Question about Tablets & eReaders
Tablet beeps what for - Tablets & eReaders
Why did my RCA 10 inch tablet power down and now will not turn back on? It does not show any sign of charging - no battery symbol, no lights, nothing.
battery have residual power which last few minutes to allow safely switch off, as you used this power, it shut down. this residual reserve is usually between 3% to 5% of capacity.
and do not fiddle with it till you recharge it, reset will not work while there is no power, any other "trickery" will not work either.
now, plug battery to known good charger and charge it for 24hrs, do not switch it on during that time nor disconnect from the charger.
after this it should be starting and working normally, if it does not - it is still under warranty and you should return it to the place of purchase for repair or replacement, even if you do not have receipt. tablet have it's serial number and can be traced in the store to day, and even hour and minute when it was sold...
hope this short info will help you - do not forget to vote...
Feb 02, 2015 | Tablets & eReaders
Tablet will not come on
Leave it on charger for several hours.
Mar 24, 2014 | Motorola Mobility XOOM Android Tablet
Beeping sound volume change
Since you did not give us the model, it is impossible to tell you exactly how to do this.
You need to get to Settings/Sounds/Notifications or a similar menu description.
How Nextbook Tablets Work HowStuffWorks
Jan 01, 2014 | Nextbook Tablets & eReaders
My asus tablet keeps beeping
Forgot password on a Coby Kyros 7012.How to reset it ?
Dec 01, 2013 | ASUS MeMO Pad HD 7
Laptop shuts down automatically and emits a beeping sound
Yes this is for the memory problem...Try to change the RAM...
Oct 20, 2009 | Fujitsu Siemens LIFEBOOK P1510D Tablet PC
X61 Beeps constantly
Please have a look through the following links, to help diagnose the problem your 'beep error code' is trying to alert you to.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 16, 2009 | IBM ThinkPad X61 Tablet PC
Powers on-indicator lights light up, motherboard fan runs, but do
try reseating the dimm ..
I don't see a listing in the manual for 5 beeps as you describe
Jan 04, 2009 | Lenovo ThinkPad X60 Tablet PC
Cannot Start
Different PC manufacturers have different BIOS Boot codes.
Read first
http://pcsupport.about.com/od/nonworkingcomponent/ht/beepcodestb.htm
Then read:
http://www.pchell.com/hardware/beepcodes.shtml
http://www.computerhope.com/beep.htm
http://networking.ringofsaturn.com/PC/beep.php
Apple:
https://mediawiki.middlebury.edu/wiki/LIS/Apple_Computer_Beep_Codes
http://www.techbase.iofm.net/tips/applemac/tip1.htm
http://www.user-guides.co.uk/download/apple/applebeep/apple-beep-code.html
Jul 30, 2008 | Toshiba Portege M205-S810 Tablet PC
Keyboard
If you are getting the message after the beep that Press F1 to continue after the beep and your system is working fine in every manner except the keyboard, you might have your KBD corrupted. better to check it with authorised service center for Keyboard interface or the complete Keyboard.
Feb 04, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Tablets & eReaders Logo
22 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
