Question about Wireless keyboard Computers & Internet
How do I hook up my wireless keyboard to an H50gbd hisense tv? I plugged in the usb device for the keyboard but nothing happens. I want to use it for the youtube feature.
  • 171 Answers
SOURCE: wireless mouse and keyboard
Push the connect button on the wireless base, then push the connect button on the keyboard or mouse, that is supposed to reconnect the device. Make sure the wireless base is close enough to the keyboard.mouse, and nothing metal is blocking the path between the keyboard/mouse and the base.
Posted on Jan 27, 2008
  • 8637 Answers
SOURCE: dell wireless keyboard and mouse will not work
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructiond.
Hope this helps. Bud
Posted on Jan 21, 2009
  • 6 Answers
SOURCE: How to fix a usb composite device?
This device isn't supposed to need any drivers or other software under Windows XP (or Vista).  These operating systems are sophisticated enough to recognize more than one "composite USB device," even when shown as being at the same "location."  The location almost certainly refers to the USB hub, which has two or more USB ports.
Which means only three common causes for your problem:
1.  the hardware doesn't work.  You might try plugging the keyboard unit into someone else's computer.
2.  These software packages won't work with this device.  The unit ships with a specific package in Europe, Cubase LE 4 from Steinberg.  You might have better results with this software.  More immediately, if the hardware and computer are working, you should be able to use the Windows built-in program, Sound Recorder.  From Start -->  Programs --> Accessories --> Entertainment --> Sound Recorder.  From this program select Edit --> Audio Properties.  You may need to specify your keyboard as the default MIDI device (and doing so might fix your troubles).
3.  The device possibly needs to be enabled in Device Manager  (Start -->  Settings --> Control Panel --> System -->  Hardware --> Device Manager --> Sound+Video+Game Controllers).  You can also get to these settings from Control Panel --> Sounds+Multimedia -->  Hardware.
I think it's very unlikely that you need to mess with memory allocation, as someone else suggested.
Posted on Jun 14, 2009
  • 542 Answers
SOURCE: Dynex Multimedia Keyboard not working
Check and install drivers for your multimedia keyboard which is came along with the Keyboard. Also check whether the USB drivers has been installed properly and check the status of the same.
Revert back for more assistance. Also give your valuabale feedback/rating on the same.
Posted on Feb 07, 2010
SOURCE: I have a duracell usb memory device, but when I
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Posted on Mar 04, 2010
I'm trying to sign in to the facebook app on my celcus smart tv but there doesn't seen to be a keyboard to do this :/ any help would be greatly appreciated
Try plugging in your computer keyboard if it is USB. Some devices will respond to computer keyboard. Don't worry about shutting off the computer. USB is "plug and play". TV should have usb ports. When done with the TV, simply unplug the kb. Plug back into computer, nothing to reset. Nothing to Reboot.
Dec 31, 2014 | Celcus Televison & Video
The keyboard is not working. Nothing comes out
I don't know your level of technical experience, so some of these may seem obvious. These may not be in the best order, I've added them as I thought of them.
1) check the batteries in the keyboard and mouse. They can go through batteries in a big hurry sometimes. If just changed double check polarity.
2) check the connection(s) for the receiver. If you have pets check for chewed wires.
3) have you added any new USB devices. They may be using to much power from your USB ports
4) have you added any other wireless devices, includes non-computer devices.
5) have you tried resetting the keyboard and receiver signal.
6) check USB power output. You can plug in a different USB device and see if it works.
7) does your receiver require batteries (very rare).
8) you may need to reinstall your keyboard drivers and software.
Most wireless keyboards operate in the 400 Mhz range so do most wireless networks and many phones, these can all interfer with your signal.
Jun 30, 2010 | Microsoft Wireless Optical Desktop 1000...
Microsoft wireless comfort keyboard model 1027 does not work, but the mouse does work. Nothing happens: batteries are new and in properly and contacts are clean
Try resetting the board unplug the usb plug to the wireless device then turn the keyboard over and press the small button on the back of the key board with a paper clip or ink pen, then the light on the device will light up next do the same thing to the mouse some have numbers of the wireless device like 123 others have letters on them like mine A 1 F let me know if you need help.
Jan 19, 2010 | Microsoft DA900013 Keyboard
GE Wireless "Malfunction" "Unknown Device"
Does the mouse and/or keyboard have a "connect" button on the bottom of either? Try restarting your PC, then, if you have installed new batteries, and the mouse/keyboard is still not connected, try the "Connect" button if any.
Jan 01, 2010 | GE Wireless Optical Mouse
Microsoft Notebook optical mouse 3000 not working
Have you tried changing the port in which the USB wireless receiver is plugged?
Or is the receiver internal to the notebook?
If the receiver is internal, try updating the drivers for your machine by navigating to the manufacturer's support site.
If you plug a wired mouse into the machine what happens? If you get the same result, it may indicate a problem with the USB settings on your machine. I would, again, suggest updating the drivers for your machine.
If that's the case, try plugging another USB device into the machine and see if it works properly.
If none of those options provide results, I recommend you return the mouse for a refund or a replacement, especially if you have the receipt.
I hope I was able to help you. Good luck!
Aug 08, 2009 | Microsoft Wireless Notebook Optical Mouse...
Wireless keyboard won't work
Check the cabling from transmitter unit to the back of your pc, unplug and plug the cable back in, perhaps to another USB port. When you do the connect button I have always down the transmitter first and then the device, like they keyboard or mouse. Make sure the batteries you used work. If you have another computer you could try it as a test.
Jan 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
I'm hooking up my Memorex wireless keyboard and mouse. I hooked up the two pieces coming off the wireless receptor to the computer and now I can't get the mouse and keyboard to work. Do I press the button...
There should be a connect button on both the receiver unit that is plugged into the usb port, and on each device (Mouse, and Keyboard) you will have to press all of these again to reconnect the devices to the computer.
Apr 23, 2008 | Computers & Internet
Wireless keyboard stopped connecting to receiver
Im sorry but you are going to have to phone and tell the device manager the problem again otherwise get a refund and go with the wired keyboards!
Hope this helps - JoshHoward
Feb 02, 2008 | Logitech Deluxe Access Keyboard
Wireless mouse and keyboard
Jan 25, 2008 | Labtec Wireless Desktop Keyboard/Mouse...
Computers & Internet Logo
53 people viewed this question
Top Wireless keyboard Computers & Internet Experts
Level 1 Expert
L Vincent Testa
L Vincent Testa
Donald Pera Deane
Donald Pera Deane
Are you a Wireless keyboard Computer and Internet Expert? Answer questions, earn points and help others
