Question about Amana Washing Machines
My Amana Tandem 7300 front load washer won't spin properly it goes slow, I pulled and cleaned drain screen underneath and still does this! It shuts down door lock engaged flashes 3 green-2 green?
4 Suggested Answers
richroth
  • 9472 Answers
SOURCE: amana tandem 7300 stopped ,door is locked wash
Door won't unlock
Did all of the water drain out of the washer during the spin? Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on? Press START/PAUSE once. The door will unlock.
Posted on Nov 28, 2010
tbirdfan1
  • 3051 Answers
SOURCE: amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked. The nd error code indicates "no drain". If the unit can't drain it won't spin. You're going to have to slide the washer out far enough to remove the rear panel; be careful not to damage the floor. Once you get the rear panel off you will see the pump. Be sure to have plenty of towels & a small container to catch water. I am sending you instructions from the service manual to remove and replace the pump. Another possibility is the drain line is blocked or something is stuck in the tub to pump hose.
Posted on Nov 05, 2011
  • 92 Answers
SOURCE: My Amana Tandem 7300 front load...When I throw
Had a similar problem with a front loader of a different brand. The latch mechanism was worn. Fixed that, fixed the problem.
Posted on Aug 04, 2014
Amana tandem 7300 washer hums but won't spin. Stopped with clothes and water in it.
If you would drain the water out with a hose (siphon it out) and remove the wet clothes, then look underneath the machine and see if you have a drive fan-belt, you may find it broken or slipping.
A very few machines have a drive shaft with a coupling instead.
God bless your efforts.
Jan 02, 2017 | Amana Washing Machines
Why is my Amanda 7300 tandem washing machine not doing the wash cycle? It stops after water has filled and stats to beep 3 times in intervals....
Sometimes this can happen when the power button does not return completely when pressed in. My cheap & cheerful solution was to use a bit of Blu-Tak on the button, so I could pull it all the way out.
Sep 23, 2016 | Amana Tandem 7300 Washer and Dryer Stack...
My Amana tandem 7300 front load dryer was making
could be that the belt has come off of is jammed take the back off if it come off and take a look or turn on it side and look under it could also me a wight has come off and jammed
Oct 12, 2014 | Washing Machines
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
Large loads won't balance & spin
Could be:
1. Broken spring(unlikely)
2. Bad shock absorbers (maybe)
3. Broken spyder-the Inner drum part that holds the drum to the hub(kinda likely). If inner drum can be moved without outer tub also moving in tandem, then broken spyder is likely.
Good luck
Mar 06, 2018 | LG WM2301HW Front Load Washer
Amana tandem 7300 stopped ,door is locked wash light is beeping
Door won't unlock
Nov 28, 2010 | Amana Washing Machines
Spin cycle very slow
have you cleaned your pump filter? using correct detergent HE an proper atmount? all this will cause problems. IS YOUR DRAIN HOSE CLEAN?
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
206 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
