Question about Samsung Refrigerators
I have a side by side Samsung RS263TDRS not cooling. Compressor comes on and then goes off but is very hot to the touch. what part need to be replaced?
    Top Expert:
  • Samsung Master
  • 48,497 Answers
Need freon added by a tech
Posted on Dec 26, 2016
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
Samsung RSA1NTPE not cooling in either the fridge or freezer. Seems like the compressor is not running although it is hot too the touch.
the compressor is seized and wont pump and the motor keeps trying
to work and thats why its hot,sorry to tell you but you need a new
compressor
Aug 21, 2012 | Samsung Refrigerators
Whirlpool 25.6 cu. ft. side by side Refrigerator with in door ice
The process of Refrigeration is for one section to be hot while cooling another section. I.e freezing in one section result in the heat build up and dissipattion else where. Any compressor working properly is going to be quite warm to the point of being hot to the touch when working NORMALLY. There is nothing that you need to do for the continued safe operation of your compressor. If your freezer has ice build up again in the near future your uint is not defrosting properly. If it functions normally after 2 or 3 days of use then you more than likely had a one time buildup of ice usually caused by someone leaving the door partially open
Jan 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My samsung rs2630sh is very very hot to the touch
The fan you should replace is called the condenser fan. It's the one that blows air across the outside coils. When it fails, you'll usually notice abnormal heating of the front of the divider between freezer and fridge.
Oct 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Oct 02, 2008 | Refrigerators
My Waring Pro Ice Maker is not cooling. The water pumps through the system but the machine does not freeze. The machine is 18 months old.
JUST SWITCH ON YOUR ICE MAKER AND TOUCH THE COOLING SIDE HOT OR COOL ,
1st . COOLING SIDE IS HOT THE MACHINE COMPRESSOR IS FAULT REPLACE THE COMPRESSOR
2nd. COOLING SIDE IS JUST COOLING CLEAN MACHINE CONDENSER COIL
Jul 19, 2008 | Refrigerators
Compressor is extremely hot
Compressor will be hot to the touch. You stated the fan was replaced and then said the fan is not cooling. If you replaced the fan and it is now operating, reinstall the panel you removed to install the fan motor. That panel determines proper air circulation to cool the system.
Jun 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE refrigerator not cooling
on most refrigeration, the refrigerant goes to the freezer first and the tail end to the fridge. it is probable that the compressor is failing. compressors are quite hotg when running but not too hot to touch. if the compressor is too hot that also indicates failure. doubt it is worth repair
May 19, 2007 | GE GSS25JEMWW Side by Side
Rs2630ww
You should be able to see the fan spinning if you look under the frige with a flashlight to the back or feel air flow (tissue paper helps) coming from underneath it. As for the center column, if you mean the divider area between sides, that being real hot means the compressor refrigerant is overheated. It should be warm to touch not hot. Sounds like your condensor fan is out or packed full of dust bunnies and not spinning. The compressor will overheat and "trip" the thermal overload on and off so you do need that cooling fan. All the underside of the frige needs to be clean and clear of hair, pet fuzz, etc. in order to cool properly. The fan is likely out of warranty but they are cheap and easy to replace by a homeowner.
Dec 19, 2006 | Samsung RS2630WW Side by Side Refrigerator
Rs2630ww
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
