When you pick up the receiver it sounds like the noise a fax machine makes. How can I fix it
  • 77 Answers
SOURCE: Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
Posted on May 23, 2007
  • 167 Answers
SOURCE: All calls go directly to fax. Calls don't go to answering machine. I can't answer calls manually to speak with caller.
You seem to have chosen the correct answering mode which is ans/fax.Also pls check whether DRPD mode is correctly set .
It should be off in case your tel line does not have dual ring feature.
happy faxing
omnipresent
Posted on Oct 17, 2007
  • 15 Answers
SOURCE: No dial tone, clicking sound
It most likely is the LIU (Line Interface Unit). or you might have it plugged in the wrong port on the fax itself. Make sure it's plugged into the LINE plug. If it's the LIU it would be cheaper to replace then calling for service. Unless it's under warranty still (usually 90 days)
Posted on Jan 29, 2008
SOURCE: The printer is making a gear clicking sound.
I had exactly the same problem with my OfficeJet 6110 as reported above (i.e. the scan head not knowing where the end-stop is). This is how to fix it (this method worked for me) 1) Lift up the scanner/copier hinged lid. Around the edge of the scan glass are 4 Torx screws. Undo all four screws. 2) Carefully prise the control panel faceplate off. The buttons underneath are on a single panel. Slide this to the left and lift off. 3) Jiggle the lid of the scanner to get it off the main body of the printer. 4) Locate the scan engine motor (top right corner) and remove the two motor retaining screws (one on the left of the motor, the other on the right). 5) Lift out the entire mechanism (rod, drive belt, scan head) and turn over. 6) Thoroughly clean all glass and mirrored areas of the scan head. Also clean the scan lamp on the top of the scan head. Clean the tray inside the scanner (where the scan head travels back and forth). Also clean the inside and outside of the scanner glass pane itself. 7) Refit all parts, using the technique described above, in reverse order. 8) Switch on printer. It should now work OK. Hope this helps, guys.
Posted on Jun 04, 2009
  • 220 Answers
SOURCE: Trying to set up the fax receiving service on our
download firmware upgrade from samsung website,have printer on and run firmware.takes 2 mins.if fails get liu/modem board replaced.common problem.
Posted on Jun 26, 2009
Fax
Are you faxing from the computer or from the control panel directly from the all-in-one? Do you have an answering machine on the same phone line as you fax? which could be interfering (picking up) before the fax machine can pick-up (called the hand-shake, as in when you hear all the funny noises and tones that go back and forth between two machines) In any even, read your manual to make sure it is set up to Tx (transmit) and Rx (receive) faxes; that feature could be off by default http://www.bhphotovideo.com/lit_files/695.pdf
Jun 25, 2013 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Can't get fax machine to work. I need to enter ECM mode on the machine so I can receive faxes but on the report print out it's saying mode G3. I can send faxes but can't receive them. Please...
Doubt if you need to set up the fax with ECM ( error correction mode )...a lot of fax's come with ECM these days set to ON. Don't know why because in the majority of cases the phone lines are of good enough quality that its not necessary. However, that said; I would suggest you pick up your handset and listen to the dial tone on the phone/fax line and listen to see if you are hearing static noises...if you do then its likely you have a bad line and should report it to your phone provider.
If the line is good, then I would ask you to try and make a phone call off your fax machine(assuming it has a handset) and again listen to the sounds off the line. I would then get someone locally with a fax machine to send you a test page to see if the machine works from a different number/location.
Jan 06, 2011 | Office Equipment & Supplies
I can fax out but I can't receive faxes.
What happens if you dial your fax number the way you make a normal voice call? Does the fax machine pick the line up? Can you hear it making electronic noises? Do you hear any static or line noise?
Try also putting a regular phone on the fax line and attempt to make voice calls to test the lin quality. Listen for static, noise, volume issues. Report problems to your telecom company if you have trouble in voice calls.
May 06, 2009 | Office Equipment & Supplies
My boice mail picks up and I cannot receive faxes How can I fix this?
YOU NEED TO HAVE THE MACHINE ON FAX ONLY OR TAD WHICH STANDS FOR TELL ANSWERE DEVICE
Sep 13, 2008 | Brother IntelliFAX 2800 Laser Fax
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
"Clacking sound when receiving faxes"
a clacking noise is not good, what's the make and model of your machine.
Thank You,
Mikey
Apr 04, 2008 | Brother IntelliFAX 4100 Laser Fax
Jan 29, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Receiving faxes but a weird noise
GO TO RICOH REPRESENATTIVE...TO FIX THE PROBLEM
May 31, 2007 | Ricoh FAX2050L Plain Paper Laser
Can't receive fax
Pick up the receiver and see if you hear a fax tone noise. If so then push the start button and hang up. Is this machine on a dedicated line or shared with the main phone number? Sometimes some people will pick up the receiver on their fax machine dial the fax number and wait for a tone before sending. If this is the case the machine can not recognize that is a ax. Make sure your machine is set for auto receive if it is on a dedicated line.
Apr 06, 2007 | Brother IntelliFax-2820 Laser Fax
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
61 people viewed this question
jasbo
jasbo
