Question about Bernina Sewing Machines
Our Bernina 1130 quits sewing after 3 stitches.
SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Posted on Jun 05, 2008
  • 21 Answers
SOURCE: Bernina 1630 problem
Your feed dogs sound like they are getting stuck,chec whether they are on the down position,and also make sure that you have cleaned any lint that builds up in the bobbin area, if all fails it will have to go into the technician,
Posted on Sep 21, 2008
  • 6 Answers
SOURCE: Bernina 440 stops stitching
see your local dealer and tell them you have a bad power board. or l-print. this is a known issue and bernina is covering it under there 5 year warranty. the 5 volt output is faulty on some some models
Posted on Apr 11, 2009
  • 980 Answers
SOURCE: My old Bernina 1130 has never given me trouble,
If you have a drop feed mechanism make sure you have not dropped the teeth down by mistake, make sure you have enough pressure on the foot, remember you should not be able to pull the fabric through by hand if the teeth are up
Posted on Nov 01, 2009
  • 65 Answers
SOURCE: bernina sewing machine 1130 manual
We have that instruction manual available here:
Bernina 1130 Sewing Machine Instruction Manual
Posted on Dec 02, 2009
Testimonial: "This website has been very helpful to me. I received the manual instruction I required for free from a kind member. More power to you,! "
On my Bernina 1130, the shaft that the sewing needle is connected to is frozen in up position & won't go down the thread the bobbin.
Does your 1130 have a basting stitch (I believe it does)? If so, the basting stitch is hung up. A technician can free it up very quickly. However, you can also do it yourself. Sorry, the instructions in writing would be difficult so I'm going to recommend you join Yahoo group "BerninaThirtySomethings" You will need a yahoo email account and then search for the group and request to join. There are documents in the files section that have very elaborate pictures and directions on how to do this yourself. It appears pretty simple once you know what you're looking for.
FWIW, Bernina afficionados recommend running the basting stitch once a month to keep it working (ha, I never do it either and did end up having a technician free it for me). Now that I have the instructions, I'll try it myself the next time it happens.
Jan 04, 2018 | Bernina Sewing Machines
Jun 05, 2008 | Sewing Machines
Gummed up baste stitch finger on bernina 1130. how can I fix it?
If you can join the Yahoo group "BerninaThirtySomethings," there are a lot of conversations there and documents that explain how to fix the stuck basting stitch. It is rather difficult to explain so that would be the best source. (You will need a Yahoo email account to join the group.) A Bernina technician can release that for you.
Bernina basting stitch use it or lose it Sewing Tip by Irene PatternReview...
Questions Answers for Bernina basting stitch Sewing Machines
Need to reset Basting Pin on Bernina 1530 have the back off Can you tell...
Dec 30, 2017 | Bernina Sewing Machines
Bernina 1130: Is it possible to override default factory settings for stitch length. I want to change from 2 to 3
A Bernina technician can probably do that for you. However, it's probably not something you can do yourself.
Mar 24, 2017 | Bernina Sewing Machines
My Bernina 1130 has zig zag problems. I have to turn my machine on for 10 minutes before it will even sew. When I sew straight it will skip a few stitches every inch or so. Now it will not zig zag mo
here are some suggestions
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
I really recommend having the sewing machine checked to
see if there is a internal problem, since you have to wait 10 minutes
before sewing & the problem with the zig zag & looping.
Oct 07, 2012 | Bernina Sewing Machines
Bernina 1130 backstitch is not working
then you need to call the shop that serviced the machine & tell them
about the problem that the machine won't backstitch & see what they
Apr 29, 2012 | Bernina Sewing Machines
My Bernina 1130 will not stitch anything but a straight stitch. Everything will work fine for about 20 minutes, then almost everything will quit working. Even the backstitch quits. The needle position...
Only sew for 20 min at a time... just kidding.
It could be a lot off stuff, could be a bit price to fix aswell.
The fisrt thing that comes to my mind is a bad S-print (mother board). This will need to be removed from the machine and mailed to bernina of america for repair. May be around $350 or so and about 3 weeks.
That is just a guess with the info you gave. It could also be a bound up slide block or bad stepmotors.
Most deffinitly will need to bring this to a bernina trained teck.
That is a great machine. If you like it then I say it is well worth the repair.
Hope this helps.
Apr 10, 2011 | Bernina Sewing Machines
Stitch is not straight
When was the last time your machine had a routine cleaning and adjustment? It sounds as though you've got "play" in the mechanism that needs to be tightened by a sewing machine mechanic.
Jun 07, 2009 | Bernina Sewing Machines
Bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Apr 10, 2009 | Bernina 1008
Sewing Machines Logo
29 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
