Question about The Toys
Can you replace chargers for the black opps falcon flyers?
Htc wont charge and turn on
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
May 02, 2013 | HTC Flyer 7 inch 32GB Android Tablet PC...
Where can I find a replacement handle for my Radio Flyer Classic Red Wagon? The number on the side is 89.
Radio Flyer has an excellent grass roots website and customer support team. Find them on the web, give them a call and they'll either get you a direct replacement or something that will work for your wagon. I had a problem with one of the wheels of our wagon which was discontinued. They sent a full set of replacement wheels; free. This is a great company. Just give them a call.
Apr 28, 2011 | Radio Flyer Class Red Wagon
I downloaded black opps went to play and it wont respond
OS not likely the problem. Black Opps is OK on XP Home. Check minimum system requirements. I'd suspect RAM or video card.
Dec 03, 2010 | Microsoft Windows XP Home Edition
I have one motorola RAZR V3I; WHICH IS NOT CHARGING EVEN A NEW BATTERY. KINDLY LET ME KNOW THE ADDRESS OF THE SERVICE CENTER. I AM STAYING IN CIVIL LINES, DELHI
the reason your phone is not charging a battery is either because the charger or the charging port or the battery terminal is faulty.
To test if it is the charger try it on another motorola phone, to see if it works, ifit does not, then you can replace the charger.
To test if it is the battery, try the battery in another similar phone and try to charge it to see if it works, if it does not then it is the battery that needs replacement.
To test the terminal head, get a meter reader, open the phone and test the battery terminal if it does not read it, then it is the terminal that needs replacement.
To test if it is the charging port, try a new tested ok charger on it to see if it work, if it does not then the charging port has a fault and needs replacement.
If you still insist on cantacting motorola, their contacts are below.
No information on any motorola close to Delhi.
GLOBAL HEADQUARTERS Motorola, Inc.
1303 East Algonquin Road
Schaumburg, Illinois 60196 USA
Telephone: +1 847 576 5000
Primary office locations: www.motorola.com/global
General comments or questions: Have a question or comment about a Motorola product or service? Contact us:
Tel.: +1 866 BUY MOTO (U.S. only);
+1 888 390 6456 (TDD/TTY).
Email: mot_mailbox@custhelp.com
Jun 15, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Big flyer replacement pedal
Contact Radio Flyer online and request the replacement part. They confirmed the replacement within 5 hours.
Dec 30, 2009 | Radio Flyer Big Flyer
Need replacement parts for Radio Flyer Steer&Stroll Deluxe Trike
Try calling Radio Flyer's Customer service for replacement parts at 1(800)621-7613
Jun 20, 2009 | Radio Flyer Steer and Stroll Deluxe Trike
Toys Logo
22 people viewed this question
Top The Toys Experts
David Payne
David Payne
ottworld5982
Level 1 Expert
Are you a The Toy Expert? Answer questions, earn points and help others
