Question about Hilti Drills
How to remove Hilti DD130 chuck. - Hilti Drills
  • 61 Answers
SOURCE: HAVING A PROBLEM WITH MY HILTI TE5 HAMMER
the bearing in the chuck is probly missing. replace the ball baering.
Posted on Oct 11, 2009
  • 61 Answers
SOURCE: Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
Posted on Jun 06, 2010
SOURCE: The chuck on my old Hilti TE 60 is stripped.
If you can t find the cap nut, drill 2 small holes on either side, tap the holes and put in 2 set screws to hold it in place
Posted on Jun 11, 2010
  • 8404 Answers
SOURCE: how do you remove the bit from the chuck of a TE
Slide the collar on the chuck to the rear (toward the handle)
Posted on Nov 22, 2010
  • 123 Answers
SOURCE: I need to remove the chuck assembly from Hilti
With the palm of your hand over the chuck where the bit goes in take your fingers and pull the black sleeve right at the drill casing and pull towards your palm. After you have pulled it all the way back just pull the whole chuck off.
Posted on Feb 07, 2011
Hilti chuck won't turn
inside the chuck you will see a screw, remove the screw and chuck . A small punch with minimum forced with a small hammer to move the chuck dogs toward the end on the chuck . The chuck was opened to far and is a mechanical bind ..
Jun 30, 2012 | Hilti SFH 18A CPC Hammer DrillDriver
How do I straighten a chuck bend off removing a jammed bit?
If this is a TE7 then the chuck will just pop off of the front end. You just pull the rear chuck sleeve foward to release the chuck. With the chuck off run the drill to see if the cylinder is bent. If you bent the cylinder it will wobble. If the cylinder is okay just order a new chuck. If the cylinder is bent then your best choice is to send it to Hilti and have it repaired by them. They have a ceiling on the amount the repair would be and you would get a warranty with the repair. It would be cheaper than you trying to buy the cylinder and replacing it yourself.
Hilti 1-800-879-8000
Glenn
Nov 11, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Need a new chuck for a tm8 hilti drill
The TM8 was only manufactured from 1984-1986. Parts have not been available in around 15 years. The TM8 had HIlti's version of the Joacob's chuck. It tightened the opposite way from a standard chuck. It had a tendency to fall apart and come off.Hilti revised the chuck two to three times but eventually did away with it after three years.
You might be able to find one on Ebay.
Sep 18, 2011 | Hilti Drills
Chuck fell off!
You did not state which model you had but normally on Hilti drills with a removable chuck you just put the nose of the chuck in the palm of your hand. Take your fingers and pull back the sleeve. Slide it back on the guide tube and then turn it until it catches. If that does not work then something is wrong with your chuck.
Nov 14, 2010 | Hilti Drills
How do i replace the jacob chuck on a hilti hammer drill?
Open the jaws of the chuck all the way open. Inside the chuck you will see a slotted screw. Use a large flat head screw driver and remove screw. It will have left handed threads.
After you remove the screw put the end of the chuck in a vise where the 6 flats sides are. Put the drill in low gear and reverse. Hold tight and turn on the drill. This should run the chuck right off the spindle.
Jun 28, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
May 05, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Hilti DD130 Core Drill gearbox Lubrication
Hi
220ml of synthetic 68 gear oil.
Hope this helps
Nov 28, 2009 | Hilti 3431126 SF 144-A CPC Drill/Driver
Hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Jul 20, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Drills Logo
61 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
