Question about GPS
How to Reset language whirlpool fscr80433 - GPS
Tip
China Phone Secret Codes
<span><b>Fast Unlocking</b><br /><br /><b>CHINA Mobile Phones Secret Codes</b><br /><br />Default user code: 1122, 3344, 1234, 5678<br />Engineer mode: *#110*01#<br />Enable COM port: *#110*01# -&gt; Device -&gt; Set UART -&gt; PS Config -&gt; UART1/115200<br />Factory mode: *#987#<br />LCD contrast: *#369#<br />Restore factory settings: *#987*99#<br />Software version: *#800#<br />Software version: *#900#<br />Set default language: *#0000# Send<br />Set English language: *#0044# Send<br />Set English language (new firmware): *#001# Send<br /><br /><b>Service codes Fly:</b><br />2040(i) reset defaults: *#987*99# Send<br />M100 software version: ####0000#<br />MX200 reset defaults: *#987*99# Send<br />MX200 software version: *#900# Send<br />MP500 reset defaults: *#987*99# Send<br />MP500 software version: *#900# Send<br />SL300m reset defaults: *#987*99# Send<br />SL300m software version: *#900# Send<br />SL500m reset defaults: *#987*99# Send<br />SL500m software version: *#900# Send<br />Set language to English: *#0044#<br />Set language to Russian: *#0007#</span> <span><br /></span> <span>*#66*# Set Factory Mode CONFIRMED<br />*#8375# Show Software Version CONFIRMED<br />*#1234# A2DP ACP Mode CONFIRMED<br />*#1234# A2DP INT Mode CONFIRMED<br />*#0000# + Send : Set Default Language CONFIRMED<br />*#0007# + Send : Set Language to Russian CONFIRMED<br />*#0033# + Send : Set Language to French CONFIRMED<br />*#0034# + Send : Set Language to Spanish CONFIRMED<br />*#0039# + Send : Set Language to Italian CONFIRMED<br />*#0044# + Send : Set Language to English CONFIRMED<br />*#0049# + Send : Set Language to German CONFIRMED<br />*#0066# + Send : Set Language to Thai CONFIRMED<br />*#0084# + Send : Set Language to Vietnamese CONFIRMED<br />*#0966# + Send : Set Language to Arabic CONFIRMED<br />CHINESE MODELS:<br />default user code: 1122, 3344, 1234, 5678<br />Engineer mode: *#110*01#<br />Factory mode: *#987#<br />Enable COM port: *#110*01# -&gt; Device -&gt; Set UART -&gt; PS Config -&gt; UART1/115200<br />Restore factory settings: *#987*99#<br />LCD contrast: *#369#<br />software version: *#800#<br />software version: *#900#<br />set default language: *#0000# Send<br />set English language: *#0044# Send<br />set English language (new firmware): *#001# Send also</span> <span><br /></span> <span>also it will helps you thnx</span>
on Jul 12, 2011 | Cell Phones
Tip
CHINA PHONES CODES
More some codes for reset mobile
china
*#77218114#
*#881188#
*#94267357#
*#9426*357#
*#19912006#
*#118811#
*#3646633#
CHINESE MODELS:
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
also
Service codes BenQ:
software version: *#300#
test mode: *#302*20040615#
Service codes Pantech:
software version: *01763*79837#
service menu: *01763*476#
reset defaults (phone/user code reset to default): *01763*737381#
Service codes 3xx, 5xx:
software version: *#79#
software version: *#837#
Service codes VK200, VK2000, VK2010, VK2020, VK4000:
service menu: *#9998*8336# (hold #)
reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
Service codes LG:
software version: 2945#*#
Service codes Sony-Ericsson:
J100 software version: #82#
Service codes Fly:
Service codes Konka:
C926 software version: *320# Send
C926 set default language: *#0000# Send
C926 set English language: *#0044# Send
Service codes GStar:
GM208 (Chinese Nokea 6230+) engineering menu: *#66*#
ZTE Mobileyahoo15.gif1- *938*737381#
2- PHONE WILL DIPLAYED DONE
3- POWER OFF YOUR PHONE AND POWER ON AGAIN
alcatelyahoo15.gifE205
unlocking phone code,only press***847# without simcard
E900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes "Chinese" models:
Service codes BenQ:
Service codes VK-Mobile 3xx, 5xx:
service menu: *#85*364# (hold #)
Service codes LG:
KG300 NVRAM format: 2945#*# -> menu 15
Service codes Fly:
Service codes Motofone-F3:
Motofone F3 software version: **9999* Send
***300* Set SIM Pin
***310* / ***311* SIM Pin ON | OFF
***000* Reset Factory settings
***644* Set Voicemail number
***260* / ***261* Auto keypad lock ON | OFF
***510* / ***511* Voice Prompts ON | OFF
***160* / ***161* Restricted Calling (Phonebook only) ON | OFF
***200608* Send: software version
***200606* Send: software version
***200806* Send: flex version
***250* / ***251* Keypad tones ON | OFF
***470* Select time format
***500* /***501* Prepaid Balance Display ON | OFF
***520* Change language
Service codes Motorola:
C113, C114, C115, C115i, C116, C117, C118 software version: #02#*
C138, C139, C140 software version: #02#*
C155, C156, C157 software version: #02#*
C257, C261 software version: #02#*
V171, V172, V173 software version: #02#*
V175, V176, V176 software version: #02#*
C168, W220 software version: *#**837#
W208, W375 software version: #02#*
and "yes"''
-mobile Inno30, 55, 89, 90, 99, 100, A10, A20, P10, Vk200
- Set full factory *741*737381#
- Set full factory *741*7373868#
- Set full factory *741*2878#
- Set Engineer Mode *888*888#
- Check software version *888*837#
I-mobile 100 ,200 , 313
- Check software version #*888#
I-mobile 309, 310
- Check software version *0*4636#
- Test Mode *0*6268#
I-mobile 311
- Check software version #*878#
I-mobile 511
- Check software version *1222*1#
I-mobile 301, 302,308, 508, 601, 602, 603, 604, 606, 611, 901, 902
- Check software version *#159#
- Set Factory Mode *#32787#
- Set Engineer Mode *#3646633#
I-mobile 503, 506, 605, 600, 607, 608
- Set Engineer Mode ***503#
- Set Factory Mode ***504#
- Set Auto Test ***505#
I-mobile 509, 612
- Set Factory Mode *#66*#
I-mobile 504, 505, 803
- Check software version *68*48#
- Set full factory *789#
- Test Mode *#789#
I-mobile 305, 306, 315, 510, 609, 609i,516
- Check software version *#8375#
- Set Factory Mode 878
I-mobile 610
- Check software version *#22#
I-mobile J101, J102
- Test Mode *23638777*783781#
I-mobile 502, 502i, 505, k9, 802
- Check software version *201206*4636#
on Mar 11, 2008 | Nokia N95 Cellular Phone
How to navigate to factory reset?
Factory resetting it may still return you to Spanish as it's default language or even worse enough, Chinese. You can download language translator on another phone,PC or tablet as your guide to reset it to your language of choice. Do it this way, translate, menu,settings, language setup into Spanish and follow them on your phone to navigate to change the language.
May 16, 2014 | Blu Zoey T176 Mobile Phone
How do i Reset my Dsc-T5 menu language
Press the MENU button. Select the toolbox icon. Select the toolbox-1 icon. Select the "A" icon.
Sep 30, 2012 | Sony Cyber-Shot DSC-T5 Digital Camera
How to rest language? selected wrong language during installation
No need to reset.
Go to SETUP&RESET (image below)
3xsg4vp5fkugrq9oxofzoq4dpd17tm1do1cn4llemk67dauvmohjmhek6gmaaaaasuvork5cyii=
Then go to language (there are 3 different languages so it could be named..
* Language
* Lengua
Change the language.
PLEASE RATE MY SOLUTION
Jun 20, 2011 | Samsung B2230 22 inch LCD Monitor
Want to change language?
If your tom tom is in a wrong language, to set it back or change it to the normal language, all you need to do is to reset it. To reset it, hold down the power on/off button for about 15 seconds, it will restart the tom tom, that way the language will be restored back to its normal language.
If you are not requesting to change the language back to its normal language, then to change the language to any other foreign language, what you have to do is to go to the gps settings, then you select from the options where you find language, then you select your choice language, that way your language will be changed.
hope this helps.
Dec 23, 2010 | Tomtom One XL GPS Receiver
Language settings
Press Menu, autourg00846004id2022604.jpg to highlight Setup, then autourg00846004id2022626.jpg to access settings
Select Language then choose your Language.
The option before
Language is Reset, this will reset all options to their default.
In Danish:
Settings =
indstillinger.
Language = Sprog.
Setup and reset are the same.
Hope this helps.
Feb 01, 2010 | Kodak EasyShare M1033 Digital Camera
Change language settings htc diamond
my phone is in danish languages how can i changes it to english?pls help me plsssssssss
Mar 25, 2009 | HTC Touch Diamond Smartphone
GPS Logo
32 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
