6300 squeaks when printing or scanning, is this a known problem?
Why printer squeaks
There are several moving parts inside the printer. more in a color laser printer.
Generally if you have used a refilled toner recently (any color or black), the chances are that the wiper blade in NOT seated properly inside the toner or reversed.
Try the following steps.
1. Set known set of good toner (even if nesrly empty)
2. Perform self test
3. Replace one old toner with new set corresponding color and eliminate which toner causes the squeak..
4. Mark that toner defective and Return.
5. If that is not feasible, try to forcefully rotate the drum in the opposite direction to see if helps flip the rubber blade in place
6. I will not suggest you to open the toner as it can damage the drum, spill toner and lead to you bigger mess.
7. If it is not due to toner, then the culprit is in the several gear trains inside the printer and that can be tricky to solve.
Sep 06, 2016 | HP Color LaserJet Pro 200 M276nw
Canon pc-921 squeaking noise
1- might be the scanning rail -- if you can open and lube LIGHTLY slide scanner back and forth ( w power off)
2- caould be Drum, some make a whistling/ hollow sound
Sep 05, 2012 | Canon PC-921 Black and White Copier
Xerox 6360dn, Tray 2 makes loud grinding noise when printing. Tray 1 is as quiet as a mouse. Replaced tray 2 with a known good tray and it still makes grinding noise.
In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
Oct 18, 2010 | Xerox Phaser 6360DN Printer
Xerox 6250 squeaks when printing
The image unit 108R00591 is known to squeak.
You can also isolate the motors in diags. (Power-on the machine holding the back arrow and the "i" button and scroll to Motors) If any of them squeak then you have another suspect.
Jul 20, 2010 | Xerox Phaser 6250N Printer
6300 camera open to mpbile hang and restart plz help
its internal memory problem or scan ur mobile by some good antivirus or ur software need to be updated firstly scan ur mobile then go for update
Mar 22, 2010 | Nokia 6300 Cellular Phone
Nokia 6300 unlock code
Nokia 6300 have a special chip in them, known as BB5. This means the only way to get an unlock code is by calling your network and asking them for it. They may charge you for the code.
Jul 25, 2009 | Nokia 6030 Cellular Phone
How to unlock nokia 6300.
Jul 16, 2009 | Nokia 6300 Cellular Phone
Restriction code
Sorry but Nokia 6300 have a special chip in them, known as BB5. This means the only way to get an unlock code is by calling your network and asking them for it. They may charge you for the code. Good Luck,
-WN
May 15, 2008 | Nokia 6300 Cellular Phone
"Scanning in progress" reported even when I'm not scanning anything
You need to install the print driver and Sharpdesk before you connect the USB cable.
Dec 10, 2007 | Sharp AL-1642CS Copier
23 people viewed this question
jasbo
jasbo
