Question about Garden
Zl600 sled, starts well, only goes into reverse, belt is good, clutch does seem to engage in forward
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
  • 776 Answers
SOURCE: hyundai excel 1996 automatic will engage reverse
It appears you have a Forward Clutch FAILURE. Replace the trans after you get it diagnosed and verified by a professional technician. By the way, do you have a Check Engine light? If so, what is the diagnostic code? The dealership can scan the system and find any codes which may have been stored in the TCM (Transmission Control Module). If there were any 'Incorrect Gear Ratio" codes, it's most probably the trans itself.
Posted on May 28, 2009
  • 1111 Answers
SOURCE: Cub Cadet engine runs but, also will not go in forward or reverse
you didnt say what model this is, but i assume its hydrostatic because it has a drive shaft. is the hydrostatic unit filled with oil¿ if its ok, check the linkage from the pedal to the rearend (hydrostatic drive) make sure its not broken or loose.. if that l@@ks ok, check both ends of the drive shaft making sure the couplers are not broke and the drive shaft is ok. hope this helps.
Posted on Jul 17, 2009
  • 205 Answers
SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Posted on Oct 13, 2009
  • 513 Answers
SOURCE: Bolens clutch wont engage
check to see if there is something caught around the blades that won't allow to turn
Posted on Jun 27, 2010
Primary clutch does not want to close far enough to engage belt and belt slips and sled will not move 2014 arctic 6000 zr
check for a broken cable jamming the clutch operation
adjust the clutch cable correctly
Feb 11, 2016 | Motorcycles
I bought a 92 Chev 2500 4X4 from a guy just recently. He said the tranny wont go into gear. I found the transfer case was in neutral. So i put it in gear and away it goes. But reverse seamed sluggish. ...
If your transmission is a 700r4 (4l60) you have a reverse band that engages when you want to go in reverse. since it drives forward your low reverse clutch and your fwd clutch are working. This leaves the band which was probably slipping now is not engaging.
Feb 16, 2011 | 1992 Chevrolet C/K 2500
I have a 2004 polaris prox2600 snowmobile with perc reverse and every time i engage the reverse button the sled shuts off any ideas would be greatly appreciated
did you let the sled warm up first? If the sled is'nt warmed up flip the choke lever while its running and quickley press the reverse button make sure you shut choke back off or you can load up your sled. Good luck let me know
Jan 20, 2010 | Polaris New Genuine Polaris Snowmobile...
Tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
Sep 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
1990 VW cabrio wont reverse. Seems in gear but only goes forward
left and push the shifter into the floor like stabbing down ten it will go left a little more and push forward and you will be on your way in good ol R
Jul 25, 2009 | 1990 Volkswagen Cabriolet
MTD Yard Machine does not go forward or reverse - I replaced belt
I think that the belt is not on right. if you look at the belt diagram from the top, then on the left side then the belt is hooked up to nothing. on the right side then the belt goes through the left side of the clutch pulley.
Jun 18, 2009 | Mtd Garden
No power when drive is engaged
Check your drive belt and the tensioner pulley that holds tension on the drive belt. Its possible for the tensioner pulley to be sticking and not putting enough pressure on the drive belt causing it to slip.
Grab hold of that tensioner pully and make sure it moves in and out freely against the drive belt.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
