Question about Acer Aspire 5500 5570-2609 Laptop
STATUS KEEPS SHOWING "CONFIGURE THE BLUETOOTH DEVICE FOR THIS COMPUTER" THOUGH THE BLUETOOTH IS WORKING OK WITH NOKIA PHONE PC SUITE
Latest softwear Version for Nokia 5220
JUST CONNECT YOUR PHONE TO PC WHICH HAS INTERNET AND USE PC SUITE TO CHECK FOR SOFTWARE UPDATES....
Oct 23, 2011 | Nokia 5220 XpressMusic Cellular Phone
I have a hp laptop nx7300 with windows 7 installed. Whenever i tried to access internet through my nokia ovi suite it shows bluetooth peripheral device driver not found .wht can i do in this case???
Please uninstall Nokia PC suite from your computer control panel. Then download and install Nokia PC suite from link http://nds1.nokia.com/files/support/global/phones/software/Nokia_PC_Suite_eng_web.exe
Jun 07, 2011 | Computers & Internet
My set model: nokia n95 8gb Problem: my bluetooth device does not work from when i install bluetooth hacker. I delete this now. *#2820# shows no bluetooth address. Now what should i do?
back up all your files using Nokia PC Suite
make sure all info has been back up before doing this
reset your device using *#7370# to factory defaults enter the security code if you have one.
the default code is 1234 or 12345
it will restart
after the restart check if your bluetooth is working thenyou can restore all your files using the PC suite
Sep 06, 2010 | Cell Phones
My nokia 6600i is not recognizing the usb wire when connected to the computer and when connecting the headset it keeps showing the usb wire icon for some minutes and then asks to connect the device. I...
Hi, if you want your PC to recognize the phone your using, you will need to install a nokia connectivity first before install nokia pc suite.
Nokia connectivity is a driver that makes your PC to recognize the phone when connected.
When you install the nokia connectivity, install nokia pc suite, and then try it out again. am sure it will work.
Note:Hope the cables are ok.
Take care.
Jun 21, 2010 | Nokia 6600i Slide Cell Phone
Want to TRANSFER PICS FROM NOKIA PHONE TO VAIOPCG7154M VIA BLUETOOTH. NOT HAPPENING.
install latest nokia pc suite version in your vaio you will get it from nokia site www.nokia.co.uk after downloading install it swtich on the bluetooth in your vaio and run the pc suite application keep your phones bluethooth on pc suite automatically traces the phone once it get connected it will as for passcode enter 123 from your pc and enter 123 from your mobile too . then go to my computer click on nokia browser from their chose your image folder transfer the file from phone to vaio via bluetooth and and you can also transfer from vaio to nokia phone also
Oct 17, 2009 | Nokia 6300 Cellular Phone
I use my nokia N70 for connecting my pc to internet.I connect my phone through both bluetooth and usb.I connect to internet using one touch access.I had no problems at all in the past.But recently i have...
We want to change the properties for our connection to the internet. This is the adapter we want to share "from". Just right-click in the corresponding icon and select Properties.
The Bluetooth Network adapter was automatically created during the Bluetooth installation.
There's a bug in Windows 2000 before SP3 where changing the sharing option may change IP configurations in this adapter. To make sure you're safe, we will note the current configuration.
In the General tab select the Internet Protocol components and click Properties.
Write down all the information from the next dialog, and click Cancel.
Back in the Adapter properties, select the "Sharing" tab and tick "Enable Internet Connection Sharing for this connection".
Now, to configure the Bluetooth USB, right- click the Bluetooth icon in the system tray and select Advanced Configuration.
Change to the Local Services tab and double click "Network Access".
Change the type of service to "Allow other devices to acces the Internet/LAN via this computer".
The alternative to this option will allow your device to connect to your computer as part of a LAN, but will not have internet access.
Note the Configure Connection Sharing button: it'll open the configuration screens we've visited before. But some Bluetooth software will not have this button, hence I guided you through the other route .
Now, on your Pocket PC... Tap the Bluetooth icon the the status bar and select Bluetooth Manager.
You'll see your notebook or desktop here, and if it's out of range a question mark (like in the mobile icon in the picture).
Tap the icon corresponding to your computer or notebook.
If the computer does not show here, the devices are not paired! Go back and pair then.
Tap the Actions menu option.
Tap the "Connect to Network Access" option.
If all is ok, you'll see the message "Connected for Network Access" here !
Just start using your favorite programs... ICQ, Pocket Outlook, MSN Messenge, Pocket Internet Explorer .
Yes, visit the Geekzone mobile, or browse the internet from the sofa...
"Hmmm, what's on the movies tonight?"
If you tap the Bluetooth icon in the status bar again...
You'll see the computer or notebook is connected .
To disconnect, simply tap the connection icon in the status bar, and tap the Disconnect button.
And this is the result of disconnecting...
To check your connection from the desktop or notebook, double-click My Bluetooth Places, and open My Device.
The icon in green show which Bluetooth profile is in use right now. Right-click My Network Access, and select Properties to see its current status.
That's it!
Jun 22, 2009 | Nokia N70 Cellular Phone
Nokia pc suite
Uninstall every BT software you have and any Nokia PC Suite software you have. Plug in your BT phone dongle and let windows auto recognize the device. after it is done installing, then put in the Nokia cd. Do it in this order.
Nov 11, 2008 | Nokia E71 Smartphone
Acer Aspire 5500 5570-2609 Laptop Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
