Question about Kitchen Ranges
20 Freestanding Electronic Ignition Range - The oven ignites the pilot but the burner is not working. How do i fix this?
5 Suggested Answers
SOURCE: Kenmore Gas Range/Freestanding/ Electronic Ignition
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Posted on Oct 14, 2007
  • 432 Answers
SOURCE: top burners work but the oven is not working. I
Well not sure how long it has been in use,but igniters will go bad anywhere from 5-15 years depending on use and if the stove has been moved or dropped.The igniter is very fragile and when you look at it the crack that stops it from working is very small and many times is hard to find.Well hope this helps.
Posted on Mar 12, 2010
heatman101
  • 43501 Answers
SOURCE: Premier 20" range with electronic ignition - the
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Sep 08, 2010
  • 2006 Answers
SOURCE: caloric range oven, older at
If you don't smell gas, then it is probably electronic ignition and not a pilot light.
But if your oven and none of the range burners light, are you sure you are getting gas to the unit or from the range valve to the burners and oven? Can you light the burners with a match? If you can you can rule out the valve and incoming gas line, and concentrate on the ignitors.
Posted on Jun 07, 2011
The gas is connected on the rear side of the stove but the pilot light is not lit, nor will it light. trying to trouble shoot the problem before deciding to purchase a new oven/range. Also, I remember...
You may have a pilotless ignition.Check around door frames for model #plate.
Also , open broiler door ,turn on oven and look inside . If you see an orange glow appear after awhile, that is the electronic igniter and you have an electronic ignition(no pilot).In this case the top burners use a spark ignition system.If you don,t hear clicking when you turn on a burner your ignition module might be bad.
Easily fixed though.
Aug 18, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
WHERE IS MY PILOT ON MY FRIGIDAIRE FGF368GM
Hello, There is no pilot..It uses ignitors to light. number 19 in this picture is the oven ignitor http://lookup.bellparts.com/diagramenlarge/frigidaire/47877/00000358
If when you turn on the oven it doesnt glow bright orange chances are it failed and needs to be replaced. The top is electronic ignition. If this helps please rate me..Thanks
Jun 08, 2011 | Frigidaire FGF368GM Kitchen Range
Caloric range oven, older at least 20 years old, the range burners spark, but will not light, i am assuming that its electronic ignition, no pilot light?
Jun 07, 2011 | Kitchen Ranges
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
How do i light the oven pilot on a ge xl44?
MOST modern appliances that use gas ignition (including dryers) no longer have a pilot light. These appliances are now equipped with a burner assembly with electronic igniters. The following link explains a little theory about how these igniters work and how to access the them on a gas range:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you are having ignition problems with one of the oven manifolds (bake or broil), it may be a simple matter of a weak or bad igniter. If BOTH manifolds are experiencing the same problem, you may have a bad regulator or electronic oven control (EOC) board. The EOC controls all your oven features.
The surface burners use an electrode type igniter for ignition. There is one mounted next to each surface burner assembly. They get their electric source from a spark module. If none of the surface igniters are working, you may have a bad spark module. If one single burner is not igniting, the problem is probably the electrode.
If you have any questions, please let me know. Include your complete model number if it is different from the one you posted this question under. I hope this information is helpful to you.
Jan 14, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Oven won't work
    sounds like electronic ignition is worn out
    May 26, 2009 | Hotpoint 30" Self-Cleaning Freestanding...
    Oven will not light
    If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
    Nov 20, 2008 | Frigidaire Ovens
    Aug 31, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
    Kitchen Ranges Logo
    Top Kitchen Ranges Experts
    Oloyede Monsuru
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
