Question about Honda Electrical Supplies
I have a honda 3000is generator but when on idle down and you pull a trigger on my saw it does not kick back up what could it be
4 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: auto idle on a reddy rgh11000 ie will not idle down
This sounds like the idle control solenoid has become misadjusted. To check that this is the case, locate the throttle lever and follow it back towards the governor arm until you find the solenoid. Start the generator and switch on the idle control while watching the governor arm where it passes near the solenoid, if the arm snaps back and forth you probably have a bad adjustment. To readjust the solenoid loosen the jam nut on the core of the solenoid just enough that you can turn the core by the square bit on the end. Adjust the core 1/4 turn or so at a time until the governor arm stays in position when the idle control is on, then turn idle control off and make sure that the governor arm goes back to the full throttle position. You may have to fiddle with the adjustment a little until you find the right spot. Tighten the jam nut back down and you're good to go.
Carl
Posted on Dec 09, 2008
mamicheddy
  • 79 Answers
SOURCE: Generator hard to start. Kick back
This sounds like the timing is off. Remove the spark plug and pull the cord to see if there is less tension. If there is less tension then you know that the pull cord is fine. Do a compression check on the cylinder, it should be around 100psi. Remove the valve cover and check to see if valves are moving when your pulling the cord. The valves could have came off the rockers.
Posted on May 20, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Brand new B&S 5000 watts
There really is not much you can do without voiding your warranty. This may be something simple like a connector that vibrated loose inside the control panel. (Alternator to contol panel inter-connect) There could also be a wire lying loose that was not connected. Open the control panel... and look for anything obviously out of place. DO NOT do anything else. After that your stuck with the warranty process of Briggs and Stratton.
http://www.briggsandstratton.com/~/media/PDF/BriggsStratton/Engine_Warranty.ashx
or 1-800-233-3723
When your at a B & S service / repair point... (store front)
Things to note .
1. Tell servicer unit is for PRIVATE USE (There is no warranty for commercial use)
2. Have proof of purchase in hand otherwise they will use the MFG date as the start point of the warranty. Many generators sit in a warehouse or on the shelf long past an implied warranty (date of mfg) Bottom line you need to have your sales slip.
There are several things I could have you do but... as the consumer the only thing you can do is perform an inspection. By opening the control panel you need to tell the servicer the only thing you did was a VISUAL Inspection...... Anything else will void your warranty.
So.. look for any obviously loose parts or or connectors. After that sadly your stuck with dealing with warranty service.
Thanks for choosing FixYa,
Kelly
Posted on Sep 04, 2011
Why can't i run my a/c with honda 3000is generator
This generator will run an a/c unit up to 13500 btus and is good for 2800 watts. This is a small generator, the nameplate rating numbers need to jive before overloading the energy supply.
Jun 03, 2017 | Honda Electrical Supplies
Honda EU 3000is only runs on half choke
Overhaul the carb. When you have to choke it to run, there is not enough fuel getting in
May 04, 2013 | Honda EU3000iS Inverter Generator
Honda eb5000 generator
I have a EB-5000 model B 50 Honda generator the high idle works but can't get it to idle down, I change the switch because it was broke, I looked all springs are there, when I put my finger on the governor rod and pull it back idles down, any suggestions
Apr 16, 2013 | Honda Eb5000 Eb7000 5000 7000 Generator...
I have a husqvarna 141, I can start it and it will fast idle. When i kick the high idle down it stalls.
Remember taht when you start to cut you need to pull back (towards you) the upper handle this will automate the full trigger for logging.
Nov 07, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a Honda 3000IS generator that only produces ~50 volts from the 30A receptacle--the other receptacles work fine, as does everything else on the machine. How do I get full voltage out of this...
I would guess that this uses both of the 15 amp breakers to make the 30 amp circuit. Try carefully measuring the voltage at the back of the 30 amp outlet after pulling it out. You may have a bad socket. look at how it's wired behind the panel too and see if there are wires from the other sockets to this one. If so, check all connections between them. If you still can't figure it out, try to get a picture of the panel and the wiring behind it and send it to Shelomah@i-can-fix-that.com
Dec 06, 2009 | Honda 3000 Watt Portable Generator
I have a 3000is not starting. Has gas spark oil.
Use fresh gas! Dont just pour some on top of the old...Change it out.
Drain the carb bowl (Honda carbs have a drain screw slightly off-center of the bowl bottom).
The Honda EU3000is uses a vaccuum-operated fuel pump and old gas will ruin it also.
Take the fuel supply line off the carb inlet, direct it in a container and spin the engine over. It should pump a stream that is FULL LINE DIAMETER.
If still no start, take it to an AUTHORIZED Honda Power Equipment Dealership.
Find one here.
Hope this helps.
Sep 27, 2009 | Honda 3000 Watt Portable Generator
Generator runs great but doesn't produce any power
There is a electronic module that senses load current that pulls the throttle up for high RPM. Fine the module and look it over, you may need to replace it.
Jun 23, 2009 | Coleman Powermate Premium Plus 6250W...
Battery in a honda 3000is
The battery is behind one of the end plastic casing pieces. You have to remove the center plastic panel, then remove the bolts holding the handle in place, and then remove the small, lower metal panel. I don't remember if it is on the side where the exhaust opening is or not, I believe it is on that same side.
May 04, 2009 | Honda 3000 Watt Portable Generator
My trace inverter SW2512 will only allow pass through power.
First problem is caused by the new generator producing too high a frequency... 65 Hertz is above the inverter limit. Adjust the governor down to 60 or 61 Hertz.
Breaker tripping may be due to excessive current draw from the Honda. Check the max AC input menu on the inverter. It might have been set lower to avoid overloading the original generator but if DC power was turned off at any time while you were changing generators, the inverter would have returned to it's default settings which may exceed the Honda's capacity.
Mar 29, 2009 | Xantrex Technology Trace Series Inverter /...
Electrical Supplies Logo
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
