Question about Bernina 1008
On my bernina 1008 the selection lever is all the way up but I want it on the straight stitch but won't move.
  • Bernina Master
  • 11,205 Answers
Are you able to remove the top cover of your 1008? The 930 has a "lid" that can be removed to access the internal mechanism. Am suspecting that perhaps the selector has seized from old oil solidifying. If able to open machine, apply 1-2 drops of liquid Tri-Flow Synthetic Lube to every place where metal rubs against metal. Do NOT oil belt or nylon gears! Be sure to move the selector dials and levers and oil those moving parts too. To help speed things up, direct hot air from a handheld hairdryer into the internal mechanics.
Posted on Dec 27, 2016
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
SOURCE: stitch is not straight
When was the last time your machine had a routine cleaning and adjustment? It sounds as though you've got "play" in the mechanism that needs to be tightened by a sewing machine mechanic.
Posted on Jun 07, 2009
  • 980 Answers
SOURCE: My Bernina 830 Sewing Machine is not sewing the
If you are selecting patterns but only getting a straight stitch after making sure you have set the width, there may be a chance that the pattern camstack has split and the selector finger is stuck in the split, more common than people think,
take the top off the machine and check
Posted on Oct 24, 2009
RickE1
  • 202 Answers
SOURCE: copy ready diagram of Bernina 1008
Not sure which diagram or scematic you want but feel free to contact me at callnrick@yahoo.com and I will reply with your need.
Posted on Jul 12, 2010
SOURCE: bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Posted on Aug 11, 2012
I cannot get the green decorative stitches to work. I'm insure if my Bernina 930 is broken or I'm just unfamiliar with this machine. How do I set my machine for the embroidery stitches?
There are 2 levers on the top that need to be set. One shows the green stitch selections. That needs to be set to your stitch choice. To its right, there is another lever called the "changeover lever." It needs to be pushed all the toward the back of the machine--that switches it from straight stitch to decorative stitch.
Then on the bottom front on the right is a large knob. Both the outer ring of the knob and the inner knob perform different functions. One drops the feed dogs for darning or raises to activate the feed dogs to pull the fabric through the machine. The other part switches between the red and green stitch selections. When that knob is turned the light should show green or red to coordinate with the stitch selection lever on the top of the machine.
So to make decorative stitches, there are 2 levers that need to be moved plus the red/green activator knob. In addition, you will want to adjust the stitch width dial and the stitch length lever to widen or lengthen the stitch.
If you need a manual for your machine, you can download it free here:
BERNINA Support Machine and Accessories Finders and Software Support...
Apr 07, 2016 | Bernina Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Bernina 530 through 830 Record Oiling Diagram
Oct 19, 2015 | Bernina Sewing Machines
What is the setting for regular straight stitching?
Stitch length @ 2.5mm (between 2 and 3 on the scale).
Stitch width @ zero.
Top selector lever @ 1 / 2 or (1 slash 2).
Needle position @ center.
That's it, no rocket science here. Stitch length will vary per application and per user choice. The 2.5 setting is only a suggested default.
Sep 22, 2015 | Bernina 1008
Why the lever won't move from straight stitch to other stitches on my bernina 801?
thats a 50 year old machine...its seizing and needs oiling and service
Sep 17, 2014 | Sewing Machines
Bernina 1030 needle not moving up or down
I believe the 1030 has a basting stitch, similar to the 930 Record. If the basting stitch is not run regularly, it may lock up the machine requiring a technician's expertise to get it working again.
Mar 31, 2013 | Bernina 1008
Bernina 1008 troubleshooting
the best thing to do is have the machine serviced at a sewing machine
shop
May 05, 2012 | Bernina 1008
I would like to set my bernina 1008 to a freehand setting but d not have the manal i would like ot know what control to have on which setting to make this work
You have to lower the feed dogs and use a darning foot. Use straight stitch setting.
If you cannot lower the feed dogs, this model may use a cover plate.
You can also set the stitch length to zero and tape an index card over the feed dogs with a small opening for the needle.
You will be controlling the stitch length as you move the fabric by hand.
Mar 01, 2010 | Bernina 1008
My 1008 bernina sounds like it is straining to
Your machine needs to be serviced. Take it to an authorized Bernina service person.
Feb 17, 2010 | Bernina 1008
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
