Question about Kenmore Ovens
Convection oven and timer shuts off after 1 minute. The regular bake works.
I have a Kenmore Elite Double Electric Built-In Oven Models 790.4817*, 790.4818*,790.4819* suddenly tonight as I was baking supper and thought I should be about done I checked the food and the oven was off. I again set the temp to 350 convection bake and after 1 minutes it shuts off-including the timer. I tried the other oven and the same thing happens. It seems to work fine on regular bake just not convection bake.
4 Suggested Answers
SOURCE:
scottowa
  • 87 Answers
SOURCE: Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Posted on Mar 04, 2009
  • 291 Answers
SOURCE: my oven inside glass door exploded tonight while
Very rare, in 35 years I replace maybe 2 to 5 a year out of 1500 to 2000 repairs a year on all major appliances. Make sure you replace it with the exact glass from the manufacturer, usuing your model number. Do not replace with glass from a glass shop.
Posted on Jan 29, 2010
dmftrucker
  • 1922 Answers
SOURCE: Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Posted on Jul 29, 2012
What is a error code F/19 mean?
That error means that the lower oven is not heating fast enough. IT should rise to over 150 in 5 minutes. Check the broiler and the baking coils for continuity. If they are ok then check the radiant heater in the convection fan housing.
May 12, 2015 | LG 30" Built-In Double Electric Convection...
Replace thermostat on kenmore elite
Possibly none of these videos are exactly like your oven but it should give you enough information to get the job done.
Note that some of the videos are not for ovens.
Replace thermostat on kenmore elite oven YouTube
KENMORE ELITE Walloven Parts Model 79048033800
Oct 16, 2014 | Kenmore Elite 30 In. Electric Self-clean...
When trying to thermal/radiant bake, convection fan at the rear does not stop turning after the preheat. Why doesn't this happen? Isn't it then convection baking?
Most wall ovens have a cooling fan that comes on when the oven has been on for some time. It is separate from the convection operation. It should shut off after the oven has been off for a time.
Nov 12, 2013 | KitchenAid KEBS279BWH 27" Double Electric...
Jul 28, 2012 | Dacor Ovens
What is the best setting for my viking on a 14 pound turkey, bake or do i use the convection broil?
Use the regular bake setting.... run the oven at 350.... the 14 lb. bird will take about 4-5 hours.....convection moves air and can tend to dry out the bird...
heatman101
Nov 25, 2010 | Viking 30" Professional Select Built-in...
Should the fan on my built in electric convection oven come on during normal 'bake' mode (ie not 'convect' mode ?
There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
Mar 03, 2010 | KitchenAid KEBC107 Electric Single Oven
The upper oven has faulty code 4d22 every time i try to clean
I just tried the suggestion to cut the power to the oven from the box for 1 minutes, and it worked! I feel like I just earned a day's pay!
Dec 29, 2008 | Jenn-Air JJW8230D Electric Double Oven
Whirlpool Oven/Convection Oven Timer Problem
replace the control cpu unit the main control board is deffective
Apr 11, 2008 | Whirlpool RBS305PD Electric Single Oven
Ovens Logo
32 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
