Question about Philips Televison & Video
Philips HTS bluray receiver is cycling through open and close disc commands and I'm unable to open the setup menu to attempt to install firmware upgrade.
  • 231 Answers
SOURCE: Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Posted on Dec 03, 2007
  • 6 Answers
SOURCE: DVD PLAYER DISC TRAY DOES NOT OPEN
tap it gently from the side while pressing the button......or with a knife try to open it gently...while pressing the button....after it,s open..clean the side n the belt..
Posted on Jun 26, 2009
ripleymojica
  • 643 Answers
SOURCE: skips and stops playing after a few minutes
go to esonyrepair.com and download latest firmware. make a dvd to download.
Posted on Jul 11, 2009
SOURCE: Sony Bluray player Picture blinking on and off
Hi Lauren,
We had this very same problem and all we did was upgrade our standard, generic HDMI cable to a Monster brand "higher def" cable, and all was right with the world. Hope this helps!
Posted on Sep 19, 2010
beeduq
SOURCE: Philips HTS 3164
Also working in htsd3510 or hts3510
Posted on May 02, 2015
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
I have a friend who has a PIONEER Bluray Player BDP LX52.Despite having updated it to the latest firmware(3.71)it is not playing the RED(Morgan Freeman,Bruce Willis)Bluray.Sometimes he gets the menu and...
The firmware update needs to be done again.
Follow the steps below to troubleshoot if the BD player cannot read or play a disc:
IMPORTANT: Prior to following the steps below, go to the Drivers & Software section of the Pioneer eSupport Web site to check for available firmware updates. If a firmware update is available, it will be posted there with a list of improvements over the original or any previous firmware version. Some disc playback issues may be resolved by ensuring the BD player has the most current firmware installed.
  1. Ensure the Easy Setup procedure has been completed on the BD player. NOTE: Can't play DISC may display on the LCD screen if the Easy Setup procedure was not completed first.
  2. Ensure the inserted disc is compatible with the BD player. NOTE: Consult the instruction manual of the BD player for a list of compatible discs.Manuals are available online through the Manuals/Specs/Warranty link on this page.
  3. Select BD players may require that a USB memory device has been properly inserted into the EXT slot of the player prior to playing the movie. If the BD player being used does not have an EXT input, skip this step. NOTE: The USB memory device may need to be re-formatted to FAT32 format prior to inserting it into the player.
  4. Use a soft cloth to clean the disc.
  5. Examine the disc for any cracks or scratches that might be interfering with playback.
  6. Wipe the top of the disc tray using a soft dry cloth before placing the disc on the tray. Attempt to play the disc again.
  7. Attempt to play another disc. Remove the disc from the BD player.
  8. Turn off the BD player.
  9. Unplug the power cord of the BD player from the electrical outlet.
  10. Let the player remain without power for 1 minute.
  11. Plug the power cord back into the electrical outlet.
  12. Turn on the BD player.
  13. Insert the disc into the BD player.
  14. Attempt to play the disc.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required
Apr 08, 2011 | Pioneer BDPLX52 BluRay Player
I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
1. Switch the DVD player ON
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Regards,
BElectric
Mar 26, 2011 | Philips HTS3371D Theater System
Avatar menu keeps poping up while the movie is playing
Make sure that the blu ray player is indicating that the latest firmware is installed on it. Press the setup button go to settings and down to version. Then record the version number. If it is the most current firmware version number after all call 800-237-4277 pressing 1 for all of the prompts. Inform the representative that with the firmware version number installed on your bluray player you are having this problem with Avatar. This helps because Sharp is
gathering information on any occurrences after an update and they are working on another update to resolve any occurrences
May 10, 2010 | Sharp AQUOS Blu-ray Disc Player
My Philips HTS6500 does not read most DVDs. After
HTS 6500 1- OPEN TRAY 2-PRESS DISPLAY 3-ENTER 9.9.9.9.0. 4 CLOSE TRAY. SHOULD WORK .
Sep 14, 2009 | Philips HTS-6500/37 System
Unlock dvd player to play all dvd regions
I bought today a Philips HTS 8140 region 4 and i use this solution
1. Abrir a bandeja do aparelho / Open the tray
2. Aperte a tecla DISC / Press DISC buton
3. Digite o código 99990 / Insert 99990 code
4. Feche a bandeja / Close the tray
Jan 12, 2009 | Audio Players & Recorders
''WRONG REGION'' MESSAGE ON PHILIPS HOME THEATRE SYSTEM
Ensure both TV & player are on , no disc in player
on the remote press: disc menu, then open/close then stop
enter the following numbers:
7,3,4,4,6,6,0
you should see region 0 in the bottom left hand corner
the player should now play, if not and your in Australia ring Philips on
1300 363 391
good luck
Terry
Jan 11, 2009 | Philips HTS-6500/37 System
Region code
I have a region Code For A Philips HTS-3544 which is 1 model Down. You can try it, it may work or it May Not.
Heres How:- power on the TV/DVD without any disk in the player.Press open/close eject.
Press Stop 7.3.4.4.6.6 ( on the Remote )
The menu code appears On The Screen.
Press 0 for region Free, or the region Code Required.
Power Off and then on Again, if the codes have worked, your dvd player is now region free.
If this works please rate as Fixya.
many thanks mike @ Compurepair.
Aug 28, 2008 | Philips HTS-3555 System
Unlock Philips HTS-3565
Hi
TURN ON THE PLAYER
PRESS OPEN/CLOSE TO OPEN THE TRAY
WITH THE TRAY OPEN, PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL BE DISPLAYED.
PRESS "0" TO UNLOCK ALL
PRESS "OK"
Aug 20, 2008 | Philips HTS-3565 Theater System
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
