Question about NetGear WN111 (DHWN111100NAS) Pre-802.11n Wireless Adapter
Wep key will not store...
Everytime the computer is rebooted the wep key has to be re-entered in the connection properties tab of the wireless connection. how do you get the computer to save the correct key?
Windows XP home edition SP1
  • 1,272 Answers
Hi, This is a prominent issue with SP1 on XP.Either upgrade it to SP2 or above or use NETGEAR Utility to connect to the network instead of windows one.
To download SP2 visit microsoft website and for NETGEAR UTILIY follow the steps below:
1. Double click on WN111 icon from the right hand extreme bottom corner of the screen, near the system clock, in the system tray.
2. Click on networks tab.
3. Click on the SCAN button - This will show a listing of all available networks.
4. Select the network you wish to connect to and click on the "CONNECT" button.
5. This will automatically take you back to the settings tab.
6. If you are using WEP security then Enter the WEP KEY under the option 'Enter Key manually' under the settings Tab.
7. Apply Settings .
8. This should get you connected to your selected network.
9. Click on the 'About' tab and check the IP address.
10. If you are getting an IP address in the format of 192.168.x.x, try to go online.
11. If you are not getting an IP or the IP is in the format of 169.254.x.x, restart the computer and then try to go online.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 21, 2009
  • Anand Gupta
    Anand Gupta Jul 21, 2009
    7. Apply Settings .
    Regards
    Anand
Where can I find the WEP number on my wireless router?
If your connected to a wifi network on your computer, right-click the Wireless connection and click properties. Under the security you will find your WEP key
May 08, 2011 | Computers & Internet
Tip
How to configure the wireless connection ?
Configuring the Wireless connection
Check the Following
1) Wireless Switch of the Laptop is off (Wifi is Off)
it is located somewhere on the edge of the laptops
or Fn+F2 might turn the switch ON and OFF
2) The setting required to configure wireless connection
Check the following steps
Windows XP
1. Click on the Start Menu, and click on Control Panel.
2. Find and double-click “Network Connections” to open up the list of connections that your 3. computer uses to connect to the internet.
4. Right click “Wireless Network Connection” and select “Properties”.
5. Go to the “Wireless Networks” Tab
6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
7. Click “Add” to add a wireless profile.
* Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
* Uncheck the box “The key is provided for me automatically”.
* Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
* Push “OK”
# Open Internet Explorer (with the computer connected to the Router)
# Enter 192.168.1.1 into the Address Bar, push Enter
# Leave the User Name field blank
# Under the password field enter “admin”
# Click “OK”
# Click “Wireless”
# Click “Basic Wireless Settings”
# Enter a desired name into the “Wireless Network Name (SSID)” field
# Write down your Wireless Network SSID, it will be used for later.
# Click “Save Settings”
For WEP:
* Click “Wireless”
* Click “Wireless Security”
* Select “WEP” in the “Security Mode” field
* Bubble “1” under the “Default Transmit Key” field
* Select “128 bits 26 hex digits”
* Enter a desired passphrase into the “Passphrase” field
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field on paper, and store it in a safe place. THIS IS YOUR WEP KEY, it will be needed later on.
* Click “Save Settings”
on Jan 22, 2010 | Computers & Internet
Tip
Enabling Wireless security on Linksys routers.....
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then unchecked “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
If this is a Helpful tip Thumbs Up is appreciated. Thank you
on Jan 03, 2010 | Linksys Wireless-G WRT54G Router
Cant play the ps3 online. it ask for ssid and a wep key need help
The ss id is the name given to your network and the wep key is the security code or password for the network...you will need to go to the computer that you used to set up the network...assuming your running windows go to the start button bottom left then go to control panel...then network status and tasks...open the properties by right clicking on the network status and tasks..in properties, you should see a window and there should be a button saying wireless properties...click wireless properties...there will be two tabs...connection and security...click connection...here you will see the ss id and you'll need to write it down...then click on security tab..here you will see the wep key and also write it down....next you need to go back to the game sys to enter the info that you wrote down and then it should work ok
Jan 22, 2011 | 2wire (2701HG-B) Wireless Router
Im trying to connect my laptop to the router,(the laptop is an hp pavilion running on windows 7, and the router is a 2wire) but I cant connect to the router and theres no option 2 put in the WEP key. (And...
Your class geek is not much of a geek. The computer can loose the wireless settings quite commonly. Open the wireless connection window as below:
right-click the network you are trying to connect to and click properties and then the security tab. You should get this window:
Change the encryption type to WEP and enter your router's WEP key. Click OK and you should be able to connect. OK?
Dec 05, 2010 | HP Pavilion dv6000z Notebook
In the middle of a connection, my husband's wifi connection was severed with a message that the settings were changed and a prompting that he type his WEP password. I am the primary connector to the...
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 31, 2010 | Computers & Internet
Wireless card does not connect to Linksys router, all other computers have no issues. I have a Toshiba M55-S331 with Intell Pro 2200 BG wireless card
Check the Following
Windows XP
2.Find and double-click “Network Connections” to open up the list ofconnections that your 3. computer uses to connect to the internet.
* Push “OK”
# Click “OK”
# Click “Wireless”
For WEP:
* Click “Wireless”
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field onpaper, and store it in a safe place. THIS IS YOUR WEP KEY, it will beneeded later on.
Jan 24, 2010 | Intel PRO/Wireless 2200BG 802.11g/b
Setting up wireless connection on aceracer, aspire sa90- wireless connection
Check the Following
Windows XP
* Push “OK”
# Click “OK”
# Click “Wireless”
For WEP:
* Click “Wireless”
* Click “Generate”
Jan 18, 2010 | Zonet Fast Ethernet Adapter Realtek 8139D...
How do I get my WEP Key for my LINKSYS ROUTER
To access the web-based utility, launch the web browser on
your computer (INTERNET EXPLORER), and enter the Router’s default IP address, 192.168.1.1, in the Address field/bar. Then, press Enter. A password request screen will appear. Leave the User name field blank then default password admin. (You can set a new password from the Administration tab’s Management screen.) Click OK to continue.
The Internet Setup section configures the Router to your Internet connection. Most of this information can be obtained through your ISP/ your internet provider. Internet Connection Type Select the type of Internet connection your ISP provides from the drop-down menu. By default, the Router’s Internet Connection Type is set to Automatic Configuration - DHCP, which should be kept only if your ISP supports DHCP or you are connecting through a dynamic IP address. 68be046.jpg IMPORTANT: If you are using WEP encryption, always remember that each device in your wireless network MUST use the same WEP your wireless network will not function properly.
WEP Encryption Select a level of WEP encryption, 64 bits
10 hex digits or 128 bits 26 hex digits. The default is
64 bits 10 hex digits.
Passphrase Enter a Passphrase to automatically generate WEP keys. Then click Generate.
Key 1-4 If you did not enter a Passphrase, enter the WEP key(s) manually.
Click Save Settings to apply your chang
Nov 12, 2009 | Linksys Wireless-G WRT54G Router
WRT54G3G router (Mobile)
Try this steps.
Go to Network Connections
Properties of Wireless Network Connection
Click Wireless Network Tab on the top
At the bottom, clear the Preferred Network box. Make sure delete all names that are listed.
Click OK all the way out
Enable the WEP on the router.
Now try to connect to the wireless network again with WEP enabled.
Make sure you enter the 10-digit code and not the Passphrase.
If it doesn't connect, try to power cycle the router. Just unplug the power for 30 seconds then reconnect to the wireless network.
That should do it.
Jul 31, 2008 | Linksys WRT54G3G Wireless Router...
NetGear WN111 (DHWN111100NAS) Pre-802.11n Wireless Adapter Logo
221 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
