Question about Kyocera Cell Phones
I have a Kyocera E4710 flip phone , the sim card holder pop out so I have nothing to hold the sim card in place for me to use phone can I order this piece separate?
bsrjth
  • 270 Answers
SOURCE: My phonw wont read sim card
just placea piece of folded paper so as to make the simacrd tight and put he battery . it will work fine
Posted on Dec 23, 2007
damneddle
  • 1607 Answers
SOURCE: We removed the sim holder
Hello.
Make sure you insert it back properly and not upside down:
Or use a flashlight to check what is preventing it from going back in place.
Posted on Aug 02, 2011
pattybailey2
SOURCE: New SIM card overheating
Sounds like a battery issue
Posted on Oct 08, 2012
cksparky7886
  • 97 Answers
SOURCE: How to fix the Sim card holder kyocera
You might have to take it back to the store
Posted on Oct 15, 2016
  • 81 Answers
SOURCE: i need user manual for kyoceraE4710 cell phone.It's a flip phone. International INC E4710
Hello, your manual can be found here: https://mans.io/files/viewer/199429/1
Posted on Dec 29, 2016
Oct 15, 2016 | Kyocera Cell Phones
Tip
Insert SIM Card Problem Fix
The "Insert SIM Card" problem can be irritating when it keeps on popping up even when a SIM card is actually been inserted into the phone's SIM card holder. It can sometimes be remedied by cleaning both the SIM card and the holder terminals with a cotton swab immersed in alcohol; most preferably 70% alcohol solution. Sometimes the holder is not tightly holding the SIM card causing the problem. This can be solved by padding up the back of the SIM card with a small sheet paper or any appropriate material enough for the holder to hold the SIM card tightly. Another way to fix the problem is by bending in the mid-section of the SIM holder cover.
Nokia 1110, 1110i, 1200, 1028, 1209 and all other member of the family of Nokia phones with USB ports similar to the ones mentioned earlier have the tendencies to experience the "Insert SIM Card" problem not due to a dirty terminals nor a loose holder but due to dirty, soiled, or oxidized USB port terminals. The fix is just as simple as cleaning the USB port terminals but make sure to remove the phone battery prior to the cleaning. Use a paper clip, a safety pin, or a needle with bended tip to scrape off the dirt between the port terminals and dip it in alcohol to wash it out.
The cleaning can be done without the necessity of disassembling the phone but if proper tools are available, disassemble the phone to clean the inside of the system connector, the one where the USB port, the charging socket, and the headset socket are located.
System Connector
People may wonder how a dirty USB port can lead to the "Insert SIM Card" issue and guess what; it is not even included in the Nokia Service Manual. The fix was discovered accidentally and proven many times that a dirty USB port is indeed the source of the problem.
on Apr 09, 2010 | Cell Phones
How can I install my 8GB SD card for my boost mobile Kyocera phone
My Kyocera phone, Turn phone off or just remove battery.
The SD card is at upper left push lightly upward and the card holder will release.
Insert card and gently push back into place install battery and repower the phone.
Feb 11, 2015 | Kyocera Cell Phones
How do i install sim on a kyocera c653 phone
Did you mean the Hydro-life C6530N phone? There is no C653 listed on the Kyocera USA web site. The following is copied from page 9 of the manual for the C6530N:
Insert the SIM Card
1. Insert your thumbnail or fingernail into
the slit and lift the battery cover.
2. Grasp the white pull-tab extending from
the battery pack and pull the battery out
of its compartment.
3. Use your fingernail to carefully pull out
the SIM card tray.
4. Place the SIM card into the tray, with
the gold contacts facing down and the
cut off corner on the top left. Insert the
SIM tray back into the SIM card slot and
push until it clicks into place.
Note: Make sure not to insert the SIM
tray in the opposite direction.
5. Insert the battery, contacts end first, and
gently press into place.
If the tiny type is too hard to read, you can view the manual with a PDF reader at http://www.kyoceramobile.com/hydro-life/Hydro_LIFE_User_Guide_T-Mobile_en.pdf
There is a different manual for the MetroPCS version of the phone, but the SIM card installation is the same.
Jan 03, 2015 | Kyocera Cell Phones
How to manually reset kyocera echo?
After I holder the menu thing down I typed reset and nothing happened :(
Aug 22, 2012 | Kyocera Swipe Echo
Have tried following instructions but cannot get back off to insert battery - nothing budges and am reluctant to push/slide cover too hard. Is there a trick to this?
There is three tangs that hold the battery cover in place. You can push with 2 fingers on each side at the bevel area on both side of the camera len. You could also bring you phone to your local service provider to ask them to remove the cover for you.
Oct 11, 2010 | Nokia 2720 Fold Cell Phone
Where do I put the sim card in a motorola L7 please let me know. rattler7010@yahoo.com
In the above image i will clearly explain how to place the SIM card.
First please remove the back cover by pressing in outside(side ways)
and remove the battery and place the SIM card in the Gold plating.You have to slide the metal projector and place the Sim card.The RED marking is the place where you place the SIM card.The blue marking is the metal which you have to slide to place the SIM card.It is like a holder to hold the Sim Card
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | Motorola Mobility SLVR L7 Cellular Phone
I am trying to remove my sim card from my kyocera cell phone
it's usually located under the battery. the metal holder slides in one direction to release the lock that's holding the sim card. for that phone i'm not sure which direction. try both you'll know when you have it. be gentle tho it's not made to use alot of force on.
Feb 21, 2010 | Kyocera wild card Cellular Phone
How do I remove the battery and put the sim card in my new nokia 2760 cell phone
These are steps from the Nokia 2760 manual found at :
http://nds1.nokia.com/phones/files/guides/Nokia_2760_UG_en.pdf
(pages. 12-13)
1. Press and slide the back cover toward the top of the
phone to remove the cover .
2. To remove the battery, lift it as shown
3. Carefully lift the SIM card holder from the finger grip
of the phone, and open the flip cover
4. Insert the SIM card, so that the bevelled corner is on
the upper left side and the gold-colored contact area
facing downward.Close the SIM card holder, and
press it to lock it into place
5. Insert the battery into the battery slot
6. Align the back cover with the back of the phone. Slide
and push it toward the bottom of the phone to lock it
Apr 14, 2009 | Nokia 2760 Cellular Phone
Phone doesn't recognize the SIM card
The sim card holder has a tiny slide mechanism. After inserting the sim card and pressing it against the body of the phone, place your finger over the card and slide it gently forward. The tiny plastic part that holds the card will snap it into place. Hard to explain, but it will work.
Dec 17, 2007 | Motorola Mobility V66 Cellular Phone
Cell Phones Logo
95 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
DROPNDEAL
DROPNDEAL
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
