Question about Crock Pots & Slow Cookers
My pressure cooker lights up sets time pressure mode goes on,but aint working????advice
My power XL pressure cooker will power up, but you can't set the time for food; the display stays on zeros What can I do?
This is an indication that the keypad is not working and that could mean the controller is bad. If it is out of warranty, it is time to replace it Customer Service Power Pressure Cooker XL
Feb 18, 2018 | Crock Pots & Slow Cookers
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
I have an electric ultrex pressure cooker. What temperature should I set it to cook a 4.25 pounds corned beef
It goes by minutes under steam pressure. You likely will need about 1 hours in the pressure cooker to make it tender.
Mar 16, 2017 | Ultrex Crock Pots & Slow Cookers
How can I purchase a manual for a Innova pressure cooker model number 42008
You don't have to buy it. You can download the INNOVA pressure cooker manual from here, for free!
http://www.hippressurecooking.com/fagor-innovain-pressure-cooker-manual/
Oct 19, 2014 | Crock Pots & Slow Cookers
Se e4 on my cooker what do i do
The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
Living well pressure cooker displays red screen and F4
the digital lights on the Wolfgang Puck pressure cooker do not work. How do I repair? Thank you.
May 06, 2012 | Wolfgang Puck 5-Quart Electronic Pressure...
When you set the cook time it goes to warm will it change after it warms up
with this slow cooker it is automatic for temp settings you set the time and the rest is automatic, 1-6 ohurs starts on low and 7 and above start on high it worked out great
Nov 06, 2009 | CorningWare K4903 Slow Cooker
Ultrex pressure cooker model innova 14240
Pressure cookers are only slightly more complicated than crock pots. In fact, you can think of them as the opposite of Crock pots. Where a crock pot needs 2-3 times as long to cook something, the pressure cooker needs only 1/2 to 1/3 of the time.
These are not that complicated and haven't changed in the last 50 years. The only real hard part is being sure is doesn't explode; not that hard: don't cook things that would foam, like pasta or potatoes. Just read some recipes on the internet or get a recipe book at a bookstore, used book store (super-cheap)or the library. My best advice is to make sure you use the lowest possible heat that still allows steam to escape at a whisper. That will keep things from burning (or scorching) on the bottom, which can give a harsh taste and make clean-up more work. Just do it.
Jul 20, 2008 | Ultrex 2-in-1 (9qt) 8-Quart
Crock Pots & Slow Cookers Logo
47 people viewed this question
Top Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
