Question about Simmons Rocker Recliner
The lever is too hard for me to push and pull
I just bought a new recliner, simmons Victor 588. Is there a way to make the lever easier to push and pull?
2 Suggested Answers
I would contact the manufacturer. Maybe you should contact the manufacturer or return it where it was purchased.
Posted on Nov 30, 2012
Why is the footrest so difficult to lower?
Some recliners are just designed that way - my wife's chair is nearly impossible for me to close.
Jul 29, 2014 | Simmons Apollo Jumbo Cuddler Recliner
The hood lever is stuck inside the car. Tried pushing hood done etc. stuck in an outback town in NT. Need to change the dead battery!
Push hood back down hard,then pull on
hood release hard again.If not work,trace wire
inside as far as you can and get grips or pliers
and pul from as far up the line as you can.If it
opens as it should,you can easily unattache wire
from pull handle put a knot in wire,this will shorten it
so easier to undo next time.Infact you might try that first.
If none work which I doubt,get push to start and drive
to garage.LUCK
May 10, 2014 | 1999 Jeep Cherokee 4WD
Recliner sofa won't recline
Try looking next to your seat cover and the arm rest for a little pull handle. If it is a pushback recline model tried looking to see if the shipping ties are untied underneath. Or try simply pushing back while you're sitting in it with your shoulders.
Mar 18, 2014 | Furniture
Simmons rocker recliner footrest spring placement
my spring on my footrest on my simmons recliner broke,when I replace it, where does it connect on the chair ?
Oct 24, 2013 | Simmons Rocker Recliner
Bought a Collins power recliner by home meridian from samsclub that has only half of the power supply. (It was on clearance) Where can I find a replacement power supply for it? I have searched everywh
try I bought a new motor and button from them. They have parts for many makes and models. I took old assy apart and found it was a defect in the wire between motor and push button. I drew a schematic of mine here is the drawing.d5ed86f4-7c9d-4a33-8615-2eb2c5fa16f7.jpg
Apr 17, 2013 | Home Meridian Fletcher Power Recliner
Nov 30, 2012 | Simmons Rocker Recliner
Hi, I can't recline the I coo Pacific stroller, the push button is too hard. I bought the stroller three months ago, so it's still new!! Thank you!
I also had trouble with this but I found if I pulled it up a little before pushing the button it would work and then after doing it several times it gave a little and it didn't need to it anymore x
Jan 08, 2011 | i'coo Pacific Stroller Stone Strollers
How do you change the low beam bulb on a 2001 vw beetle?
It's easy, under the hood on the headlight casing is a lever like thing, (careful it is fragile) pull the lever up or down (can't remember). There is a notch under the lever that needs to be pushed in to 'release' the lever. Push the entire headlight casing out toward the front of the car. (The casing will hang over your bumper) Pull out the headlight and plug the new one in. Push the casing back in and lock the casing in with the lever. One note, there is some really sticky adhesive holding the light in, so you may have to push/pull hard to get it to slide out. I find that using WD40 on the tracks helps it to slide easier. You will have to use a screwdriver (or the like) covered by a rag to pry the light out.
Dec 27, 2009 | 2001 Volkswagen Beetle
Britax Roundabout
its easier to do while its buckled in or someone is holding the base....
Apr 17, 2007 | Britax Roundabout
Simmons Rocker Recliner Logo
174 people viewed this question
Top Simmons Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Simmons Furniture Expert? Answer questions, earn points and help others
