Question about Drills
I need the user instructions for the LIVING SOLUTIONS 4.8 VOLT CORDLESS SCREWDRIVER. I misplaced the paper and after 48 hours non-stop charging, battery meter remains red.
danny_murray
  • 55 Answers
SOURCE: My cordless Black & Decker
Most likely it is the switch has gone bad or just a loose connection on the switch . you can take it apart and check the switch connections and make sure they all have a good connection.If they do then you should take a volt meter and make sure that when you puch the button they get proper voltage if not then order a switch and replace it .
Posted on Dec 05, 2008
SOURCE: skil cordless drill model 2362 - won't charge
I have the same problem. The guys at Batterries Plus told me that 7.2 volt battereis are not easily replaced and definately not through them. If you left it charging for to long (ie over a week when you were gone like me) then the battery is never gonna charge again. You might as well find the same model of dril at skil's reconditioned site for around $40 or buy a brand new one for $60 or $70
Posted on May 09, 2009
harlan301
  • 205 Answers
SOURCE: looking for charger no.7228201 for craftsman 4.8
those unit were made for sears check there web site. the part number my tell you MFG of the unit. if not you'll have to buy it from sears
Posted on Oct 12, 2009
  • 553 Answers
SOURCE: It tells you to that you should charge the battery
The problem is your batteries are either over heating or worn out. You might also have a problem with the charger but you'll need Dewalt tech support to determine if it's good or bad.
The first thing to do is clean the contacts. Use a white plastic pencil eraser and clean all the contacts you can reach. If there are any contact you can reach with the eraser use a Q-tip that is just damp (not wet) with rubbing alcohol to clean them.
Discharge your batteries completely then put them in the freezer for 8-24 hours. Take the batteries out of the freezer and let the set 24-48 hours after that put them on the charger, they'll either charge or you need new batteries (more likely) or a charger.
Posted on Jul 01, 2010
  • 178 Answers
SOURCE: I have a B&D Pivot Plus Cordless
If your drill is a model PD600, your battery part number is 5102993-00 and this website is selling it for 15.00
http://www.ereplacementparts.com/battery-p-100105.html
If this helped, please rate me!
Posted on Nov 25, 2010
What settings on a universal charger do I use for a Black & Decker 2.4 V cordless screwdriver
I would say that a output voltage of not more than 2.8 volt and the output amp should not exceed 60% of the Amp hour rating of the battery. Example if the battery is a 2000 mah battery the charging amp should not be more than 1400 milli amp or 1.4 amp
Jan 12, 2014 | Black & Decker 9072CTN Cordless...
How long should a fully charge battery last on WG250E Hedge Trimmer
This is the info i found on WG250 battery . It says up to 50 min below in the features. Hope it helps
Battery
The WORX WG250 hedge trimmer incorporates an 18-volt 1.7 Ah Ni-Cd battery pack. You can use this battery pack with other WORX Ni-CD PowerShare tools. The included charger takes about an hour to restore a dead battery to full charge.
Cordless Hedge Trimmer 18v Worx WG250E jQuery(document).ready(function($) { $("a[rel=product-image-gallery]").fancybox( { 'transitionIn' : 'elastic', 'transitionOut' : 'elastic', 'titlePosition' : 'over', 'titleFormat' : function(title, currentArray, currentIndex, currentOpts) { return 'Image ' + (currentIndex + 1) + ' / ' + currentArray.length + ' ' + title + ''; } }); });
Features
  • Wall mount bracket
  • 3 position adjustable front handle
  • overmould soft grip for user comfort
  • Quick release handle
  • Double insulated
  • Volts: 18
  • Blade length: 510mm
  • Cutting capacity: 14mm
  • Blade action: Dual
  • Run time: Up to 50mins per charge
  • Charge time: Up to 1 hour
  • Machine weight: 3.1Kg
  • Comes with one battery and a charger
Sep 13, 2011 | Worx Wg250 20inch 18volt Cordless Hedge...
Battery runs down after about 5 hours and has to be removed and recharged. This leads me to believe that the battery is not being recharged in use. My supplier says nothinhg is wrong and I am stopping and...
Hi, has your supplier actually tested that the mower is charging? If you have a multimeter check the battery voltage with the mower running at about quarter throttle. It should be higher than 12.7 volts, usually somewhere around 14 volts. If it is not the charging system requires checking. Hope this helps, regards Phil.
May 19, 2011 | Garden
I have a pd360 Type 2 3.6 Volt Pivot screw driver and I don't know how to charge it? I've misplaced my paper work for the tool. Can you help me?
Usually, the battery is removed from the tool and inserted into the charger base. Hopefully, the charger has not disappeared also. Good luck!
Oct 16, 2010 | Black & Decker Garden
My Craftsman cordless screwdriver doesn't charge
you have a short in the battery or charger,,,very dangerous ,,the batt could explode
Jul 27, 2010 | Craftsman 14.4 volt Cordless Drill/Driver...
Jul 01, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Looking for Craftsman Cordless Screwdriver Charging cord
Go to the following link:
http://commercial.searspartsdirect.com/partsdirect/parts/5102970-17/0009/900&pathTaken=partSearch&filterPart=&pop=flush
Sep 12, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Phone not charging even with new batteries
Reboot your phone system. I'm not kidding. Unplug base from power and phone line for 1/2 hour and unplug battery from phone.
Feb 19, 2009 | AT&T 650530003417 Cordless Phone
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
My cordless Black & Decker Pivot screwdriver, stopped working. It is completely charged, but will not work.
Aug 23, 2008 | Black & Decker 9072CTN Cordless...
Drills Logo
89 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
