Turntable arm will not lower - the guide just pushes it back to the off position
The guide raises when we lift the arm to place it on the record, preventing the arm from lowering enough to touch the record. The arm then just returns to the home position. The record player was working properly, but the next morning this behavior started with no clear cause.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Try to do this
1. unplug the turntable
2. raise the arm
3. put it over the record
4. lower it which will not lower you said
5. push the arm to the very end close to the label
6. rotate the turntable by hand and it should take it through the whole return cycle of the arm and lower and finish the motion
7. then plug in and it should come back to normal
Posted on Jan 04, 2017
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
When playing a record the needle gets stuck at the same place, near the end f the record evevry time. Does not matter what record. Happens with all of them.
I don't know the AT PL50 but I had a similar problem with another make of turntable.
The problem was caused by the rear end of the pick-up arm hitting the side of the perspex cover. The solution was a simple one - leave the lid in the raised position or lift the cover right off when playing records.
Jan 30, 2011 | Audio Technica AT-PL50 Turntable
Tone arm will not move over on self-start unless
Hi, they are not an auto start model turntable. To start lift tone arm off rest and move into position at start of record. It will automatically lift and return to rest as well as shut off at end of record. cheers john ,, Styluscity.com
Feb 21, 2010 | Thorens TD-190 Turntable
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
I'm using the TTYSB05 turntable for the first
There is a raise/lower button. To lower the tonearm, the button should be in the out position.
Apr 07, 2009 | ION Audio Vinyl Recording Turntable
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
The tone arm will not drop on our Technics sl-dd33 turntable.
Have you left the tone arm lift in the up position?
If not: At the end of a record the mechanism lifts the tone arm, returns it to the rest, lowers it and switches off the motor.
It the motor has stopped too early, the tone arm will remain raised.
You can try gently rotating the platter clockwise by hand. This may allow the return cycle to finish.
Jan 16, 2009 | Technics SL-BD22 Turntable
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
Audio Technica AT-PL50 Stereo full automatic turntable system
Try pushing the button on the far right. I had this same problem last night before I released the button was in the wrong position. It is called the "Lift" button and when depressed it lifts the needle up from the record- or keeps it raised and never lets it come down.
Sep 01, 2008 | Audio Technica AT-PL50 Turntable
Kenwood KD 3070 turntable
There should be a set screw that you can tighten in order to adjust the height return. If you do not have anything like this, perhaps your record is raised too much. How thick is your rubber mat? Do you have any other mats sitting on top of this?
- OPTiC
DJ Pro Audio
www.1200s.com
www.repairnyc.com
Aug 16, 2008 | Audio Players & Recorders
Open Questions:
69 people viewed this question
 Grubhead
Grubhead
