Question about Miller Welding Tools
I have a Miller blue star 3500 with electric start Honda engine.
Problem is after running for about five or six minutes engine begins shutting down with back firing and then quits. Cannot restart except after waiting for a minute then restarts and runs fine for about a minutes then shuts down, sputteter sputter, cough, backfire stops. This can go on and on over and over. When it is running top speed will weld and generate fine...just can't keep motor running. Why?This can go on and on over and over. When it is running top speed will weld and generate fine...just can't keep motor running. Why? I am original owner. Machine has been lightly used over the past several years. Machine has been garage kept.
    Habit-Forming:
  • 27 Answers
Have you stripped and cleaned out carburettor?
sounds like a blocked idle jet?
Posted on Dec 28, 2017
3 Suggested Answers
philriden
  • 146 Answers
SOURCE: Engine Quits
sounds like a tipical crankshaft position sensor will fix your car
Posted on Jan 07, 2009
  • 142 Answers
SOURCE: onan generator dies after 2-3 hours of running ,
This sounds like overheating. These small generators don't have overheating protection, but if a low oil pressure or low oil level is present it may be the reason for stopping.
Check the oil level in the starting conditions and again when it stops. It may become under the "stop" level and after some time the precipitated oil has reached the "start" level. The same may be with oil viscosity and oil pressure.
Try to add some oil or change the oil with bigger viscosity.
Posted on Jul 10, 2010
What size motor came out on the miller blue star 2e welder
Depending on serial number, Miller started out with Kohler manual start, Kohler electric start, and then Tecumseh electric start. They ended the series with a Tecumseh OH160, miller part #070732. I have included the manual. https://www.millerwelds.com/files/owners-manuals/O424E_MIL.pdf
Sep 11, 2017 | Miller Welding Tools
Blue star Cassatte AC run light blinking. After 2 minutes.
when the light of your air conditioner starts to blink, switch off the circuit breaker , it is found below the alternating current (AC) unit and switch it on after about five minutes.
Jun 26, 2017 | Star Computers & Internet
250. What causes it to run roughly and lose RPM?
The Miller 212 has a 60% duty cycle. So for every ten minutes of welding the machine is designed to weld for 6 min and cool down for 4 min.
Sep 02, 2015 | Miller Welding Tools
Starts OK but after about 15 or 20 minutes starts losing power and after moving throttle up and down for five minutes or so to keep going dies After cooling for twenty or thirty minutes will start and go...
When your ignition coil get to engine temp. it will begin to lose its power, therefore your engine will eventually shut down, when it cools it will start up again,
Good luck
Jul 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
Dryer gets hot and shuts off after five minutes,
Check your vent tube to make sure it is clear. It is probably getting to hot because there is no ventilation to the outside. When you have the front off, check all the way from the lint filter to the outsid of the house.
Mar 23, 2009 | Frigidaire FEQ332E Electric Dryer
I have a miller blue star 6000. I started it up but its not putting out any power.
By any chance has this generator been sitting for a while, or been dropped? That's a common symptom. The generator has lost its' residual magnatism. The exiter field needs to be flashed. Either follow the instructions in you user manual or see this link:
http://www.dieselduck.net/machine/03%20electricity/flashing_generator.htm
Avoid this problem in the future by running the generator with a load on it for 10 minutes or so every once in a while.
Dec 25, 2008 | Miller Blue Star 6000 Elec Start 120V DX,...
Welding Tools Logo
191 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
