Question about Ovens
My oven heating element went out, i replaced it and it still does not work. Any suggestions. Everything else is working
  • Ovens Master
  • 16,199 Answers
Some stoves have fuses. Also connections can burn, so check the connections at the other end of the element wires.
Posted on Dec 26, 2016
Testimonial: "I just checked and harness is burnt where it connects into the control board"
  • Andrew Taylor
    Andrew Taylor Dec 26, 2016
    Yes, that will do it :>)
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
Hi. My oven doesn't heat up after I've used oven pride on it. It's a New World DF 90 make. Everything else works, the fan, grill and hobs, but not the oven itself.
Unfortunately, it sounds like your heating element broke. Suggest using an ohm meter to make sure of that before you replace.
The good news is that element is pretty easy to replace and not very expensive either. Just make sure to trip the circuit breaker BEFORE you attempt the remove and replace.
Jun 05, 2011 | Ovens
The oven was on and working..then the electric tripped and all power went off...after putting the switch back up on the fuse box everything on the oven started working but it does not get...
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please How to Video Tutorials on Domestic Appliances
Mar 04, 2011 | Zanussi ZBF260 Electric Single Oven
Main fan oven in Creda C130E won't heat. Everything else working ok. Suspect the element. Does oven have to be removed from its housing to replace the element?
If you remove the inner rear panl of oven compartment, you will see the element.
If you can see removeable screws, then you can change the element from inside without the need to remove from housing.
If screws cannot be removed from inside, then you will have to remove the oven from housing.
Please leave feedback for my suggested solution.
Thankyou.
Feb 16, 2010 | Creda Ovens
Fan working, everything working but not heating up. Can you help?
If fan working o/k, then I would suggest that the oven element has failed, and needs replacing.
It is located at the rear of the oven behind a removeable cover.
It is a very common fault.
Hope this helps.
Jan 10, 2010 | Neff B1421 Electric Single Oven
The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
May 28, 2009 | Whirlpool GBS277PRS Stainless Steel...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
