Lg50ps70fd sound intermittently drops out for a few seconds at a time maybe every 15 to 20 minutes.It doesn't matter what type of media device is connected this happens with free to air as well.
  • 240 Answers
SOURCE: Slow printing.
flash another firmware to the printer..
it's one of the cause why printer take a late reaction t...
Posted on May 14, 2009
SOURCE: Video call through Skype drops my internet connection after 30 seconds to a few minutes- any suggestions
want software and c d
Posted on Jun 09, 2009
raygin
  • 322 Answers
SOURCE: My 2000 Jaguar S-Type High Engine Temperature
I assume the car drives okay the rest of the time at varying speeds and conditions?
It may be you have an air lock in the system (have you had work done or lost coolant?) or the sensor or its wiring is faulty.
Check the level of your coolant tank when the car is at full temp and idling - for safety - the tank is opaque you should be able to see the water level - do not open when hot !
Posted on Oct 21, 2009
  • 43 Answers
SOURCE: Neptune MD55 elec dryer chirping noise
I would think it might be the "board" but I once went on a call for the same chirp on an oven...ended up being the smoke detector was low on battery..it cost them $$ for me to find that simple thing.
Posted on Oct 24, 2009
  • 5 Answers
SOURCE: I have DSL through Qwest and can connect to the
check the configuration of the modem if you can. I do not know the exact model of the modem, could you post it? then with the exact model of the modem you could google it for a Manual, Handbook, or simply good configurations. If the configurations are good, then could be the firmware that is not updated, or in the last case ask Qwest to change your modem for one that works.
A piece of advice don't open it or modify it because you could void the warranty, in case of a change.
Hope this help you!!!
Posted on Aug 21, 2010
Every few minutes the sound drops out for a couple of seconds. Tv is a Sony and I am watching via sky
Does the TV do this no matter the video source, for instance does it do it when you watch a DVD? If the sound is steady on other video inputs then the TV is not the problem.
Jun 28, 2017 | Sony Televison & Video
Intermittent problem - speed dial 'drops out' sometimes for a few seconds, sometimes for a couple of minutes, then returns to normal operation
What year an model ford ? Electronic module clinch , lose or corroded connector or wiring , ground wiring etc... Do you know what voltage drop testing is ? Voltage drop test main battery cables , What is Voltage Drop Voltage testing fundamentals Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
watch these videos
Sep 09, 2016 | Ford Focus Cars & Trucks
LG microwave intermittently runs
I would try troubleshooting the "defrost circuit". The behavior sounds like the microwave is cooking in the defrost mode, where it actively cooks then stops allowing the food to rotate and the heat to spread then actively cooking again.
Nov 06, 2013 | Microwave Ovens
Why do my lorex cameras intermittently black out?
THIS COULD BE A FEW THINGS I CAN THINK OF
1ST ARE CAMERAS WIRELESS ? IF SO SOMETHING COULD COME ON INTERMITTANTLY AND BLOCK SIGNAL FROM GETTING TO BASE UNIT, IF THIS IS SO ONLY A SPECTRUM ANALIZER WILL BE ABLE TO TELL YOU WHAT IT IS .
SECOND IF NOT WIRELESS CK YOUR RECORD SETTINGS IN SETUP YOU MIGHT BE OVER TASKING HD DRIVE , VIDEO CAPTURE ONCE PER SECOND IS NORMAL ANY FASTER IS NOT NEEDED UNIT WON'T HOLD VIDEO IF HD IS BUSY WRITING SO IT DROPS SECONDS OFF FINAL RECORD
Jul 12, 2013 | Lorex Home Security
The gauges on my dashboard keep dropping to nothing while driving
possible short of the circuit,power steering needs compression from the engine,if the dials drop they indicate a failure or intermittent blockage,check earth connection on car to the body,make sure the right type of battery is fitted and and disconnect battery allow the car to cool down before replacing to see if a sender unit is failing every now and then
Jan 08, 2012 | Cars & Trucks
I am clearly stupid. I cannot work out how to submit my comments on the last iteraton of fixYa problem solving. I will list below the questions followed by my comments. Questions from guru: Kindly...
Patrick, look, these days one cannot realistically repair ones own TV any more, barring a few exceptions, with intermittent problems being the bane of an Engineers life. Please take my professional advise, from a 30 year veteran. Please take it to a reputable service center, Ask for a free "Quote" this way you can get an idea as to repair replace. You see, this will indeed save you Money, and time, and frustration, I assure you.
Before one can even, have a chance at a repair, you need, service manual, tools, spare parts, multimeter, a signal generator, an oscilloscope. Huge amounts of time. Also you need an understanding of how a digital TV works there days, they are nothing like the "older" ones, that maybe were able to be repaired with a little rudimentary knowledge, those days are long gone, a TV now, is a PC, and a DVR and a Digital Video processing system all in one. One must have software knowledge now as well.
Mar 27, 2010 | Televison & Video
Sony projection tv 5 years old
you will need to call an electronic repair shop to get this problem resolved
Oct 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
Sound problem
my sound device canot play sound but ican watch video but no sound when igo to contro panel and click sound the volume doesnt work if iwant put the volume up it doesnt work it just freeze so can you help me
Dec 24, 2007 | Asrock K7S41GX Motherboard
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
