Question about Air Air Purifiers
My question has nothing to do with Air Purifiers. I'm asking about purifying water only.
SparkGap
  • 363 Answers
SOURCE: Flair air purifier
You can download the users manual and troubleshooting guides from the Ecoquest web site.
http://www.ecoquestintl.com/customers/owners_manuals/index_home.asp
Posted on Oct 21, 2007
  • 19 Answers
SOURCE: Oreck XL® Professional
clean your cell. Allso check for broken or loose tungsten wires in cell.
Posted on Feb 22, 2008
  • 6 Answers
SOURCE: my ionic breeze quadra GP silent air purifier has no power: stopped working!
Okay, after working on my Ionic Breeze Quadra I have fixed it. My problem was it wouldn't turn on even though the fins were clean.
1. Unplug
2. Turn the machine upside down (there are 4 screws holding the bottom stand on) remove the screws
3. once bottom is off there are 2 screws sideways helping the hold the 2 sides together. Remove those 2 screws.
4. Turn the machine uprgiht and remove the middle fins (the ones you clean)
5. Remove the 4 screws that are deep in the 4 holes when you look down inside (you can't see the screws, I had to feel for them with a phillips head narrow screwdriver)
(it will be easier if your screwdriver has magnetic head for next step.)
6. after removing the 4 screws gently work lose the top (part that has the little lights and turn on push switch)
7. turn the breeze on its side, you will find about 5 or 6 tiny screws holding the two sides of the outside louver case together. Remove all these screws. You will be thankful for the magnetic end, I have small fingers and still had a problem catching the little screws.
8. You want to take off the screws from both sides but only remove one side.
9. Being careful of the wires (I left that side alone) I worked from the wire free side and using a bottle of rubbing alcohal and lots and lots of q-tips I gentle cleaned off all the gunk on all the little metal pieces at the bottom of the breeze (on the inside where the wires are). Clean as good as you can, you will find the metal pieces covered with what looks like tar but it comes off with the alcohal.
10. Using a can of 'canned air' like you'd use for a computer, gently blow the rest of the breeze parts getting all the dust away but being careful not to damage the electronics. (there are a lot of little computer boards). I didn't find any dust in the electrical parts in the very bottom of the breeze, just above where the fins are and some at the top where the controls are.
11. I cleaned the 1/2 I took completely off with some rubbing alcohal, gets that **** off pretty good but didn't mess with the side with the wires, just blew the dust out, gently cleaned a bit and on the outside.
12. To put back together, first I gently put the outer middle pieces together and then gently put the control top back on and replaced those 4 screws. Then I put the 10 or 12 tiny screws back into the middle, then the 2 screws in the bottom sides and 4 screws putting the stand back on. I stood it up, plugged it in (make sure its dry) and turned it on and the light came on and it is working great.
I've had mine for 3 years so I think they occasionally need a thorough cleaning. Except for the canned air I bought nothing else. Everyone has rubbing alcohal and q-tips in their homes. When I first started I didn't know how to dismantle it and tried to clean the inside with long q-tips but it was too hard. Those little metal pieces in the bottom make some sort of connection to the fins we pull out and clean so I guess they need good contact.
I hope I've helped all of you with the problem of the Ionic Breeze Quadra and I suspect any other iconic breeze type machine by sharper image pretty much comes apart the same way and may have the same problems. I don't know how to post this so that everyone can see it as a general solution. Maybe you guys at FixYa can help with that. --- Harry Potter Without the Wand (and a female to boot!)
Posted on Mar 08, 2009
SOURCE: I have 2 ionic breeze air purifiers sharper image.(germical )
I have the same problem as gerardperez7. One of my germicidal light quadras won't turn the light on and doesn't appear to be cleaning the air at all. I even put a new light bulb in it and it doesn't fix the problem.
Posted on Dec 22, 2009
  • 28 Answers
SOURCE: I have two sharper image quadra air purifiers.
There's a link to one manual here:
http://www.amazon.com/Sharper-Image-Breeze%C2%AE-Purifier-SI637BLK/dp/B0000AUTU3
try google
Posted on Mar 09, 2010
Do I need to fill 588 air purifier with water and were do I fill it please?
I have re-categorized to Air Purifiers rather than washing machines. What is the make and model of your air purifier?
Air purifiers usually run dry and filter the air, some add ionized air to the mix, so do add water, but those are usually called 'humidifiers.
If it is this unit '588', then it does have water tanks.
http://www.asia.ru/en/ProductInfo/1253334.html
Aug 31, 2015 | Air Purifiers
What is the best way to clean your air purifier that has cigarette smoke
Try vinegar and water solution. Some people prefer Javex with water for tougher stains but be careful to air it out before exposing anyone to the fumes. Read the instructions for the ratio of Javex to water. Good luck
Dec 07, 2013 | Honeywell Enviracaire Elite F300E-1019 Air...
Smelling of tobacco on cd so bad, how make oddor disapear ?
My solution has nothing to do with air purifiers other than you use them to keep the air clean. In the old days we put household vinegar in a bowl, hid the bowl under the bed or a chair. The vinegar "swallows" the tobacco smell.
Aug 19, 2013 | Air Purifiers
I have been looking to buy an air purifier and people keep telling me to get a HEPA. What does this mean?
HEPA is a type of air purifier. It stands for high-efficiency particulate air. To qualify as a HEPA filter by government standards the filter must remove 99.7% of all particles larger than 0.3 micrometers from the air. The following site lists the top 10 HEPA purifiers available online - http://www.air-purifiers-america.com/AP101_top10.asp.
Jul 12, 2012 | 3M "Replacement Filter, 11 7/8 x 18 3/4"
Do you add water
Air cleaners do not use water. I have never heard of a "water" air filter. There is a device which is a humidifier, and it has a tank for water. If you put water in your air filter, it will be ruined. alfiefinnell@gmail.com
Jan 13, 2011 | Duracraft DA5010 Air Purifier
Dec 19, 2009 | Sharper Image Professional Plus Ionic...
No smell
clean plates and blow out guts with compressed air. clean plates with mix of water and amonia!
Sep 28, 2008 | Ecoquest Flair Air Purifier
Air Purifiers Logo
126 people viewed this question
Top Air Purifiers Experts
NOEL
NOEL
Are you an Air Purifier Expert? Answer questions, earn points and help others
