Get error occurred while printing..
When i press print i get the message says print preview error........yellow triangle sign then it says an error occurred while printing
  • 2985 Answers
SOURCE: Printer stopped printing. Error message
Thjis is indication the Waste in collector pades need changing eventually.- but no now. you have plenty of warning
Reset Epson R300/200
press three buttons to reset the counters
The buttons are "STOP" "Maintenance" and "POWER"
or down load the epson utility and use the reset counter feature
The printer will sound like its going to blow up, but thats normal.
You can do this about 5 times before your printer starts to piss out ink over the table because the Waste Ink Ink Pad is full
To avoid eventual flooding go to rear of the machine- remove the little door and rake around for a small plastic pipe buried under some padding under the left side.
Fix to this a thin piece of ploythene tube[Fish tank air supply], extend it to our side the machine and place in a suitable container to collect the waste ink..
Posted on Nov 21, 2007
SOURCE: Status Monitor informs of Ink levels requiring me to press resume button during and after each print job.
What it means is the tank to collect waste ink (from cleaning etc) is full.
Canon suggest you return ther printer for replacement of the absorbant mat, suggest you scour the web for DIY cures.
Posted on Mar 12, 2008
SOURCE: hp photosmart 7960 printer disconnected error message
usb port
Posted on Oct 08, 2008
  • 85 Answers
SOURCE: Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Posted on Feb 15, 2009
  • 541 Answers
SOURCE: Error Message: write error to a port occurred. Printing is finish
you need to reconfigure the port in his computer. you change this in the driver on his computer
Posted on Oct 05, 2009
Error message, print requests stuck in que
you might have multiple prints loaded
make sure you have the printer turned off it might load another page to be printed
you will need to open up a page you are about to print click ok
a page will open with a display print que tab
you will see all of the prints you have loaded
right click on the ones you dont need select delete
hope this helps
Nov 19, 2011 | Brother MFC 420CN All-In-One InkJet...
I just want to be able to enlarge my print size
  • Simply press and hold down the "control" key, while pressing the "plus sign" key. Be sure to keep the "control key" depressed while you press the "plus sign" key. Each repetition will enlarge the text. This can make reading small text SO much easier!
  • To return the text back to its original size (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key. Each repetition will decrease the text size
  • Log on to your computer and open the document you want to print. Click on the "Print Preview" button on the toolbar.
  • 2 Click on the "File" menu and choose "Print Preview" from the drop-down list if the "Print Preview" button is not available. The "Print Preview" function will show you exactly what the finished print will look like.
  • 3 Click the "Close" button to close the Print Preview window, then highlight the entire document and click on the "Format" menu. Choose "Font" from the drop-down list and change the font.
  • 4 Click the "Print Preview" button again to see the finished print. Continue to adjust the font size until the print looks good
  • Jun 12, 2011 | Microsoft Windows 7 Professional Upgrade...
    I have an HP laserjet 1320; all of a sudden I cannot duplex will print one side only and on the reverse side of the page I get a message: Guest: ERROR: MemoryFull Guest: OFFENDING COMMAND:...
    Welcome to Fixya
    Try to restore the printer to factory state and make sure you record your printer's settings before performing this procedure. Holding down the printer's Green print button briefly will print any configuration information.
    a. Turn the printer power off
    b. Press and "hold" the green "go" button whilst turning the printer on.
    c. Continue to hold the go button for at least 5 seconds and until the amber
    attention light turns on (triangle with ! in the middle), this should occur
    before 15 seconds elapses.
    d. Release the go button.
    Your response will be highly appreciated.
    Thank you for using Fixya!
    Jan 04, 2011 | Computers & Internet
    My MP510 was just printing fine then went to rear feed and now all I get is a flashing green and yellow lights
    review this to determine your problem.. If all else fails simply unplug your printer wait a minute and plug back in.
    Handling Error Messages
    When a printer error occurs, the POWER/ERROR lamp flashes.
    The number of flashes indicates the type of error that has occurred.
    Count the flashes and take the appropriate
    action to correct the error.
    Number of Flashes
    Possible Cause
    Try This
    Two flashes Printer is out of
    paper/Paper does
    not feed
    Reload paper in the Sheet Feeder or Cassette and press the RESUME/CANCEL
    Three flashes Paper jam/Paper
    Output Tray is
    Clear the jammed paper, reload paper in the printer, then press the RESUME/
    CANCEL button. If the Paper Output Tray is closed, open it.
    See “Paper Jams” on page 72.
    Four flashes Empty ink tank Press the RESUME/CANCEL button to resume printing with an empty ink tank.
    Replace it with a new ink tank immediately after the printing. It may damage the
    printer if you continue printing with an empty ink tank.
    See “Replacing an Ink Tank” on page 42.
    Five flashes Print Head not
    Head not installed
    Print Head
    Install the Print Head. If the Print Head is already installed, remove the Print Head
    and check the electrical contacts for foreign matter, then reinstall.
    After reinstalling the Print Head, you may need to realign it.
    If this error still remains, the Print Head may be damaged. Contact the Customer
    Care Center.
    Six flashes Inner Cover is open Close the Inner Cover and press the RESUME/CANCEL button.
    Eight flashes Waste ink absorber
    almost full
    The printer has a built-in waste ink absorber for the ink used during Print Head
    Eight flashes indicates that the waste ink absorber is nearly full.
    Press the RESUME/CANCEL button to cancel the error so you can continue printing.
    Before the waste ink absorber becomes completely full, contact the Customer Care
    Nine flashes A specified period
    of time has elapsed
    without receiving a
    response from the
    digital camera/The
    digital camera or
    digital video
    connected is not
    compatible with
    this printer
    Disconnect the camera cable, press the RESUME/CANCEL button and reconnect
    the cable.
    If the error is still unresolved, there is a possibility that you are using a digital
    camera or digital video camcorder that is not supported by this printer. Use a
    digital cameras or digital video camcorder compatible with this printer
    Mar 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    Light with the triangle flashing - printer stopped
    That means ATTENTION, you are either out of toner or have a paper jam.
    Feb 18, 2010 | HP LaserJet P2015 Printer
    When i try to open iTunes a message pops up saying " the iTunes application could not be opened. An unknown error occurred (-50)
    The only options for this error are for solving the problem of iTunes not opening, which are listed here:
    I suggest trying to re-install iTunes first, then go through the solutions on that page. Print off the page before you start trying to fix it, and include all sections (check in print preview).
    Dec 30, 2009 | Apple iTunes
    List the steps to get a printed screen of an error message
    Press command-shift-3 to take a picture of the screen. This will create a file named "Picture 1" on your Desktop. Double-click that to open it in Preview, then use command-P to print it.
    Aug 13, 2009 | Computers & Internet
    Ink tanks are running low... BUT!
    Have you changed anything on your pc such as installed updates windows or interent settings, this can often adversely affect printer fuction as many printers cannot handle certain settings and operating environments. I would first clear all printing jobs (click on printer and select cancel print queue or similar message. Now turn printer off, disconnect all cords and usb cables. re plug and turn on and try again. You can also check printer driver function, go to start, control panel, perf and main, hardware, scroll down to your printer, see if any yellow exclamation marks. This could mean a driver problem. It may be incompatable if you have changed anything or it may be malfunctioning due to spyware or other. I also suggest running full anti spyware and virus checks. I all this fails, try uninstalling and reinstalling the printer.
    Aug 16, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
    22 people viewed this question
