Question about Kenmore Washing Machines
Kenmore Quiet Pak 4 front loader washer machine, sanitary cycle only runs with warm water and 35 minutes. Can anything be done to get it to run with hot or hottest water temp and more time?
  • Kenmore Master
  • 17,151 Answers
IF you take the front panel off that is under the door, there is a service technicians sheet in a plastic envelope on the frame, when you get it, use it enter the codes on the controls to get to diagnostics. It will self test everything and tell you what is wrong.
Posted on Dec 26, 2016
Kenmore elite smartwash quiet pak 4
This video will show you how to change a door seal on this Bosch front loader washing machine
You can find more Bosch videos in our Bosch repair channel
Jul 22, 2013 | Kenmore Elite 45986 Front Load Washer
How do I reset and unlock the door on my Kenmore Elite quiet pak 4 washer?
Press and hold "end of cycle" at the right end of your panel for 3 - 5 seconds. The machine power should be on.
Try the door 2 minutes after this.
Mar 29, 2013 | Kenmore Elite 45986 Front Load Washer
Washer smell
If this is a front loader, clean around the rubber "boot" inside the doorway between the front of machine and the drum by pulling out a little to reveal buildup behind it. This can get a funky smell. You can also run the "sanitary" cycle if your unit has one, with bleach, which will clean the tub better.
Jan 12, 2012 | Kenmore Washing Machines
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
its a inlet water supply error code check your cold fill line and fill screens at cold fill valve for block
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE SMART WASH QUIET PAK 4 FRONT LOADER,
Now this is a drain issue from the pump, clean out or check drain hose position to make sure hose isnt in water. Front loader right? kick panel under door has two screws, 1/4 or Torx T20 will remove them. You will see a clean out screw handle that holds junk. Use a trash bag wrapped around the clean out to catch water and debris..
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
43 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
