Laptop screen acts strange (grays out in areas) when connected to Cricut Air Gold and using Cricut Design software. What causes this and what is the fix?
    Top Expert:
  • Computers & ... Master
  • 23,236 Answers
I would make sure the screen resolution is correct.
Posted on Dec 26, 2016
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    How do I use the Artbooking cartridge on the cricut design studio?
    Cricut design studio is no longer supported by Cricut but if you mean Cricut Design Space then this is how you do it. Open and sign in to Design Space select insert images and in the box on the right select my Image sets and then type in Artbooking. Artbooking cartridge will then come up for you to select what you want. all images come onto the mat at 2.5 inches they havent fixed this yet so you have to resize your images. If you want to download the image numbers from the artbooking book which go with design space go to http://thenon-craftycrafter.blogspot.co.nz/p/image-codes.html and download the artbooking book from this lady please join her blog and leave her a message as she does a lot of work all of which she does for free. Also if you youtube cricut design space. or go onto design space in cricut.com
    Aug 20, 2014 | Cricut Expression Cutting Machine
    I have a cricut expression 2 and after I turn it on it won't go past the Cricut screen. Any thoughts?
    Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
    The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
    Test all power and data leads that attach to your hard drive IDE,SATA
    the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
    Hope this helps.
    Jan 20, 2013 | Computers & Internet
    TheI can not reset the circuit machine all green lights are on
    You can call customer support. They will have you install the Cricut Design studio just so you can access the firmware update. You must find a PC to do this - it will not work on your Mac that you use for everything. After your 10 year old PC takes 40 minutes to install and open Studio, you run it and restart your Cricut and all of your green lights stay on. You re-run it just to be sure, and all of your green lights stay on. You call back customer support and they have you cut out the drive belt to disable your Cricut and take a picture of it, then they will send you a refurbished replacement Cricut - white and gray, not white and pink like you own. This was my experience today and my only used twice Cricut is now ready for garbage pickup.
    Jul 23, 2012 | Provo Craft Cricut Expression Personal...
    I can't get my cricut to cut out the whole letter. it cuts part of it but not all of it
    I need more information. Are you using Cricut Design Studio or cutting just from the cricut itself. If you're cutting from Design Studio then you need to make sure your letter is within the space of the mat. If there is some hanging off the edge or past the cut line then it will skip over it and not cut it.
    Feb 15, 2010 | Provo Craft Cricut Disney Font Cartridge
    Jpeg file onto a cricut
    Cricut does not accept jpegs. They use their cartridges that come with the machine and others that you can purchase. However if you have Cricut Design Studio you can design your image with the cricut. Any further questions feel free to ask.
    Dec 02, 2009 | Provo Craft Cricut Disney Font Cartridge
    Cricuit design studio program problems
    I believe you have a bad install. prehaps one of the files is corrupt.if you downloaded the file uninstall.reboot and reinstall online with your firewall n antivirus programs disabled.They may be blocking the full install.Need more info or help contact me.RICHARDM69
    Aug 30, 2009 | Dell Dimension 2400 PC Desktop
    Video Display Problem
    Thats because its all onboard and you have to replace the mother board. Its probably the screen, not the video card seeing as how external displays work fine.
    Most likely over heating or damage to the screens data ribbon that connects to the board is causing the issue.
    Or someon put something to heavy on the lid.
    remove the keyboard and underneaith should be the push in ribbon connector that attaches the monitor to the system board.
    try removeing and re-connecting it.
    Make sure the laptop is off of course.
    While your in there, use some compressed air to clear out any dust around the CPU and Fans and anywhere else.
    Most likely its a gonner, try finding a new or used one on ebay ans ordering from the manufacturer is usually very expensive.
    Good luck
    Nov 18, 2008 | HP Pavilion ze2000 Notebook
    Cricut design studio software
    I was recently told that as long as I have the serial #'s, I could download the program onto my new computer without having to re-buy it.
    Aug 27, 2008 | Computers & Internet
    Computers & Internet Logo
    David Payne
    David Payne
