or failing, this can be DIY depending on how mechanically inclined you are.
anaanymous
Oct 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Buzzing Microwave
the buzzing is the magnatron tube juicing too thousands of volts before emmitting the micro-wave radiation to what your cooking that turns molecules 180 degrees around... guess that friction is what really heats it.
radar ovens is what they use to call em and even people would stand in front of big ones to warm up long ago...lol canibles will love that.
Jan 11, 2008 | Panasonic NN-T990SA Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
