Question about Toys
I lodged my centre link claim form on 24/12/16 instead of 22/12/16, earlier date. i had to lodge it 2 days earlier. who can i ring to get an emergancy payment as my son and i need it?
  • 566 Answers
SOURCE: how do you remove underwire lodged between drum and outer case
hi to remove bra wire from between drums ? you might try this 1st ? if you diconnect water supply hoses and unplug power supply then remove rear panel from machine you will have access to the large rubber drain hose from outer drum down to discharge pump ? ok hose is held by spring wire clips both ends remove clips then hose you may find bra wire either in hose or close to drum drain if you need ? feel inside drom via drain hole ? or probe with a piece of coat hang wire ? you may even find the mysterious missing sock/ thong / etc when you disconnect the hose too?? any debri has to lay in bottom of outer drum and so a little patience will locate them using this method instead of removing the main front door sealto drum for access to same area also with rear panel off you can check belt tension ? hope this helps/inspires you ? best wishes from uk
Posted on Feb 26, 2009
  • 4088 Answers
SOURCE: need to remove agitator to remove lodged medallion
Remove the agitator top cap, and unscrew the mounting bolt part way. Pull up on the agitator by both sides of the rim, then finish removing the bolt after the device is loose. (Keeps you from smacking your face when the agitator comes loose.) Hope this helps.
Posted on Oct 08, 2009
Testimonial: "Thank you so much. I had figured out how to unscrew agitator, but was affraid to pull 2 hard as I thought I might break it. Your 2 step method works"
SOURCE: How can I remove a lodged oil dip stick?
Go down about a inch on the tube and drill two small holes horizontally to fit a metal coat hanger thru. Put the hanger thru and wrap it tight. Next bring your hood down half way and wrap the other end of the hanger tightly around the hood latch. A couple of quick pushes up on the hood will pop the tube out. Dealer price to replace the dipstck about $15. To replace the tube about $40
Posted on Nov 17, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: The washer will not go into High Spin. I had the
You have to pry off the caps on the tumblers. Try not to produce any burs on them so on reinstall they dont snag the wash load.
Once you have the caps off you take a #20 Torx driver and back out the tumbler retaining screw the SM does not call that out.
Page 37 of the FAV6800A/FAV9800A Service Manual will detail this?
Do you have the SM? If not join this forum and download SM 16022808 Maytag Top Load Neptune Washer Service Manual
Posted on Oct 26, 2010
SOURCE: my childs vtech mobigo says
my childs mobigo says he has rewards
Posted on Jan 17, 2011
My wife is getting compensation for a public liability claim. Can Centrelink take it??
if they have been making disability claim payments they can get those payments paid back from you when your claim is settled for the period the claim was lodged to settlement date
for example if you claimed a payout of 500,00 dollars for an injury and the center link paid you disability to the sum of 100,000 dollars over the claim period then they will be entitled to that 100,000 back on settlement of your claim
best talk with qualified legal advice as to where you stand
May 30, 2017 | Computers & Internet
What must I do if I want claim a land
fill out a form and lodge it with the lands office
May 07, 2016 | Computers & Internet
How to get a passport
If you are an australian citizen
Go to your local post office to make your new passport you will need 2 Australian current passport holders to sign documents that they have known you for a certain amount of years 10 i think also about 100 points of ID Birth Cert ,Drivers Licence,medicare card ID,current passport, bills ie:electricity gas rates.......2 passport size photographs For current or recently expired passports only
When you need to renew a passport, we will provide a one page form already filled out with your personal details if you are eligible. This pre-completed form streamlines the renewal process.
You will not need to supply any supporting documentation. However, you will need to provide two recent colour photographs of yourself and present your previous passport.
When you lodge your renewal form your old passport will be physically cancelled. Some exceptions apply for renewal overseas.
Not everyone can use the renewal form. In particular, you cannot use it if your passport was lost or stolen (you will need a passport application form instead). So before trying to renew, use the following checklists to make sure you are eligible.
You can apply for renewal if:
  • you hold an Australian adult passport issued with at least two years' validity and
  • the passport is current or expired less than two years ago and
  • the passport was issued with your current personal details (i.e. name, date of birth, place of birth and ***) and
  • you are an Australian citizen aged 18 years or older.
Note: You will need to retain your expired adult passport for two years after the expiry date if you intend to renew your passport.
You cannot apply for renewal if:
  • your passport was lost or stolen or cannot be presented for renewal or
  • your passport was issued with less than two years' validity or
  • you have changed your name or *** since your passport was issued or
  • your passport has expired for two years or more.
Obtaining a renewal form
Online - follow the prompts at this web site to obtain a pre-completed renewal form and print it from the screen. You can also ask online for a pre-completed form to be mailed to you. The form should be lodged in person at an Australia Post outlet.
If overseas, contact the nearest Australian diplomatic mission or consulate for details on how to lodge the form.
Alternatively:
In Australia - call the Australian Passport Information Service on 131 232 to arrange for a pre-completed renewal form to be mailed to you.
Overseas - contact the nearest Australian embassy, high commission or consulate. The passports staff will mail out a pre-completed renewal form or it can be collected from the diplomatic mission or consulate.
https://www.passports.gov.au/Web/Forms/Passport/Renew/RenewPassport_0.aspx
https://www.passports.gov.au/Web/Requirements/IdentityDocuments.aspx
Mar 26, 2014 | Facebook Apps
Passport colect by agency that gone.how can i get it or file re-new?
Go to your local post office to make your new passport you will need 2 Australian current passport holders to sign documents that they have known you for a certain amount of years 10 i think also about 100 points of ID Birth Cert ,Drivers Licence,medicare card ID,current passport, bills ie:electricity gas rates.......2 passport photographs For current or recently expired passports only
Not everyone can use the renewal form. In particular, you cannot use it if your passport was lost or stolen (you will need a passport application form instead). So before trying to renew, use the following checklists to make sure you are eligible. You can apply for renewal if:
  • you hold an Australian adult passport issued with at least two years\' validity and
  • the passport was issued with your current personal details (i.e. name, date of birth, place of birth and sex) and
  • your passport was issued with less than two years\' validity or
  • you have changed your name or sex since your passport was issued or
Alternatively:
https://www.passports.gov.au/Web/Forms/Passport/Renew/RenewPassport_0.aspx https://www.passports.gov.au/Web/Requirements/IdentityDocuments.aspx Hope this helps.
Jan 14, 2013 | Computers & Internet
\ what are the requirements for renewal passport and changing status?
depending on which country you are a citizen of and live Go to your local post office to make your new passport you will need 2 Australian current passport holders to sign documents that they have known you for a certain amount of years 10 i think also about 100 points of ID Birth Cert ,Drivers Licence,medicare card ID,current passport, bills ie:electricity gas rates.......2 passport size photographs For current or recently expired passports only
Alternatively:
https://www.passports.gov.au/Web/Requirements/IdentityDocuments.aspx hope this helps
Sep 08, 2011 | Western Digital My Passport Essential SE...
How to make an appointment to get a new passport
Go to your local post office to make your new passport you will need 2 Australian current passport holders to sign documents that they have known you for a certain amount of years 10 i think also about 100 points of ID Bith Cert ,Drivers Licence,medicare card ID,current passport, bills ie:electricity gas rates.......2 passport size photographs For current or recently expired passports only
Alternatively:
Aug 14, 2011 | Computers & Internet
How i can renewing my passport help me please
Alternatively:
Jul 05, 2011 | Computers & Internet
How to apply for passport?
if you are referring to an australian passport renewal For current or recently expired passports only
Alternatively:
Jun 26, 2011 | Western Digital Passport WDXML800UE...
I need to renew my passport,what are the requirements and do i need to apply online?
this is for an australian passport For current or recently expired passports only
Alternatively:
hope this helps
Jun 25, 2011 | Computers & Internet
Door Hums but won't open
drive gears not causing this problem. usually when trolley lodges against bolt, you take out bolt, reset up travel a little, put bolt back in and it never happens again.
Dec 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Toys Logo
27 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
