Question about Cuisinart Food Processors
I HAVE A NEW cUISINART AND WOULD LIKE TO REGISTER IT.
What to do with Cuisinart processor #dlc-2007 that was recalled
Don't use it. Contact Cuisinart and they will send you a new blade. The recall is on the blade only.
Conair retira del mercado procesadores de alimentos Cuisinart debido...
Dec 14, 2016 | Cuisinart Food Processors
Need circuit board for DLC 8-PLUS
Rather than replace the circuit board, you might consider going on Ebay and just buy a used replacement base. I got one a few months ago on Ebay at a fraction of the cost of buying a new food processor. Cuisinart parts are popular on Ebay.
Apr 24, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Plastic piece broken on lid
Cuisinart has the part - you can order it from Cuisinart's website - www.cuisinart.com or call them directly at 1-800-726-0290
Feb 11, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Replace the spindle on Cuisinart DLC-7 Food Processor
You need to pull the old one off, probably with vise grips and a lot of effort, and then order a new one. The new one is a tiny bit larger, so you'll probably need to order new blades, too. The new one slips right on, so there's no issue that would be the reverse of removing the old one. I read somewhere else that you have to pound hard to get the new one on, but that guy must have been speaking about the older model spindles. I was perplexed that the new one slipped right on so I pounded it to be sure and ended up breaking the tip of the new spindle and cracking the housing of the whole processor.
Jan 05, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Plastic bowl of Cuisinart DLC-7P will no longer lock in place
Buy replacement plastic bowl of Cuisinart DLC-7P is Cuisinart DLC-005AGTX-1 work bowl 14 cup.
Jul 15, 2008 | Cuisinart DLC-5 Food Processor
My food processor plastic container has never slipped on and off with ease i have to smash it into place and the double smash the handle to remove it from the base. I would like to get a new upper...
You can get a completely new work bowl set (not the original parts) from Cuisinart for around $118.00. You could also buy one from a shady eBay seller and see if the oldie works. I am a collector of these myself, but in reality, it is probably cheaper to get a new Cuisinart food processor - they are nearly as good as the old ones.
-Tha Mp3 Doctor
Jul 02, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Install Cuisinart stem cover
I was able to replace my pieces thru Small appliance.com I ordered new parts and the directions on how to remove the old stem and put the new one on.
Put a little vaseline in the rim of the new stem. Use a wooden block and a hammer or rubber mallet and lightly tap the new one into place.
Cuisinart called two weeks after the fact to say I have to send them the machine.....
Oct 17, 2007 | Cuisinart DLC-10S Pro Classic Food...
Food Processors Logo
64 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
