Question about Cameras
How to copy a picture - Cameras
  • Brett Duxbury
    Brett Duxbury Dec 26, 2016
    Hi Ed Gonzales, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    Is this a digital camera ?
    Can you download the files to a computer ?
    What are you wanting to do ? Copy a file of a picture ?
How do i download photos onto a usb
Not sure what the problem is here, but if the laptop recognises the USB drive and it is formatted as a FAT device, you should see the device icon in "My computer". If you are downloading from your hard drive to the device, simply highlighting all the files by SHIFT and RIGHT mouseclick and dragging them onto the device will copy them.
If downloading from the internet, right mouse click and save target or picture as and point to the USB device as the place to save to
Jun 02, 2012 | HP Computers & Internet
I want to download pictures from the internal memory and I attached the camera with the usb cable and it does nothing. I've tried pressing the shutter button nothing
The only way is copy pictuers from internal memory to the external memory using the camera Copy pictures or videos:
1 Press the Review button, then press the Menu button.
2 Press to highlight Copy , then press the OK button.
3 Press to highlight an option:
PICTURE or VIDEO-copies the current picture or video.
EXIT-returns to the Review menu.
ALL-copies all pictures and videos from your selected storage location to the
other location.
4 Press the OK button.
NOTE: Pictures and videos are copied, not moved. To remove pictures and videos from the original location
after copying, delete them
May 19, 2012 | GE X500 Digital Camera
How can i get the date and time shown on the developed picture
If you copy the data from the built-in
memory to the card, we recommend using
a card which has more free space than
the built-in memory (about 14 MB).
• If a picture having the same name as the
name of picture to be copied exists in the
copy destination, the picture will not be
copied.
•When you copy the data from the built-in
memory to the card and if the free space
on the destination recording medium is
not sufficient, the picture data can only be
copied halfway.
• DPOF settings on the original picture data
will not be copied. Set DPOF settings
again after the copy is completed. (P73)
• Only files conforming to DCF standard
(P49, 75) can be copied. (Files which do
not conform to DCF standard cannot be
copied.)
• It may take time to copy the data.
• Pictures which are recorded or edited with
other equipment may not be copied.
1 Select [YES] to format the
medium.
(The illustration is the screen when the
built-in memory is formatted.)
•When a card is not inserted, you can
format the built-in memory. When a
card is inserted, you can format the
card.
hope you can get something out of this...it came from user manual!
Jun 12, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
How can I transfer pictures from internal memory
Link to the manual:
http://wwwuk.kodak.com/global/plugins/acrobat/en/service/manuals/urg00378/C340_4J1986_GLB_en.pdf
PICTURE or VIDEO—copies the current picture or video.
EXIT—returns to the Review menu.
ALL—copies all pictures and videos from your selected storage location to the
other location.
Nov 19, 2009 | Kodak EASYSHARE M340 Digital Camera
Can't Copy Files onto USB Drive
I think you have to copy the pictures to your flashdrive and not copy and paste. this is how to do it: highlight the pictures you want to copy to your flashdrive and check on the left side of windows explorer, you will see some commands available like (delete, copy , move etc) select the copy command and a small windows will appear for you to choose the location to copy, select the flashdrive and then click on copy.
this will copy the selected pictures with ease.
Feb 05, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Feb 03, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Can't transfer photos from computer to digital frame
1. Install EasyShare software (free download at www.kodak.com/go/sw)
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Jan 17, 2009 | Kodak EasyShare M853 Digital Camera
I can't transfer pictures from my computer to my digital frame. When I connect my usb cable to my computer from my digital frame , the frame displays "Connected to computer. Use PC interface to copy files....
Dec 26, 2008 | Kodak EasyShare SV811 (8858946) Digital...
I'm trying to transfer pictures from my computer to the picture f
Dec 20, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer autourg00722003id1479308.jpg Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See info.jpg for applicable file formats.
spacer.gif spacer.gif spacer.gif spacer.gif 1. Connect the USB cable from the frame to your computer (Connecting to your computer).
autourg00722003id1967406.jpg 2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
  1. Install EasyShare software from the CD included with your frame (Installing the software).
  2. Connect the USB cable (Connecting to your computer).
  4. In the menu bar, select File ® Copy to.
  6. Select Best For Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
  8. Unplug the USB cable and press autourg00722003id1974433.jpg to navigate to your copied pictures.
Dec 16, 2008 | Kodak EasyShare EX1011 Digital Picture...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
