Question about Sewing Machines
I can't get my 1634d stitch width more than an 1/8 th of an inch
  • Sewing Machines Master
  • 11,452 Answers
What is the brand of your machine? The only thing I can locate is Brother 1634d which is a serger and, as such, has no stitch width selection.
Posted on Dec 27, 2016
What are the stitch numbers
There are lots of numbers in sewing! I suspect you are referring to the numbers that some sewing machines assign to each stitch. So, for example, a straight stitch might be #1, zig zag stitch #2, hem stitch #3, and so on.
Different sewing machines will number their stitches differently, though. My suggestion is for you to take a plain piece of fabric and a contrasting thread color and just sew a few inches of every stitch on your machine. Number them, and keep the swatch for reference!
Another "stitch number" on a sewing machine could be the tension number (that's the dial usually at the right side of the needle). This will determine how the stitch lies on (or within) the fabric. Another number will set the length of the stitch, so you can have tiny little stitches or very long ones or anything in between. Yet another number will set the width of the stitch, so you can go from a very narrow zig-zag to one as wide as your machine is capable of producing. That width is limited by the opening of the plate on your machine, usually about 5 mm.
Hope this answers your question, and isn't too much information!
Nov 21, 2017 | Sewing Machines
What stitch setting do I use for a satin stitch?
Depending upon the machine, whether it is electronic or a manual setting, most settings for satin stitch are shown as a zigzag with Length being the primary changeable setting.
If you want a 1/4 inch stitch, your width should be set for 6mm. on an electronic machine with the Length at or about 0.3 mm.
On a manual machine you will have to adjust the length until you get the effect that you want.
In either case use a scrap of fabric to test your stitches and then record the settings that you like best.
Apr 26, 2017 | Sewing Machines
I got a new Brother 1634D Serger and would like to make a quilt on it. How do you get a 1/4 inch seam? please help me
Don't expect a quilt to be as accurate from a serger as from a sewing machine. First, you probably want to focus a strip quilt where rows of strips are stitched together. If you do strips, you won't have to worry so much about maintaining an exact 1/4" seam. You can also vary the widths of strips in order to camouflage any seam variations. Avoid a pattern that requires points being aligned! Any seam width variances will not as obvious as an error (it is intensive getting an accurate 1/4" on a sewing machine--so-o-o-o much more difficult on a serger). There are usually seam width marks on a serger that you can follow as a guide, but straight line serging is very difficult to accomplish. You can always try marking a line on your serger using painter's tape.
FWIW, making a strip quilt on a serger is a fast way of finishing a quilt. I divide my quilt into 3 or 4 sections, like making it in thirds or fourths. That way, when the quilt begins to grow, you are not constantly grappling with flipping or turning the heavy and bulky fabric. Instead, do each section separately, then stitch the sections together to make the whole quilt.
Also, be sure to press all the seams of a strip quilt in the same direction.
Strip Quilt Patterns
4 Free Strip Quilt Patterns That Standout from the Crowd Fons Porter
How To Sew An Easy Strip Quilt
Make FAST Serger Strip Quilt with 1 4 square Triangles
Feb 27, 2017 | Brother Sewing Machines
Easiest way to make a buttonhole...manual does not tell much info
Easiest way is to create a bar tack at one end of the buttonhole (widest stitch width and stitch length set to 0). Stitch maybe 4 or 5 stitches.
Then move needle all the way to the left, set stitch length to very short (maybe somewhere between 0 & 1), width to slightly less than half, stitch forward to the end of the buttonhole.
Then make another bar tack (as above). Move needle all the way to the right, set to less than half width, short stitch length, and stitch in REVERSE to first bar tack. To tie off, set width to 0 and length to 0 and stitch 2-3 times in place. Raise presser foot, pull gently on fabric and clip threads.
Mar 12, 2015 | Sewing Machines
How do I change the stitch width and length from mm to inches on an Ellure. I've changed the overall settings to inch, but the individual stitches are still showing up in metric.
The inches to mm display is only changed in emb. mode. The stitches will still be shown in millimeters. It is the nature of machines manufactured in todays world.
Jan 01, 2015 | Sewing Machines
Directions for making a buttonhole with an Elna SU
A transcript from the Elna SU manual reads as follows, and the manual can be viewed on line at
First make a few trial runs with a scrap of material exactly as the buttonhole will be stitched, with the machine adjusted as you intend to use it.
1. Use the embroidery and buttonhole foot. It can be chnged without a screwdriver by using the fixation screw.- With the stitch width knob at "0", turn the selector to zigzag "1".
2. De-center the needle to the left.
3. Set the stitch width knob at 2, with the solid mark on top.
4. Set the stitch length dial between 1/2 and 1/4.
5. a) Mark the desired length on the material.
b) Sew the first side of the buttonhole. Stop with the needle in the material and the mark (right).
c) Raise the foot and pivot the material round the needle. Lower the foot and raise the needle.
6. a) Set the stitch width knob at 4.
b) Sew a few stitches. Raise the needle.
7. a) Set the stitch width knob at 2.
b) Sew the second side and stop just short of the length of the first. Raise the needle.
8. a) Set the stitch width knob at 4.
b) Finish off the buttonhole by sewing a few stitches. Raise the needle.
9. a) Set the stitch width knob at "0".
b) Sew a few stitches to fasten the threads, holding the material back by hand.
10. Open with the buttonhole knife, which you will find in the accessory box.
Oct 12, 2014 | Elna Sewing Machines
How do I make a large buttonhole ..( 1 3/8 inch).. the button doesnt fit on the buttonholer.
You do it using narrow rows of side by side zig zag stitches and bar tacking the ends of the rows. Make a line where you want the hole to be. Set the zig zag stitch width very narrow, whatever is closest to what suits the fabric. Coarse or loose weaves need a wider width, finer ones a narrower width. Experiment on some scraps to get it right. Number of stitches per inch, or stitch length, should be very fine, at least 20 per inch, but not 0. Try a few more experiments on scraps to make sure it looks right. Make a test hole to be sure it is the right size for your buttons.
Stitch a straight line of zig zags down one side of your line, with the edge of the stitching not quite touching your line. Stitch a second row directly on top of the first one.
Repeat on the other side of the line. Ideally you should still be able to just see the line you drew when the rows are done, but not see any bare fabric on either side of the line.
Then move to one end of your rows. Leave the stitch length the same, but change the width to match the width of your two side by side rows. Stitch a bar tack, about the same length as your two rows are wide. If your two rows are 1/8 inch wide, your bar tack should be 1/8 inch long. Do the same at the other end. Make sure the bar tack covers the very end stitches in the rows as it is the anchor that will prevent unravelling. This is exactly what machine buttonhole makers do, but they do it all for you.
Carefully slit between the rows to open the hole. I like to put a drop of Fray Check or something similar on my buttonholes after I cut them open. It makes them much stronger and they will never come out.
Oct 09, 2014 | Sewing Machines
I have a euro-pro sewing machine that i got second hand, came with no manual so i dont know whot to set it to basic stich it has all these knobs and i have no idea how to run it normally
The stitch dial for the length is located all the way on the right side of the machine and is factory set at the setting "3," which is a 3mm or 1/8 inch length. Turn the dial up or down to adjust the length. For example, the setting "4" is 4mm (5/32 inch) and "2" is 2mm (5/64 inch).
The width of the serged seam is dependent on the needle or by adjusting the knob for the width. With the left needle only sewing, the width is set to 7/32 inch, and with the right needle only sewing, it is set to 9/64 inches. Additionally, by pushing in the width adjustment knob behind the front cover, the stitching can be adjusted manually from 1/8 inch to 17/64 inch wide.
Jul 23, 2011 | Euro-Pro Deluxe 6130 Mechanical Sewing...
Have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Mar 11, 2009 | Elna 1010
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
