Question about Polar Express Crafts & Hobbies
Lionel Polar Express 2-8-4 does not run. Makes a sound like the gears are not meshing. Also the wheels turn freely on their own which I think is not typical.
4 Suggested Answers
SOURCE: Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
Posted on Dec 23, 2009
  • 2418 Answers
SOURCE: The Cw 80 watt transformer
If you have a volt meter you can check the rails for power, Check the transformer wiring to the first rail connection and then along the rails for loss loose connection(s). If you have power to the rails it is an issue with the Engine, Check any brush or rail riders (connections) for a bent or broken tab. If for a temp fix in a broken connection tab or brush you can use Tin foil. Hope this helps.
Posted on Dec 25, 2010
residentoccu
  • 161 Answers
SOURCE: lionel polar express train is stopping on the track, then becomes disabled
Replace all the batteries, then keep the remote close to the
train. if it's too far away, it will shut down.
Posted on Mar 02, 2013
Led blinks when train put on track
I am assuming you are using the Lionel CW80 power source. If so, the blinking light might indicate a partial short or a problem with the motor. The reason I believe that is that the CW80 has an internal fuse, which will blow for near shorts/shorts. A stalled motor i.e stuck drive gear, can cause excessive power drain although not enough to blow the internal fuse and also cause the engine not to move. Also, If the engine has the neoprene belt on one of the drive wheels it might have come off and is jamming the running gear or wheel. I believe the Polar Express only has one neoprene belt.
Feb 10, 2015 | Lionel The Polar Express Train Set
Lionel o guage polar express set transformer has a bell button but don,t work no sound
IfIam correct, the basic Polar Express came with just a whistle. There is an optional coal tender that has a better sound system in it...Whistle bell and steam sound also try reversing the power wires at the transformer or track
Mar 11, 2014 | Lionel Trains The Polar Express O Gauge...
New polar express motor wont engage
It sounds like the gears have worn out or come adrift somehow. You will be able to get replacement gears from any of the Lionel authorised dealers Lionel Authorized Dealers or their replacement parts service Replacement Parts
Dec 28, 2013 | Lionel The Polar Express Train Set
White Gears
You might be able to get replacement gears from Lionel
May 01, 2013 | Lionel The Polar Express Train Set
I'm looking to replace the little white gears in the locamotive.
You could try contacting the Lionel Service Department on
their website contact service. Contact Lionel Trains
Take wheels off polar express
You will have to solder them using a pencil soldering iron.
Feb 13, 2012 | Lionel The Polar Express Train Set
Crafts & Hobbies Logo
177 people viewed this question
Top Polar Express Crafts & Hobbies Experts
Andrew Taylor
Andrew Taylor
mikeymars
mikeymars
Level 1 Expert
Are you a Polar Express Craft and Hobby Expert? Answer questions, earn points and help others
