One cd is stuckinside dcm-500 ae. playing same cd over and over
3 Suggested Answers
  • 66 Answers
SOURCE: cd stuckinside the deck
question to u is the deck still on is the deck powerd up............if so you will have to replace the deck you can remove the cd with a little work once the deck is removed.........good luck
Posted on Nov 30, 2009
  • 6771 Answers
SOURCE: Denon DCM-370/270 - issue playing CD's. A CD will
I would replace the audio cable from the CD player to the Denon amp, a long shot, if you have other devices hooked to the amp and plays fine, the problem will be in the CD player. However! if all sound sources have the same problem, the issue is with the Denon unit.
Posted on Mar 09, 2012
Mar 09, 2012 | Denon Audio Players & Recorders
Where is the mp3 plug in for a denon DCM-280
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Denon-DCM-280-CD-Players-review-manual/id/363ci871/t/1-2/
It's capable of playing MP3's right out of the box. See page 18.
Feb 21, 2011 | Denon DCM-280 5-Disc CD Changer
My DCM-360 has stopped playing discs after my moving house. It spins the carousel, picks up the disc and then puts it down without spinning the disc up. Laser problem or disc-spinning-motor problem or...
Had a similar problem with my Denon. When I inserted CD it takes it in but immediately stops - like it doesnt sense the CD. Same problem with Single or Multi changer. Removed cover, removed reader ( 4 screws) and found lens had fallen out. Cleaned, reinstalled with touch of super glue on rim - works fine.
Oct 12, 2010 | Denon DCM-360 5-Disc CD Changer
Changer spins but will not play cd
the sensor is probably dusty, so id try 2 take it apart n dust it off
Dec 15, 2009 | Denon DCM-360 5-Disc CD Changer
Cd stuckinside the deck
Nov 30, 2009 | 2005 Acura TL
Denon DCM 390 not longer reads discs--HELP!
Hi there, this lens may be dirty or it may have a thin layer of heat film that is causing it to not read in a consistent manner. i would try to clean the lens with a good CD lens cleaner. if the cleansing doesn't restore the lens to its original reading state, this will confirm lens assembly failure and you will need to replace this assembly.
May 17, 2009 | Denon DCM-390 5-Disc CD Player
Denon DCM 5000 error code
The disc is loaded upside-down in the disc rack or the disc is dirty or scratched, try another disc and make sure the top side (label side with printing) is facing towards the back of the rack, away from you. The bottom or data side should face out towards the front of the rack. If that does not work then your laser picups inside may need cleaning. Make sure your disc is clean and now scratches.
Feb 08, 2009 | Denon DCM-5001 100-Disc CD Changer
Denon DCM 370 5 disc changer does not show all discs!
Probably drive belt that rotates the carosel inside is not lining up properly,or the belt that moves the laser mech into position,sounds like its just not lining up properly
Jan 04, 2009 | Denon DCM-370 5-Disc CD Changer
Cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
 Grubhead
Grubhead
