Question about USE Cycling
Hi. I have some 3" slugs for my remington 870 wingmaster. But my gun is chambered for 2 3/4 shells. Is it safe to use 3" shells in this gun?
  • 20,997 Answers
I have a remington 870 wingmaster with barrel code CsH, sn.# so50664v tring to date it , and wind out if its a special mdl.
Hi James,
Here is a link for Remington Dates of Manufacture. It is highly reliable for rifle identification. Note to shotguns. It is possible a barrel may have been swapped. So authenticity could be questioned. One needs to be certain of matching to receiver This will be helpful. Remington Dates of Manufacture
From the site conversion:
C=April , S=1925,H=1939
Go and verify the provided results James.
Fare. Well.
Dec 10, 2014 | Remington Sports Remington 12 Ga...
How do I get the plug out that is in the chamber its a new gun
If you mean the MAGAZINE plug, look at your owner's manual:
file:///C:/Users/Guest/Downloads/om_870.pdf
It starts on the bottom of page 11
Sep 27, 2014 | Remington Model 870 Express Deer Pump...
Remington 870 shotgun,serial number 12960V,when was it made
Hi Mike,
I see this is out dated to April 2014. SO. Here goes. I will provide you with a link supported by Remington Society. Here you will find a conversion and listing chart for your interests. Defer to the society on line to enhance your education within Remington. Here is the link. Remington Dates of Manufacture .
It appears you will need more Alphabetic Characters to satisfy the date and year of the manufacture of the weapon. One must disassemble and look for stamped characters. Here is a link for that concern. Remington Serial Number Lookup . The next link will demonstrate where to find the code and its definitions. http://www.remingtonsociety.com/questions/BarrelCodes.jpg .
The final piece of information would be the Remington Arms direct link to contact. With some patience your questions will find what you are searching? See Support. Here is that link. Company History
Apr 05, 2014 | Remington Sports Remington 12 Ga...
Remington 1100 wont eject or load another shell
check and see if the shell stop hasn't broken loose. this on the inside left side of the action . this could stopping the next shell in the mag. from being loaded. this not uncommon. but is an easy fix. a gun smith can stake it back in . in a few minutes for around $20.00
Nov 25, 2012 | Remington Shotgun Mount 12Ga Lh, B Square...
I bought a Remington 870 at Christmas time. The first time i shot it the shells are jamming in the gun. I took it home cleaned it and oiled it real good. Went and shot it again same problem. Either...
If the 870 is a Magnum model it should accept 3" shells. After making absolutely sure you have an unloaded shotgun, both chamber and magazine are empty, empty, empty, proceed with these few checks.
Assuming it may be a 2 3/4' model, have you double checked on the left side of the barrel near the receiver? There will be gauge and shell length stampings on the barrel. If you are jamming 3" shells in to a 2 3/4" shotgun you will get jams as you describe. Look at the empty shell casings if you have any and see if the shell appears to be damaged from the chambered and firing process. This could also indicate you have a improper shell length issue.
If you are shooting reloaded ammo make sure it has been properly re-sized, crimped and reloaded.
sloppy reloading of shotgun shells can cause jams as you describe. Improperly re-loaded shells can also cause leaks of bb's, (shot) in to the receiver and bore area.
Check for a loose bb. or bb's, (shot) in the receiver and chamber area. A lodged bb. in these areas will cause problems you have described.
Run your fingers along the barrel and visually check it for any slight bulge. If you detect or suspect a bulge do not shoot or load the shotgun until a gunsmith or the factory check the barrel thoroughly. If someone had loaded a 20, 16 or similar smaller guage shell in the chamber by accident and the gun was fired it will usually cause at minimum a stressed and bulged barrel. Many times a slight bulge in the barrel may not be visually obvious.
Most of the time if a 12 gauge shell gets loaded behind that one and fired you will have catastrophic failures, i.e. the gun can blow up and cause serious harm, blindness or even death in rare cases to the shooter. Shooters call this a "20/12" catastrophic failure. This type of accident is not to be taken lightly! this is why shotgun shells of different gauges are different in color normally.
Never ever, mix shotgun gauge shells in a pouch or box.
If you pump the shotgun too easily, (i.e. wimpy) it can jam up. Always pump, "rack" a shotgun with vigor. I'm not suggesting abusive action, just don't be slow or overly gentle with the pump action that ejects a shell and reloads the next one. Something related to this is if your action/slide bar is out of alignment or has become torqued out of it's proper alignment this will cause problems as you have mentioned. The action/slide bar is a long single piece of flat metal that is in alignment with the barrel and is attached to the front forearm of the shotgun. This is the flat piece of metal that actually makes the action open and close as you pump the shotgun. There is one on the left underside of the bore and forearm of the shotgun. When you pump the action you will easily observe it moving with your pumping action.
Check how the empty action feels to you. While dry-firing, (using an unloaded shotgun), does the action feel smooth or perhaps, gritty, sluggish, overly tight? If any of the later the you need to double check for debris, shot, excessive old lubrication, gumming of the action, a bent action/slide bar, etc. A normal 870 has a very smooth action.
Also, check the bore for any obvious nicks or obstructions that don't belong there. A good quality shotgun such as your 870 should operate best with very little lubrication. Excessive lubrication over time can cause gumming up of the receiver area. Also, improper lubrication products. Improper lubrication can cause problems you have described.
I am not a gun smith. I am simply an avid gun enthusiast. If you have any doubts as to anything that you observe while performing these basic checks on your shotgun, I strongly advise you to call the factory or take it to a local gun smith. Many gun shops will give your shotgun a courtesy check over and if you don't find a solution, many times they will within a few minutes. Do not be embarrassed to take the gun in to a gunsmith! Trust me, they will most likely treat you and you gun with respect and courtesy. Otherwise they won't be in business much longer.
If the gun shop fixes your problem make sure and purchase some shells and perhaps something else from them. We must support our small business firearms dealers and gun smiths
Hope this helps you!
Feb 02, 2011 | Remington Shotgun Mount 12Ga Lh, B Square...
I have a feed problem with my Remington 1100 12 gauge. With two shells in the magazine, on ejecting a shell from the firing chamber the feed jams because the second shell in the magazine is not stopped,...
You have a shell stop that is either bent or worn, I think there are 2 in there, would have to look. Go to Gunparts.com for the view and order parts, might find them on ebean. Hope th is helps.
Mar 05, 2010 | Remington Shotgun Mount 12Ga Lh, B Square...
New 870 express is not cycling low base shells properly
When it stove pipes, does the empty get caught by the next live round coming up on the carrier?
Try firing one round in the chamber and none in the mag and pump like normal.
If it fires and ejects the empty with no ammo in the mag the ejection system is probably fine.
If when you shoot with one in the chamber one in the magazine and it stove pipes you may have a timing problem. The cartridge stop is letting the next shell come into position and start coming up on the carrier to early. This may be fixed by moving the ramp on the action bar so as to get ejection farther along before the next shell is released to the carrier.
Caution, if the cartridge stops are ok and the carrier is coming up to early it is another issue altogether and needs to be looked at by a smith.
Sep 18, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Remington 1100 12 gage won't load a shell from the magazine
Are you shooting very light load?
Have you tried different ammo?
Light loads may not produce enough energy to work the action properly.
If different ammo doesn't help, make sure the two holes inside the barrel ring are clean and gas from the barrel can pass through. Next I would check the o-ring for cracks. If you shoot lots of shells (competition clays) the recoil springs inside the stock or over the magazine tube may have become weak and need replacing.
Jan 12, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Cycling Logo
240 people viewed this question
Top USE Cycling Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an USE Cycling Expert? Answer questions, earn points and help others
