Question about Kitchen Ranges
How do I take the front of the cooker off to get to the nobs as the back of the nob has fell behind
SOURCE: gas cooker keeps igniting
Sometimes when I clean my cooker, and it gets damp, mine ignites like that. It soon stops after it dries out. Give it chance and see.
Posted on Sep 09, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony TV channel stuck on 56 I need it on channel 3
Doesn't Channel + & - button work?
Let me know to guide you more.
Posted on Oct 27, 2008
SOURCE: canon elura 60 camcorder zoom is at its maximum and it is stuck .
 I have the same probelm how can i fix this.
Posted on Jan 29, 2009
memturbo
  • 226 Answers
SOURCE: new owner how do i use 4 wheel drive
you have to engage both sides
Posted on Mar 27, 2009
milten1
  • 1304 Answers
SOURCE: tefal sensor weights
thegourmetdepot.net
Posted on Oct 05, 2009
Where can I find a replacement nob for one of my favorite pots??
Use http://www.google.com or use the search in http://www.ebay.com and enter as much information as you can.
You may need to purchase a broken pot that has a working nob that you can use to replace the broken nob.
Apr 08, 2018 | Crock Pots & Slow Cookers
385 19000 touch screen is blank
There is probably an electronic problem with the circuit behind the knob.
Do you have a manual?
Kenmore 385 19000 Owner Manual
Feb 15, 2015 | Sewing Machines
Hotpoint ew91 halogen hob wont turn off
the control may have shorted. replace control(behind the knob).
Sep 10, 2012 | Hotpoint Ovens
Pilot light on hot water heater is out
you need to shut off the the red nob and turn the nob off in front take the cover off remove the heat shield turn the nob on top to pilot use a piece of paper to light put in next to pilot and hold button down for 20 to 50 secs pilot should stay lit turn nob on front then burner should kick on then you should be all good
Mar 21, 2012 | Water Heaters
I am assembling a 24 inch girls Traverse bike. Not quite sure how the front wheel goes on the fork! Seems obvious but I got confused when I saw the quick release assembly packaged with the pedals. Not...
The Front Quick release is used on the front wheel, if the axle is hollow. If it has nuts on the outside of the axle then it does not belong to the front wheel.
The front quick release is actually quite easy.
1) Place the front wheel into the forks.
2) unscrew the nob end of the skewer (opposite the handle end)
3) insert the skewer through the axle (from right to left if looking at the front of the bike)
4) Screw back on the nob a few turns.
The actual working of the quick release skewer is a cam (there is an imprinting on the handle that says open and close. make sure the handle has "open" facing out for the next step.
5) Holding the handle in your right hand, turn the nob with your left hand until the unit is almost tight.
6) Test the tightness by flipping the handle from "open" to "close". this is a cam. if you have the correct tightness then it will have some resistance to close the lever but not be difficult. If it is really hard, then back off the nob a little and try again. If it is too easy then tighten the nob a little and try again. After a couple of tries you will get it.
7) final test. Take a finger and try to flip open the lever, if you can't then its good, if you can then go back to step 6.
Dec 12, 2010 | Schwinn Cycling
Front on switch broke and fell off
u can check any appliance store, hardware if possible r variety store if they sell the nob for that particular brand, and take the broken piece you have left
Jan 20, 2009 | VillaWare Mickey's Classic 4 Slice 5555-08...
Broken nob
You can check with the manufacturer. They should have replacement parts available. You can also search the web, Ebay and Amazon. I found handles for my crock pot lids from a company on the web. You can also try a home improvement store. I know they carry knobs for all sorts of appliances.
Dec 28, 2008 | Bravetti KC281HB 8-Quart Slow Cooker
How do I put the nob back on the wall heater?
some times there is clip that goes in the knob shaped like a D that could have fell out , is called a D clips sounds silly i know might be that simple ,
hopw that helps
Dec 12, 2008 | Heating & Cooling
Delongi over nobs
yOU SHOULD NOT HAVE HEAT COMING FROM YOUR OVEN DOORS. MAKE SURE GASKETS ARE INTACT AND YOU OVENS ARE LEVEL.
Aug 08, 2007 | DeLonghi DEBIGE 2440 Electric Double Oven
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
