Question about Building Materials
When I go to open the door the door button sticks and won't let me close until I play with the button any fixes for this
  • 6 Answers
SOURCE: Sensor lights not working on door opener
If the sensor light or receiver gets kicked, it can be knocked out of alignment. If it's not aligned, it will act as though it is blocked -- in other words it will open, but not close.
I fixed my buddy's opener not long ago -- you should have two parts of the sensor, near the floor at the bottom of the door. One is an infrared light, the other is a receiver. The receiver should have a little LED on it. This glows green when it is receiving a clear signal from the other side. If your's is glowing red when you can see that the path is clear, try adjusting the aim of the infrared light. You should be able to gently move the light from side to side until you see the LED on the receiver glow green.
Posted on Dec 07, 2008
rulds2008
  • 3866 Answers
SOURCE: Problem with Sears Garage Door Opener
The motors is cought on something check the motor if it moves inches it will move a yard the question is the motor is it getting power? if so is it stuck on its own drive chain? Check these things you be glad you did.
Posted on May 25, 2009
swolfinor
  • 504 Answers
SOURCE: sears craftsman garage door opener
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Posted on May 27, 2010
  • 3197 Answers
SOURCE: Hi, I have a Lynx 455
Check the sensors in the doorway. Sounds like they may be misaligned. They need to be pointing at one another to work properly.
Posted on Sep 28, 2010
  • 3197 Answers
SOURCE: My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Posted on Feb 22, 2012
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a 3/4 horsepower liftmaster garage door opener, both the remote and the wall button won't close the garage door but both will open the garage door. however, the garage door will close if I hold...
If when closing the door it reverses to the open position and the main light flashes 10 times it is a door sensor problem. Make sure the small light on each sensor is on and not flickering ever so slightly. (check closely) Tweak them a little even though they may seem to be okay. Check for 5vdc between terminals 2 and 3 on the rear of the motor unit. If there is no voltage or if it is greater than 6vdc the logic board is bad.
Sep 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
41a4315-7d remote opens garage door, but it won't close it; in order to close the door i have to use the wall mounted button and hold it down until the door closes all the way to the concrete. if i...
Check the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Aug 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
96 lincoln mark 8,Door Ajar,cannot reset clock until close door? They are closed, any fix for constant door ajar message
one of the door pins that sense when the door is open is probably bad, or maybe sticking
Mar 18, 2010 | 1996 Lincoln Mark VIII
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sharp carousel under counter microwave start doesn't always work
Sounds like an intermittent door switch or a loose door switch mount. Very common.
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 14, 2007 | Sharp R-9H66 Microwave Oven
Building Materials Logo
53 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
