Question about Grilling
How do I set the temp on the xxl turkey fryer
SOURCE: Instruction manual for New Braunfels Turkey Fryer
http://www.charbroil.com/Consumer/KnowledgeBase.aspx
This is the web site for a company that owned the New Braunfels Turkey Fryer. Look at the info and videos for the 'Big Easy' and the instructions are roughly the same.
Posted on Nov 26, 2008
  • 75 Answers
SOURCE: need manual
so there are a few different ditigal turkey fryers so go to http://www.masterbuilt.com/manuals.aspx and look for your model. good luck happy cooking
Posted on Nov 18, 2009
SOURCE: missing instruction manual for Charmglow Electric Turkey Fryer
Fry turkey 3 minutes per pound, then add 5 minutes to total cooking time
Posted on Nov 26, 2009
  • 10865 Answers
SOURCE: I have a 28 quart aluminum turkey fryer. can I fry
hello. yes, in fact it can handle a 30 pound turkey! Joe
Posted on Mar 22, 2010
woobie dog
  • 1273 Answers
SOURCE: my brinkmann turkey fryer doesnt get up to boiling temp
Hi Larry, W/D here. Just got your question so I'm a bit late in getting back to you......
The amount of heat delivered at the burner is dependent on a number of things, and we'll take them in the order of most likely:
1st, The gas tip must be clear. It's possible for critters to build nests in the gas delivery piping that can plug either the gas delivery port or the air side of the mixing venturi; both will give you a reduction in BTU's. Compressed air can be used to blow out the air side of the venturi. The orifice for tha gas can be cleaned with a thin wire, or use a tip cleaner, available at a welding supply store. These are inexpensive.
2nd, The burner proper can become plugged at the ports where the mixed gas/air combusts. These can be cleaned with a small drill bit,sized to the holes, and just passed back and forth to clean them out. Compressed air works well to remove any particles remaining.
3rd, The regulator may be defective. If this is the case, you'll need to replace it as it contains no user serviceable parts.
4th, the in-line regulating valve may be sticking in the partially open position. This is difficult to diagnose, however, and is more of an assumption, after all other causes are eliminated. The cure for this is replacement also.
Hope that this was helpful to you.
Best regards, --W/D--
Posted on Nov 04, 2011
Why wont the skin get crispy in the Butterball turkey fryer. We have tried everything.
element isn't getting hot enough. maybe only heating half way. need to replace element and or controller temp inside without food should reach 425 deg.
Nov 02, 2016 | Masterbuilt BUTTERBALL Indoor Electric...
I need a replacement lid for a 20100809 turkey oil free fryer
[PDF]Masterbuilt Manufacturing, Inc. - s3.amazonaws.com
s3.amazonaws.com/szmanuals/36c0fb04ceed2650509e23dc539e58ad
MODEL: 20100809 ... if service, repair, or replacement of the product is not commercially practical, ... Do not plug in oil free turkey fryer until fully assembled and ready for use. ... Do not place on or near a hot gas or electric burner, or in a heated oven. .... Clean lid, cooking rack, turkey stand, and basket with a damp cloth or ...
Masterbuilt 20100809 Butterball Oil-Free Electric Turkey ...
www.amazon.com > ... > Fryers
Amazon.com, Inc.
Rating: 4.2 - ‎287 reviews
Amazon.com : Masterbuilt 20100809 Butterball Oil-Free Electric Turkey Fryer ...Thermostat temperature control; Tempered glass lid & turkey stand; Roasting ...
Jan 27, 2016 | Masterbuilt 20100809 Oil Free Electric...
Why won't it turn on?
How to fry a Turkey - Butterball Indoor Electric Turkey Fryer ...
? 8:18
https://www.youtube.com/watch?v=PsAm5jGkOck
Nov 11, 2013 - Uploaded by therealcobraburnout
Butterball Indoor turkey fryer set up and first use. ... In case anyone trips on the cord, the whole fryer won't get knocked over..... well it holds 20lb bird, so you might be able to do maybe to smaller 7lb ones .... Just remember the oil will turn rancid in about 6 months once opened depending on how you store it ...
Butterball Indoor Electric Turkey Fryer - YouTube
? 2:35
https://www.youtube.com/watch?v=LJc8gf2QlG8
Nov 7, 2010 - Uploaded by tulwave
For More On Butterball Indoor Electric Turkey Fryer visit: ... Buy one and try it and i bet you won't be so negative. This thing works great for all ... I usually calculate 3
Dec 25, 2015 | Masterbuilt Butterball Electric 20 lb....
Plugged in my Butter ball turkey fryer set it to 375 and it on got warm. what is the problem?
Hi, it sounds like your temp/thermostat switch is not working properly. Your heating element is warm but not enough this points to the temp/thermostat faulty.
Nov 26, 2015 | Grilling
Turkey fryer won't start
Yo! the Dang pan has to be filled and on the burner which makes contact with the auto shut off sensor that is measuring the temp of the pan. The weight of the filled pan holds that Lil temp sensor down and allows the gas to continuously flow as if you were holding that Lil red button. So after hours of trying to light it without the pan you should find that it does work with the filled pan on the burner holding the red button, stick a match in the hole and let the button go and watch the blue flames flow. My gripe now is that it shuts off after the oil temp reaches 250 to 260 degrees then you have to reignite. Oh yeah my 10lb Turkey was crazy tasty.
Nov 21, 2012 | Brinkmann 815-3786-0 Turkey Fryer
How to do cheat
Not sure exactly what you're asking due to a type-O. But, I going to assume your meant "How to do heat".
Admittedly, this is not the easiest electric turkey fryer to start out with, but it does do the job pretty well.
To start heating the oil and setting the cooking temperature, you must do the following.
Press "ON"; then "Temp Heat"; then press the up arrow until it reaches 400 degrees (for frying a turkey). You may have to push a button more than once, because I think the first push is to light up the screen.
Hope this helps you solve your problem and gets you going.
Feb 18, 2011 | Cajun Injector Deluxe (30 Qt) Turkey Fryer
Do you start timing as soon as you put turkey in or wait till temp is back up
I start it as soon as I place the turkey in the oil. I always add about 5-10 min onto their suggested time though.
Nov 25, 2010 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
I have a master built gas frier and just tried to cook a turkey and it didn't work. It took about three hours to come up to 360degrees. Put the turkey in and temp dropped to 225 and stayed there. cooked...
http://www.masterbuilt.com/manuals.aspx?search=M30BV
something is wrong if you followed the manual. I would get in touch with Masterbuilt directly
customerservice@masterbuilt.com
Phone
1.800.489.1581
706.327.5622 (local for Columbus, Georgia)
706-660-8022 (fax)
Address
Masterbuilt Mfg., Inc
1 Masterbuilt Court • Columbus, GA 31907
Nov 27, 2009 | Masterbuilt M30BV Deep Fryer
Missing instruction manual for Charmglow Electric Turkey Fryer
Nov 26, 2009 | Kitchen Appliances - Others
Left my instruction book at home in NC
The formula for calculating turkey cooking time is 3 minutes per pound, then add 5 minutes to total cooking time, rounding to nearest minute: 13.86 lbs. x 3 mins           41.58 mins Plus 5 minutes                + 5.00 mins                                       =46.58 mins Total cooking time             47.00 mins.
Insert cooking thermometer into the deepest part of turkey and make sure an internal temp of 180 F is reached.
Nov 27, 2008 | Masterbuilt 20010306 Deep Fryer
Grilling Logo
61 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
