Washing Machines Logo
Kim Hillery Posted on Dec 27, 2016
How do you reset washing machine, I have a ariston arxf125 washing machine it was washing one day normally next day, theres no power to it.
All power points work in laundry, have tried other appliance. I plug it in and should get all lights on, instead I get nothing
5 Related Answers
gittos73
peter gittos
  • 247 Answers
  • Posted on Aug 22, 2007
SOURCE: No power to washing machine but fuse is ok...
could be 2 things 1)try closing the door and banging the machine on the front next to where your door catch goes into the washer if it starts could have a lose wire or be faulty 2)if no1 doesnt work than it will be your mains filter which if blown power doesnt get to your machine if the machine is brand new and has manufacturers warranty then these are covered through the warranty and any tampering will void your warranty though should be covered for no less than a year
ekauffman
Elisabeth Kauffman Humphrey
  • 3 Answers
  • Posted on Mar 22, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Anonymous
  • 639 Answers
  • Posted on Aug 31, 2008
SOURCE: reset button
Friend,
ngfam1 At your service!
With an error code the only way to find to repair this is,
Try first unplugging the appliance and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!!
If not only a trained laundry tech can make the electronic diagnoses.
Like I used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I refered you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Anonymous
  • 1214 Answers
  • Posted on Jan 24, 2009
I suspect for either of these units that the timer control boards are bad.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Sep 20, 2010
SOURCE: Where is the reset button
there is no reset button, the reset for the system is to unplug it for at least 3 minutes from the wall socket, if it doesn't reset then there is a electrical failure of the central control circuit board.
WHERE ARE THE FUSE FOR ARISTON ASL75CXS NA
There is no fuse in the machine. The fuse is in the electrical panel of your home. If there is power in the outlet then the fuse is not tripped. If there is no power reset the circuit breaker or (very old) replace the fuse. Here is the link to the manual for the machine.
http://www.aristonappliances.us/_pdf/manuals/ASL75_CXS_MANUAL.pdf
Machine start normally but after some time it display H20 and stop. When i switch off the power it restart but again after few minutes it is same. Kindly help.
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Would not power up
look for a reset button but I have a feeling its inside the machine. They want you to call service. I would call their help line on that one if its free or go to where you bought it and see what they say. If all else fails, try youtube, sorry. I have an LG and there is no common stuff with anything these days
Ariston ar6f105 washin machine not working
My arxf125 is displaying the word "door"
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
8helpful
2answers
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
2answers
Ariston Washing machine A1636 - Flashing lights
what 2 lights are flashing each light that flashes gives a differant fault code . Get back to me
Top Ariston Technologies Washing Machines Experts
ZJ Limited
ZJ Limited
vince
ADMIN Andrew
ADMIN Andrew
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
