Have tau 1080i bbe digital it's not showing full picture on screen eg watching Boxing Day test cricket and the you can just see at bottom of picture a third of the height of score,help me.Ta??
SOURCE: Adjusting screen on HD TV
I had the same problem. My cable company told me to press the # button on my remote to change it from "zoom" to "normal" and it solved the problem.
Posted on Dec 19, 2007
  • 88 Answers
SOURCE: Picture Size
question how did you connect your flat TV?
if you are conected by the HDMI port you to check your resolution in your config, probably you have to decrease th resolution to 480 P or 480 I to have the totality of the screen.
the format 1080I or 1080P is for DVD player or HD decoder.
if you are connected by component cable, verify in your config menu if you can change the resolution format to 480 P or I
I hope this helps
Please rate accordingly
Thank you
Posted on May 02, 2008
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Posted on Aug 11, 2008
  • 320 Answers
SOURCE: Cannot view the full picture
First, you have to tell me how the cable box is connected to the TV, by HDMI or component. If it is connected by HDMI, the cable box settings will override the picture size settings on the TV. It may be as simple as resetting the picture size on the cable box, but I am not familiar with the type of cable boxes that Comcast uses.
Posted on Oct 19, 2008
SOURCE: Picture outside of screen limits
I have Time Warner Cable and just FIXED this problem. On the cable box remote, there is a button with the word "Aspect" on it. On my particular remote, this is the "#" button (pound symbol) and by pressing that button, it gives you options of "Zoom 1", "Zoom 2", "Stretch" and "Normal". By setting it to "Normal", it completely solved the problem. Oh and by the way, my t.v. is the LG 47" flat screen LCD. Hope this helps the other frustrated folks out there.
Posted on Jul 03, 2009
I have a Panasonic HDTV 1080i TAU BBE projection TV,I can't get a remote to work with it.
Check first to see if remote works---most shops or Radio shack have a remote tester---point remote at it and push a button and tester will indicate if remote works----some digital cameras will also work for this.
If remote is good either a problem with the remote receiver on front of set or the remote circuit inside the set.
Mar 18, 2012 | Panasonic Televison & Video
By tv is stuck on standby and now wont turn on it first started with a sound like its blinking then wouldnt turn back on plse help me
one or more lights on the front should blink an error code
Set likely has either a problem with its power supply board or something is pulling voltages there down--
Power supply board is the place to begin
Mar 16, 2012 | Panasonic Televison & Video
Some shows i don't get full screen picture about
You are watching a show or movie that was recorded in letterbox format, THIS IS NORMAL !
Jul 09, 2011 | Polaroid Televison & Video
Convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Apr 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Olevia 1080i
how do you you enlarge the picture to show on a full screen, and not black on the sides?
Dec 10, 2008 | Olevia LT42HVi 42 in. LCD Television
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
CT-F683 TV fault
Press setup on your foxtel remote, go to systems settings, and look for "TV Type" menu, you can change settings there, your TV is a 4.3 (square) not widescreen. Its not a telly problem your just giving it the wrong signal.
Feb 17, 2008 | Televison & Video
Picture size option excludes FULL at either 1080i or 540
All these Toshiba's are defective and we got scammed. Mine and others do this same exact thing. Call Toshiba support and complain to the supervisor to recall these TV's and do right by their customers.
Toshiba Customer Service Group: 800-631-3811 for more assistance.
Jul 22, 2007 | Toshiba 65H82 65" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
