I have a he2 plus it will power on but when you push start button it turns off. It will only run the clean washer cycle.
    Top Expert:
  • Washing Mach... Master
  • 79,189 Answers
Remove the control board and check for burnt connections, repair as needed.
Posted on Dec 26, 2016
catriver
  • 878 Answers
SOURCE: f-26 error message
F-26, is a door lock switch error code. Some things to try; Unplug the washer for 1 minute and see if the error clears. If not, try entering the diag mode by pressing any key except pause/ cancel. Press for 4 seconds and release for 4 seconds 4 times. If entered correctly, all lights should light and the first error should appear. Press the same key to advance through all the errors. When the errors finish. It will start an automatic test mode that tests all componets. The first thing it will test is the door lock. If this fails you more than likley have a door switch problem. Let me know how you make out. Catriver
Posted on Mar 06, 2009
jamesdaly
SOURCE: epic z front load washer will not start
Maytag service came out and told me it is control panel Part# W10217425. I washed 4 loads 1 day and came back 4 days later and got 1 load done. Then it wouldn't start and they won't replace. I got mine at Home Depot but, Maytag won't replace. They say it has to break 3 times before they will replace. After Maytag sent someone to fix and they said they had to order part and didn't know when they would be back. I called Home Depot and they overnight sent me part. Now Maytags service says they cant come back for a week and if I put in myself I lose my waranty. If you don't have waranty anymore, I found at Sears parts for $12.45 for board.
Posted on Jun 06, 2009
  • 5 Answers
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
Posted on Oct 10, 2009
rdrsp
  • 85 Answers
SOURCE: My Kenmore HE2 Plus codes F24. What does it mean
On this model of HE washer, the F24 code indicates that the water temperature sensor is out of range (23 degrees to 217 degrees F). This usually indicates a bad thermistor (temperature sensor). A bad wiring connection or a failed control board could also cause this problem. If you have the technical ability to safely access internal washer components, you may be able to repair this problem yourself. Diagnostic steps would involve unplugging the washer and checking the wiring connections between the thermistor and the control board. A resistance check of the thermistor would be needed using a volt/ohm meter.
hope this helps....
Posted on Oct 27, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have been trying to run the clean cycle on my
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
Kenmore HE2 Plus Model# 11047512600 When pushing the start button it will just beep 3 times and not do anything, door won't lock or start cycle. No error codes are displayed. Whats wrong?
Hello Jason,
Regarding
  • There is a communication error in the control board.
  • Also the door Latch assembly may be defective. Check & replace as necessary.
Here is a link to Sears parts direct.
KENMORE RESIDENTIAL WASHER Parts Model 11047512600 Sears PartsDirect
Jun 25, 2015 | Kenmore Washing Machines
No power when you push power button
Flip your breaker completely off. Wait about 20 secs. then flip it back on and make sure it is fully on and that it holds. Then try pushing the power button on machine. Failling that you may need to contact the properly trained techy.
Sep 26, 2014 | Kenmore HE2 Plus Front Load Washer
HE2 Plus Washer starts then shuts off immediately.
Aren't microprocessor controlled appliances wonderful? Especially when the code is flawed! No wonder the space program bit the dust!
May 12, 2017 | Kenmore HE2 Plus Front Load Washer
My son pushed stop in the middle of a wash cycle, now it won't drain and it turns off right after I press START.
Check your door switch button, its just above the door latch, sometimes that button has broken, or the door has dropped abit, not aligning correctly.
Dec 04, 2010 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore washer HE2 plus and F26 is flashing
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
May 14, 2010 | Kenmore HE2 Plus Front Load Washer
How do i reset my kenmore he 2 washer
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Jan 03, 2010 | Kenmore HE2 Plus Front Load Washer
How do you clean the inside of your Front Loading washer?
This can be accomplished by running the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 09, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
