I have ywo different mp3p players my charger fits both but will only charge one why?
    Top Expert:
  • Audio Player... Master
  • 77,939 Answers
The charger connection is defective in the player or the battery is no good.
Posted on Dec 26, 2016
How do i charge this device?
Is there a Model number on this bluetooth, can't find RoHs....
At Walmart and Stores like that they have different chargers that have different charger ends pieces, you can try to see if any of the ends fit in the charger slot at the end of the bluetooth. Most of these universal chargers have end pieces hanging out of the package, so take your bluetooth and try different ends. Example but do not know if its the right one is:
May 09, 2013 | Cell Phones
I have 2 sony mp3 players and they both won't charge. charger is working
hello there !
Check your charger pins First are they OK.
then go for the Sony player charging point . is it clean enough that pins can make charging , if they aren't then clean with a needle.
thirdly do try to use a original Sony charger as i had some players back and it wont work cause i didn't use a branded charger .cause the out put sometimes get different and they are not of slandered quality.
Do comment if it helps you in any manner
ill give you a feedback
Apr 23, 2011 | Sony Walkman Video NWZA818 MP3 Player
Hi i have an alba MP2200BUK mp3 player.. how do i charge it? When do i know that the mp3 player is charged?
connect the usb cord you received with the device to the device and to your computer and it will charge automatically. generally you want to charge a device for several hours at least, most devices will let you know when they are done charging.
Feb 15, 2011 | Audio Players & Recorders
Mine isn't a ZEN V Plus but it is a ZEN mp3
it could be the battery that is dead, however it is more likely that the chargers your are trying do not match the voltage needs necessary to charge it. just because a charger fits does not mean that it will actually charge it. LI-ion batteries are VERY picky and some can explode (literally EXPLODE as in bang, where did my hand go) if the wrong voltage is applied. here's the thing, most devices have a fail-safe built into them so that you cannot mess up the battery unfortunately the first charger you tried could have fried this making it unchargeable the reason the other charger works is because when a proper voltage is applied the power is split between running the device and charging the battery (this is cut off if too much power is applied) the actual battery takes very little power to charge you should look up the player via google and take not of the voltage and amperage needed to charge it these are important, there is a good chance it will still work. just buy the proper cable to hook it up to the PC this should charge it however that's not a guarantee the olympus mr100 for instance, would not charge via PC only with the dock and wall adapter. good luck and i hope this helps!
P.S. there is still the possibility that the bat. is fried and you may need a new one.
Apr 14, 2010 | Creative Labs ZEN V Plus MP3 Player
For v3 razr charger can you use it with htc touch pro 2? it fits mini usb. Are voltages and amps similar?
USB Voltage is always 5V. That is standard. As far as your charger for your V3, different motorola chargers have different ampere or mA, but I wouldn't worry about it, you cannot overpower the Touch, it just may charge slower if the charger for the V3 is a weak one.
Other than that though, if it fits USB, you should definitely be fine.
Dec 02, 2009 | Motorola Mobility RAZR V3
Y wont the razor phone charger charge my MP3
Well it wont be compatible with the mp3. even if it does seem to fit into the slot where it charges you still wont get it to charge. also different chargers deliver a different ammount of energy to the device so it either wouldnt be enough or it would be too much. I hope this helps you solve your problem.
Feb 28, 2009 | Philips GoGear SA3125/37 MP3 Player
Charging mp605
If you have a nextel charger or a Motorola Rengade charger it fits and will charge your Mp3 player and let you listen to it at the same time as well.
Jan 04, 2009 | Coby MP550 MP3 Player
Charger will not fit anymore
If you got a USB cable with the unit, you can connect to your PC and recharge the battery that way. Just be sure to have the power switch turned ON. The screen on the player will indicate its connected and you should see the battery indicator in the lower right corner showing a charging condition (bar moving)
Feb 12, 2008 | Audio Players & Recorders
Not charging with AC charger
DID u try a different AC charger?
Nov 30, 2007 | Teac MP-8000 20 GB MP3 Player
24 people viewed this question
