Question about Air Tools & Compressors
Got rebuild kit and new trigger assembly. With trigger assembly can't remember o ring in the kit coming out with disassembly. It's a Bostich FA205BA1 Trigger Valve unit. Valve in. No worky. Thanks
comax
  • 154 Answers
SOURCE: bostich nailer N79WWblows continous air
If the nailer is passing air from directly out of the trigger valve, it must be replaced (P/N-TVA11). If it is passing air from anywhere else, (eg back cap or front ) it needs an O-ring kit (P/N- ORK11)
Posted on May 28, 2009
  • 1388 Answers
SOURCE: I have a N60FN Bostitch nailer. It's loosing air
Your nailer uses a trigger valve part # tva6 (or tva1, but use tva6) (cost about $20) and is sold at www.bostitch.com or ebay for generic. If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body (Use punch for 3mm hole). Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. Note the two grooves on the side of the valve where retainer roll pins hold valve. Remember to insert the valve with these two groves aligned with path of roll pins. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring/seal on plunger is cause of leak. Try using an oring with smaller inside diameter than the broken or loose fintting seal that is present. It must fit pretty tight and be slightly thicker than 1/16" to work. Remove the outer orings to valve and clean and re-use same. Clean the valve port in body of gun and check for sharp edges to prevent cutting orings before inserting the valve. Use silicone lube or oring lube on the orings and the valve port (Danco silicone paste sold at Lowes in the plumbing department). Good Luck on your repair and email if you have other questions
Posted on Jul 08, 2010
  • 1388 Answers
SOURCE: bostich rn46 . gun will
Assuming that there are no leaks, remove head and pull headvalve. Look for fine scratches where oring contacts head. If there is a deep groove worn into head or scratched, sand with 400 grit paper to restore smooth surface. If badly worn replace head. Reinstall parts using silicone paste (looks like vaseline, sold at lowes in the plumbing department, used for faucet orings) )
Posted on Nov 01, 2010
  • 1388 Answers
SOURCE: N63 Bostich Nail Gun Trigger Assembly View
Here is the parts list for your gun:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/bostitch/N63CP
The trigger valve is a tva6 and can be ordered from ebay. Generic valve works ok and saves money. I do not believe that individual parts are sold for the valve. If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body. Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring on plunger is cause of leak. Try using an oring about same size as the broken seat. It must fit pretty tight to work. If you had a small leak it could be that the firing pin orings fit too loose or just too worn. Use silicone lube or oring lube on the orings and the valve port. Good Luck on your repair and email if you have other questions
Posted on Nov 17, 2010
  • 1388 Answers
SOURCE: I have a Bostitch N64C
Assuming no air leaks when you connect air to gun. Remove nails and remove roll pin holding trigger allowing access to pin of trigger valve. With very quick motion depress trigger pin all the way in. If the gun fires then most likely problem with safety and trigger not being pushed all the way up against valve pin. If the gun does not fire, most likely problem with headvalve orings not seating due to scratches where orings contact metal. Remove head and examing metal parts and sand with fine paper to remove scratches (400 grit to finish). Install headvalve into head with plenty of silicone paste lube and push headvalve down into head with thumbs. Cover venthole on sealing surface of head with finger and release thumb pressure. The headvalve should stay down in head with vacuum and release when you release finger on vent hole. If no vacuum then orings are not sealing and gun will not work correctly. Good holidays
Posted on Dec 02, 2010
I have a bostich rn46 wont fire a nail just leaks air.put new trigger assembly in
depends on where the air is leaking from, if the top of cap you have a pinched o ring, from the bottom of tool you have a problem with the cylinder or seal, the trigger assembly has a broken o ring. Let me know where the air if coming from and I will try and help.
Mar 13, 2012 | Stanley Bostitch Nail Gun
My paslode air framing nailer model 5350-90s is loosing air out of the trigger valve when I press on the trigger and the nail does not fire. What is the problem ?
Sounds like a bad O ring. There are rebuild kits you can get with a new set of O rings. Or you can have it done for about $30-50.
Jun 09, 2011 | Heavy Duty Stanley Bostich Heavy-duty...
Bostich rn46 . gun will work fine for awhile, then when i pull the trigger, all i get is air coming out of the trigger. i've put a rebuild kit in and i've also put a new trigger assembly in it. didn't...
Oct 31, 2010 | Stanley Bostitch Rn461 Gun Coil Roofing...
My bostich framing nailer leaks air from top and will not shoot
do you already have the rebuild kit??. Could be a cut o ring the cylinder seal might be cracked , there are quite a few items to check, specifically where is the air coming from, the exhaust, if so then I would look for the items mentioned. It would be best to download a breakdown for the tool and if you are mechanically inclined start disassembly laying parts out in the order removed and also maybe take a few quick pics to help you in reassembly. they are not that hard to rebuild. Let me know and I will see about the breakdown and rebuild kit for you but I need the model number and give me some general area you are in and I will try and find parts somewhat locally
Oct 03, 2010 | Stanley Bostitch N80s Nailer -rebuild...
Have framing gun with split neoprene seal( TVA-11 Valve). What is the scam that we have to buy a thirty dollar valve kit as opposed to a thirty cent o-ring. This seems to be a scam. Bostich N80 SB
If the o-ring is the problem, you can get the o-rings separately. I believe that the o-ring kit runs about $12 and contains all of the rings. If hte problem is internal to the trigger assembly, the entire assembly should be replaced. I have replaced the o-rings twice and the trigger once in my N80 in 24 years of service .
Dan
Jun 13, 2010 | Stanley Air Tools & Compressors
Roofing nail gun will not cycle- blowing air out around trigger area-Stanley bostich
you need a new trigger assembly TVA6 or if you have a local repair shop they might just have the o ring that is split.
May 23, 2010 | Stanley Bostitch Nail Gun
Air comes out above trigger. Gun looses all pressure through here.
the o ring on the trigger valve is broken, if you can find a local repair shop ask them for a purple o ring from a rebuild kit or you will need to replace the trigger valve assembly.
Oct 28, 2009 | Stanley Bostitch N86S 1 Factory...
Air is leaking around the trigger. N60FN. How do you replace it?
Yes, you have to drive out the pins. There currently is no rebuild kit. Depending on when your was built there are solutions though.
Carefully drive out the trigger pin first. Then the one retaining the trigger assembly. The trigger assembly is in there pretty good, carefully work it out. Once you remove it, there are two small steel pins holding it together. Remove those...careful there is a spring inside. You can see what's been compromised. Like I said, there don't make repair kits for these, but you can order a replacement assembly.
Good luck.
http://www.mastertoolrepair.com/n60fn-p-4155.html
Aug 04, 2009 | Stanley Bostitch N88rh Framing Nailer...
I have a bostich framing nail gun and as soon as i hook my air hose up to it the air comes directly out through where the driver is, dont even have to pull trigger, can u help, need gun operating to make...
The o-rings need to be replaced and/or the trigger assembly is defective. Look around at local lumber yards for a "Bostich days" promotion. Often with the purchase of a box of nails, the Bostich rep will "service" up to 2 guns for free. If this is not an option for you because of time, you can purchase the o-ring kit and replace the rings yourself. This is not a difficult repair. Also, be sure to lubricate the guns with pneumatic oil frequently as this will keep the rings lubtricated and prevent them from drying out and leaking.
Hope this helps,
Dan
Nov 30, 2008 | Stanley Bostitch F21PL Nailer
Air Tools & Compressors Logo
79 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
