My singer has error E1, what is it? - Heating & Cooling
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    I have an error reading e1 but the bobbin and thread are fine
    You need to hold the thread tightly when you do your first 5 or 6 stitches. The pull out card on the machine will tell you exactly what the E1 error mean
    Jan 02, 2015 | Singer Futura CE-250
    It keeps beeping when I am sewing a straight stitch it say E1
    E1 means the machine is out of order, usually turning the machine off & then back on clears it,unless there is something wrong with the computer part of the machine
    Sep 20, 2011 | Singer CE-200 Quantum Futura Computerized...
    I Have a Singer/Futura. While I start to sew the it flashes E1. Don't know what it means. I don't have a booklet.
    Go to www.Futura-support.com. You can download a manual there and then you'll have a better chance Since I don't know which Futura model you have, it's hard for me to tell you what the E1 message. means. Find your model on the website and download the appropriate manual. That should give you the answer you need.
    Apr 26, 2011 | Singer Sewing Machines
    E1 keeps coming up on my machine..I have re-threaded it about a dozzen times, changed the bobbin. NOTHING is working. I am only able to sew about 1 inch and E1 flashes again..HELP
    Well, first check to make sure that your machine is on a level surface and is completely balanced. Now totally unthread, insert a new needle, now with the presser foot up, rethread according to your manual, pull the top thread-it should move smoothly. Now put the presser foot down, it should barely move. This should seat your thread in the tension discs properly. If, this does not work, call Singer at 1-800-4singer and find out what the story is.
    Mar 13, 2011 | Singer CE350
    Hi i keep getting the E1 error message flash up on the sewing machine, it still sews but it keeps stopping and the E1 error message comes up, what exactly is wrong with it? can you he;lp? Thanks
    E1 means that your machine thinks the thread has broken.
    There's nothing you can do to fix this: it has to go to an authorised Singer Service Centre for diagnosis and repair. Usually it's a faulty thread sensor.
    Sep 10, 2010 | Singer CE-200 Quantum Futura Computerized...
    Singer Furtura E1 error message.
    Hopefully, you didn't use any bobbins that weren't specifically meant for this machine. Here's the joke-there are special bobbins that that this machine only works with. And anything else gives you a mess.
    They're not terribly easy to find, but they are available on eBay. Do a search for Singer Futura CE100 bobbin under crafts. I just bought a bunch from a place called World Weidner in Oklahoma through there. This will hopefully take care of your problem.
    Wish I had been on here answering posts for you a number of months ago. If this doesn't help, please leave me a message in comments. If nothing else, I'll buy the bobbins back from you.
    Jan 16, 2010 | Singer CE-100 Futura Computerized Sewing...
    My Singer Embroidery machine works wonderfully on embroidery, but...when strait stitching or design stitching...constant error. Thought it was the tension, so I've tried every setting. Still beeps and get...
    HI,
    Did you make sure that you raised the feed dogs? There is a sliding button on the front that you have to move sideways to let the feedogs come up. If not the fabric is not being move right and that may be the reason of the wrong stitching.
    Also, are you oiling your machine appropriate?
    Dec 15, 2009 | Singer CE-200 Quantum Futura Computerized...
    Heating & Cooling Logo
    109 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
