Question about Garden
Why cant i get this 826 le powermax to prime? i cleaned the carb and ajr tested the lines its just not gettting the suction
  • 113 Answers
SOURCE: engine starts when I hand prime it,but not when I use prime bulb.
There are two screws on the carb. 1 is Lo rpm air/fuel ratio and the other is hi rpm. Try adjusting the lo rpm screw counter-clockwize a 1/2 turn at first, more if needed. After each adjustment try to start. The other thing you could check is if the float is sticking in the bottom of the carb. which shuts off gas flow if full. There is a screw on the bottom of the carb to drain that float. You can try that also! Good luck man!
Posted on Sep 21, 2009
suzukiracing
  • 200 Answers
SOURCE: Craftsman weed trimmer primer bulb is working in reverse
Make sure the line is near the botto ofthe tank.Thanks you for asking and I hope it helps.Please leave me a 4 thumbs up.
Posted on Jul 20, 2010
SOURCE: primer bulb on weedeater won't prime
when you prime the bulb it sucks gas from the tank with the small tube, any excess gassed pumped will be fed back to the carb via the big tube leading to the tank. If you prime it and the bulb stays pushed down, then you have a clog or kink. To fix , pull the small tube out of the tank through the fill hole. Pull off the filter on the end and put the tube back in the tank. If it primes, your fuel filter was clogged. If it still wont prime check the hose going to the carb and make sure isnt clogged or kinked.(take of carb and blow in it). If that doesnt fix it take off the bulb from the carb with two screws. The bulb assembly will come off too(rectange metal thing) Take off the two black gaskets, be carefull with them. Take off hoses from carb and bulb asembly. Blow carb cleaner in all holes and over surface. Put back together.
If the carb wont prime and the bulb isnt staying depressed. then you might have a bad bulb or carb gaskets. Make sure hoses are not cracked, cloged, or pinched.
Posted on May 29, 2012
steves_here
  • 1692 Answers
SOURCE: Echo trimmer , new carb , good spark, cleand fuel filter, new fuel, new fuel lines, cleaned spark arrestor,primed and pull , no gas getting to the plug.compression test? What pulls the fuel? Intake?
Hi Ralph, Seems like the problem is where the float and needle meet, The float, needle and seat let the gas into the bottom of the carby and as the gas rises the float rises as well pushing the needle up into the seat slowing the gas flow into the bottom of the carby.... As the motor's using the gas in the bottom of the carby the float's lowering and the needle lowers as well allowing gas into the
carby, If the needle is stuck inside the seat then NO gas will be let into the bottom of the carby so check that by pushing up and down the float to see if the needle moves up and down if not just pull the needle down with your fingers.... OH AND YOU MIGHT NEED
TO CHECK THE PART OF THE FLOAT THAT TOUCHES THE NEEDLE.... I hope you know what I mean....CHEERS..
Posted on Apr 22, 2016
  • 2559 Answers
SOURCE: Trimmer won't prime to start
Look inside the tank. Some units have a stone inside that blocks the fuel line when it is tipped a certain way. Might be what's happening here.
Posted on Aug 13, 2016
Priming echo BP251 liaf blower
Hi Norman:
I'd check the routing of the fuel lines.
Tank to carb (this is the line with the filter on it)
carb to bulb (suction side)
bulb to tank (return line)
If the connections appear correct but it does not pull gas, check the filter to make sure it is clean, and you can try reversing the connections on the bulb.
Hope this helps.
Mar 11, 2016 | Echo Garden
Why does the carb not prime with fuel?
Check the primer bulb. If it has a small hole or leak it will not generate the suction with which to suck the gas in to them prime the engine. And make sure that the top of the carb with the bulb is firmly attached to the rest of carb to prevent any base leaks by the primer.
Sep 20, 2015 | Garden
Have huqvarna 350 it will not prime the bulb is good it check it . how can i check to see if it the carb or some other part of the fuel transfer system? when i pump i see the fuel from the carb being...
The bulb pulls fuel from the carb, if there is no fuel in the carb then it will not prime, reasons for no fuel in the carb is, blocked fuel filter in the tank, fuel hose trapped or split, internal filter in the carb, under the pump diaphram ( alloy cover on the carb held with a single screw ) blocked, you can test the primer, pull the two pipes off, the longer tube on the back of the primer should create a pressure when you press the bulb, the shorter connection should create a suction when you let go of the bulb.The suction side should be connected to the carb.
Sep 09, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Craftman blower/ changed the fuel lines/ cleaned the filters/ still no fuel in to the primer
Clean your carb and make sure your needle and seat are also clean and the screen inside carb at inlet of fuel, also the primer has a check valve inside it that gums up, try to spray carb clean or sea foams deep creep I like it seems to loosen up the check valve and remember normally fuel line with filter goes on nipple at pump side of carb and other nipple goes to suction side of primer and other nipple goes to tank as a return line ...so as you prime it, this causes fuel to be sucked thru carb and back to tank 2StrokeJim
May 18, 2011 | Craftsman 25cc Gas Line Trimmer
Didn't take the gas lines off , and I don't have a
normally the line from the tank with the filter goes to the pump nipple of the carb, then the other nipple on carb by needle/seat side goes to suction side of primer, and the other one at primer goes to gas tank. what this does it pulls fuel through the carb when you prime it, and excess goes back into tank(return line) at primer, so when you prime it you should see fuel coming out through the line that goes to tank with out filter. good luck
May 14, 2011 | Poulan Garden
Jul 19, 2010 | Craftsman 25cc Gas Line Trimmer
Replaced fuel lines now wont start dont know if lines are in correct position
make sure you prime the line with it NOT attached to carb to make sure its gettting fuel first then try to start
May 30, 2010 | Craftsman 25cc Gas Line Trimmer
Ryobi Gas trimmer fuel line routing
The fuel fillter line goes directly to the carb.inlet first
the outlet on carb.
goes to suction side of primer and outlet side of primer back to tank
primer draws fuel through carb. to prime
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My 2 stroke mantis tiller will not prime.no fuel in prime bulb. I guess no suction. Fuel lines are clear.Which parts need to be replaced?
I had the same problem, get a rebuild kit. It sounds like the diaphram is shot. Also make sure the prime bulb doesn't have any holes or cracks, the engine won't run if it does
Mar 21, 2009 | Mantis 2-Cycle Tiller
I have a Toro s 200 model 38130 1979 snowblower. it would not prime no suction when bulb pushed. I replaced the diaphragm with a kit diaphragm first to carb etc. along with new needle valve and spring. Now...
snowblower no fuel . pull float bowl from the bottom of carb the bolt you removed from the bottom to take off the float bowl there will be a small hole in it take a needle make sure to clean it out . then clean out where it threads into .
Dec 03, 2008 | Chevrolet C1500 Cars & Trucks
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
